Auxiliary sidetank project for BMW Xchallenge
Discussion in 'Vendors' started by Max Kool, Nov 9, 2007.
  1. whyldcyde
    whyldcyde Time to pull the Trigger
    Oct 19, 2007
    50
    Great NorthWet
    Hi Erik,
    Thanks for the quick response! Sent a PM.
  2. SCflyer
    SCflyer Long timer
    May 25, 2007
    1,859
    Back in NC
    Erik,
  3. TUCKERS
    TUCKERS the famous james
    Dec 23, 2005
    22,466
    Villa Maria Sanitarium, Claremont, CA. USA
    This looks a lot more functional. For expeditionary preparation one desires a bombproof design. I wouldn't want to ride along wondering if my chain could possible hit, I have other things to wonder about.
    Great job, awesome looking product, natural progression. Have you thought about loosing the other half litre on the bottom and compensating with a tad wider or longer tank?, or just going 6 litre?
  4. MizzouRider
    MizzouRider Long timer Supporter
    Jan 22, 2007
    3,352
    Fly over zone
    Eric, I am going to eventually get the tank.
    Do you have a picture of a pretty much stock XC with the "black" tank?
    I'm thinking I may like the black one better.
    Jeff
  5. Erik RS
    Erik RS Three Wheel Maniac
    Feb 10, 2008
    467
    Cloggyland
    I don't see a reason to do so (and it's a nightmare to have to redo or adapt the press-tooling)
    The recess in the "stock" tank is now 25 mm (1" for those that cannot calculate in real measurements :D). Upgraded from 15 mm just to make sure. It has now a capacity of 7 litres spot-on. This gives ample room for the (normal) sprocket.
    For XCo v2009, and others with lowered shocks, large sprockets a.s.o. we do the one you showed with a recess of 50 mm (abt. 2"). That's 6,5 litres
    For the diehards we sometimes do XL-tanks with an extra strip of aluminium alloy in between the 2 shells up to 10 litres at a surcharge. The disadvantage being that it's less cleanlooking, since the strip of aluminium always wobbels a bit (2mm unprofiled alu welded twice will not stay straight) and there is a double weld. Also I don't like making them toomuch, since there's a lot of extra work involved and they are hard to keep a bit straight and tidy and I don't want to charge toomuch for it :wink:
    Hi Jeff, I know the black also looks good on the white XC (sold several), but I have no pics alas. I've got Max Kool's bike here for a fairing project at the moment. It has a black tank, but the bike's been repainted in a sandy/brownish color. I'll make a pic if you want, but it's not white
  6. Max Kool
    Max Kool Xtankteam™
    Jan 19, 2004
    5,097
    Los Angeles
    Not the best I've ever seen or taken, but hey, better than nothing.
  7. Erik RS
    Feb 10, 2008
    467
    Cloggyland
    Cheers mate :thumb
  8. Erik RS
    Feb 10, 2008
    467
    Cloggyland
    Hi there,
    I've had questions in the past if there 's a lockable tankcap available for our Xtanks. One of our clients finally found one. Of course they can be bought through us, but I think it will be economically more viable if people can buy it in their own country or directly through the www. If you want one, try to source a gas cap for Kawasaki quads KFX700/750 (62 mm thread)
  9. verboten
    verboten confused
    Apr 7, 2014
    1,507
    Phoenix
    bumping an ancient thread.
    I bought an xchallenge with the v1 xtank in december. Last weekend, I managed to contact the tank with the chain on a big hit. It ripped off the plastic tank protectors on the bottom of the tank. What is recommended for a replacement material and bonding it to the tank? In case anyone is wondering, I am running the Ohlins shock, not the stock factory airbag. Also, the factory size rear wheel lightly rubbed the tank as well. Guess I'll have to go a tad narrower.
