Stripped clutch slave bolts
Discussion in 'Dakar champion (950/990)' started by NeilP, Mar 22, 2012.
  1. NeilP
    NeilP Adventurer
    Jul 21, 2010
    90
    Toronto, ON. Canada
  2. Chuckracer
    Chuckracer Jerkus Maximus
    Aug 26, 2007
    12,290
    Dexter, NY
    Yeah, Helicoil.
  3. crazybrit
    crazybrit Defying any self identifying
    Mar 16, 2006
    9,757
    Portland, OR
    Same topic (stripped slave) came up over at ktmtalk last week in the RFS forum, the guys there who are professional engine builders all recommended timesert rather than helicoil for longevity reasons
    You need to be able to drill straight. Obviously this is made easier by the existing hole but i would have thought some kind of guide would help (interested to hear others suggestions). Anyways, I think you should be able to do it yourself.
  4. MP5
    MP5 Been here awhile
    May 23, 2008
    366
    NB, Canada
    I used heli coils on my 09 MXZ 800 Chain Case. The magnesium case had all it's bolt holes suseptable to stripping...and sure enuf mine did when I changed the gear oil.
    I use a helicoil in two of the holes, and it held up just fine for 8000 kms. I can see how those holes can strip easily on the slave. Lots of water and gunk in and around there. Definetely dab some never seize on the new ones.
  5. thugdog
    thugdog Druid Revisionist
    Sep 17, 2004
    396
    +1 for TIME-SERT®
    i like their flange which prevents winding down into repaired hole
  6. Roeligan
    Roeligan Belgium power!!!
    Aug 9, 2005
    639
    Belgium
    I 'helicoiled' them on my ktm as well...
    Make sure you don't drill too deep...
  7. NeilP
    NeilP Adventurer
    Jul 21, 2010
    90
    Toronto, ON. Canada
    Went with the helicoil and it worked out fine.
    Can see how the timesert is a better system, but for some reason a timesert M6 kit in Canada is $210, vs. $60 in the US.
    Helicoil could be had locally
    Thanks for the help
  8. crazybrit
    Mar 16, 2006
    9,757
    Portland, OR
    How easy was it to accurately widen the holes before tapping?
    #8
  9. dog'meat
    dog'meat Presidient
    Sep 4, 2008
    168
    Cromagna
    +100 on TimeSerts... just see them both and you´ll notice the difference right away
    #9
  10. NeilP
    NeilP Adventurer
    Jul 21, 2010
    90
    Toronto, ON. Canada
    Was really easy to widen the holes for the helicoils as the drill bit size was 1/4", not much material was removed.
    Keeping the hand drill level and straight was on my mind, but used a small mirror with a hole in it for the bottom hole which allowed you to see the bit was straight by its reflection..and for the top hole used an L bracket to level it in one plane, and eyeballed for the other. Fingers crossed, but it worked out just fine.
    #10
