Drz400 Thread
Discussion in 'Thumpers' started by Britmick, May 4, 2007.
  1. blaster11
    blaster11 Still having fun!
    May 7, 2008
    9,173
    Southern Maryland and West Virginia
    I am starting my Trailtech Vapor install and was wondering how you guys installed the magnetic pickup on your bike, no sense in reinventing the wheel so to speak. Looking for pictures of the sensor down on the wheel.
  2. 4TooMany
    4TooMany Been here awhile
    Aug 23, 2011
    438
    Ann Arbor
    Hey, what "caliber" is your key? Looks like a .45, but the case appears to be stepped. My friend and I are trying to figure it out.
  3. DR650SEDDY
    DR650SEDDY ride2discover
    May 31, 2007
    6,024
    Phoenix,Az
    :lol3 i was trying to figure this out myself last nite :scratch but i got too tired:snore , if anything i'll wait till my neighbour cross the street get back in town he's got the same bike and device. He told me to wait he'll help me out on that. If i only can peak into his bike quickly:hide :D . i'll post up a pix soon as i get it done.
  4. sanjoh
    sanjoh Long timer
    Feb 13, 2007
    9,406
    Here
    Yep, my thoughts exactly.
  5. singletrak
    singletrak Been here awhile
    Oct 27, 2003
    280
    Blaine,MN
    What would you pay for a low mileage (less than 1000 miles), non running 2004 DRZ400s? Probably needs a carb cleaning and a battery. Bike is all stock and has not been run since 2006? $1000 to $1500?
    Singletrak
  6. streetndirt
    streetndirt Been here awhile
    Jan 11, 2013
    149
    Hardin, KY
    I gave $3000 for a 2006 DRZ400s with 400 miles in January 2013. Battery was good but I had to clean the carb. I felt that was a good enough price.
    Sent from Samsung Galaxy S2
  7. Wlfman
    Wlfman Long timer
    Sep 6, 2011
    1,306
    TN
    I paid $2000 for my 04 back in June. Stock except bars. 8600 miles. And it runs fine.
  8. DualSportDad
    DualSportDad Long timer
    May 11, 2007
    2,638
    Cape Coral, Fl.
    I got the pack of o rings from discount auto. The brand was doorman... it was a assorted pack of viton o rings for like $10. Sucks to pay $10 for 1 o ring but I guess I different sizes of I ever need them. If I remember correctly the size needed was 8mmx1.5mm.
    When you try to remove the seat from the carb body be sure to only grab the out side of the seat area. If you even slightly Nick the inside of the seat area the needle assembly will get hung up on it. I found that out the hard way.
    Sent from my Galaxy Note 2 using tapatalk 2
  9. markjenn
    markjenn Long timer
    Nov 9, 2003
    10,728
    Bellingham, WA
    I'd jumper it and make sure it turns over strongly with good compression and no bad noises. Assuming nothing else is wrong, it's easily worth $1500, and probably considerably more.
    - Mark
  10. DR650SEDDY
    May 31, 2007
    6,024
    Phoenix,Az
    I haven't start with it yet but i have an idea of how to install it now, i got this youtube vid it shows u how to install the magnet bolt on wheel the mount wheel sensor to brake caliper.
    http://www.youtube.com/watch?v=K-lpI2-jDxw
  11. Gadget678
    Gadget678 Long timer
    Aug 12, 2010
    2,184
    Victoria, Australia
    Sorry for the delay.... it took me a while to find the pics:
    [​IMG] [​IMG] [​IMG]
  12. Plane Dr
    Plane Dr Long timer
    Sep 29, 2005
    1,247
    North TX Metromess
    I took a small piece of Aluminium. Notched it for a hose clamp. Then made a countersink for the fastener. The hose clamp (band clamp? Runs between the block and the sensor and wraps around the fork.
    This way both sets of wheels have the magnet mounted the same distance from the axle rather than having the location based on the caliper. Which changes with the wheels.
  13. Achtung
    Achtung Wicked Pisssah Adventurer
    Nov 1, 2002
    3,963
    Waltham MA
    That'd be a very fair price and typically your only looking at a carb clean and a battery but I worked on one once that needed a top end after sitting too long. There was corrosion on the piston and the rings were stuck. Not trying to scare you but realize you are taking a risk, albeit at that price not a very big one. Good luck.
  14. buls4evr
    buls4evr No Marks....
    Sep 16, 2009
    2,318
    Michissippi & Nuevo Mexico
  15. Wlfman
    Wlfman Long timer
    Sep 6, 2011
    1,306
    TN
    Anyone have a right passenger peg bracket they don't want? I'm looking for one to cut up for the section the exhaust mounts to.
  16. DualSportDad
    May 11, 2007
    2,638
    Cape Coral, Fl.
  17. DR650SEDDY
    May 31, 2007
    6,024
    Phoenix,Az
    Thanks Gadget, does the magnet goes on one of the allen bolt that hold the rotor ?? (like vid i posted earlier).
  18. blaster11
    May 7, 2008
    9,173
    Thanks Gadget...that's exactly what I needed! No worries on the delay since I got a head cold and don't feel much like working on the bike anyways. :D
  19. Gadget678
    Aug 12, 2010
    2,184
    Victoria, Australia
    Yep. I used the bolt in magnet (replaces a disc rotor bolt)... I didn't trust glue to hold a magnet in place.
    You might notice that I've rounded off the lower - outer edges of the sensor to get it all to fit better and pick up the magnet in my preferred location.
  20. Plane Dr
    Plane Dr Long timer
    Sep 29, 2005
    1,247
    North TX Metromess
    Didn't have a good spot on the other disk. Or couldn't find a "sweet spot" on both. I'm not running conventional SM rims so it was a little more complicated. One less thing as well when I change wheel sets. Just a brake line and spacer. Since I also run KTM guards no fiddling required.
