Help Need - KLR
Discussion in 'Thumpers' started by Mike Butt, Mar 21, 2010.
  1. Mike Butt
    Mike Butt Agent Provocateur
    Mar 6, 2002
    55,634
    Looking west
    2008 KLR650. Died suddenly while being ridden. Won't restart. Spark, yep. Compression, yep but I didn't put a gauge on it. Gas, yep, nothing stuck in float, can pass air through jets. Fuel gets delivered from tank to carbs. Took off the carbon canister et al, no affect. Put gas into cylinder via spark plug, wants to fire, but no. Could the CDI have failed? Anything I am missing? Less that 5K miles on the bike.
    Thanks.
  2. lostmarbles
    lostmarbles Long timer
    Jun 8, 2009
    1,922
    N.C.
    what is the color of the fire on your sparkplug yellow or blue :ear
  3. El Guero
    El Guero Long timer
    May 8, 2007
    9,605
    Iowa
    Did you check the air filter? It's a longshot but it sounds like you've checked just about everything. Short of that you might have a problem with the ignition...
  4. Mike Butt
    Mar 6, 2002
    55,634
    Looking west
    Good question. A friend grounded it while I spun the starter. He said it was a good spark. But I didn't see it. Would yellow be an indication of something? Weak spark?
  5. Mike Butt
    Mar 6, 2002
    55,634
    Looking west
    Will do.
  6. larryboy
    larryboy Just obey!
    Jan 9, 2005
    30,814
    Nebraska, Flat Earth!
    Jumped timing? Double check.:deal
  7. lostmarbles
    Jun 8, 2009
    1,922
    N.C.
    yellow bad blue are white gooooooddddddd:lol3 if you get yellow check the coil resistence
  8. Mike Butt
    Mar 6, 2002
    55,634
    Looking west
    I don't have the tools to check the timing. Is this a known issue? Wouldn't it wipe out valves? That would be a big ouch. :eek1
    #8
  9. larryboy
    larryboy Just obey!
    Jan 9, 2005
    30,814
    They have been known to break the balancer lever spring and to fling a broken spring end thru the cam chain...it can take out the valves too, sometimes a person will get lucky and it only jumps a tooth making for hard starting.
    #9
  10. ROYAL COACHMAN
    ROYAL COACHMAN Long timer
    Sep 11, 2007
    1,346
    Defiance, Mo.
    Might be a long shot, but I would check the side stand safety switch.
    It could have shorted out causing intermittent spark ignition.
    You said you blew out the jets, how about checking the small hole in the carb body (behind the butterfly plate) that control the idle circuit.
    Any chance you got some really bad gas?
    #10
  11. Mike Butt
    Mar 6, 2002
    55,634
    Looking west
    I'll shine a light down the spark plug hole and check for damage. Funny thing is that it first died down about 25 mph in low revs. I'd hope it would need more stress than that to jump a tooth.
    #11
  12. Mike Butt
    Mar 6, 2002
    55,634
    Looking west
    Haven't eliminated the gas. Same gas that I am using to test with is out of the tank. I'll try some starter fluid and see what happens.
    Re the side stand, wouldn't it not crank over if it was bad?
    #12
  13. ROYAL COACHMAN
    Sep 11, 2007
    1,346
    Defiance, Mo.
    I was under the impression the safety switches killed the spark, but I could be wrong. Some one more experienced with the KLR hopefully will chime in.
    #13
  14. ROYAL COACHMAN
    Sep 11, 2007
    1,346
    Defiance, Mo.
    One other thought Mike
    I have heard that if the vent tube from the gas tank gets blocked by debris, it will create a vacum that can cause fuel starvation.
    Upon opening the gas cap if you hear a slight hissing sound, check the vent tube
    #14
  15. Mike Butt
    Mar 6, 2002
    55,634
    Looking west
    Check that, good to go.
    #15
  16. threewinmag
    threewinmag Happily Lost
    Jun 22, 2008
    64
    Rockies!
    KLR's are notorious for their kick stand kill switches. Most people disable them soon after they buy the bike. You might check that.
    #16
  17. Hektoglider
    Hektoglider One with Life
    Jun 10, 2006
    2,536
    Lone Pine Ontario (or travelling)
    Try a new correct spark plug. Brand new , gapped correctly. The old plug may produce a spark while you test it, but under compression it may not function. Eliminate the easy common stuff 1st, then go from there. The fuel is also suspect..try a shot of ether in the airbox, see if it fires......
    #17
  18. bsheet2
    bsheet2 Been here awhile
    Jun 27, 2009
    233
    I have a 2008 KLR. The kick stand safety switch can cause it. Just take the two wires leading to it and wire them together. Also the clutch safety switch can be bad, but seems to be much less frequent than the side stand.
    Did you do the recall on the wiring harness?? There is a spot on the front right down by the voltage regulator where the harness rubs on a bracket. This has shorted out a number of 2008 models.
    Also the tank vent can be a cause if plugged like indicated above.
    #18
  19. Mike Butt
    Mar 6, 2002
    55,634
    Looking west
    I'll give it a try. I did the harness recall the hard way.
    #19
  20. Mike Butt
    Mar 6, 2002
    55,634
    Looking west
    Got it.
    #20
