Euro Special
Discussion in 'Airheads' started by Ras Thurlo, Mar 21, 2013.
  1. Ras Thurlo
    Ras Thurlo Desert Lion
    Aug 5, 2010
    906
    Hillcountry, Italy
    Another Unholy Union rebuild on a R100GS:
    Donor is a low mileage one owner bike that had been stolen and vandalised by kids. The original owner kept it for years in the hope of rebuilding it, but never got round to doing it.
    TAG aluminium extended monolever, bitches:
    The beast:
    R100GS base engine, Moorespeed 1000cc long skirt pistons+valves and balanced OEM crank.
    I have the Moorespeed pistons on my 100GS city ride and really love them. Waiting to see how the valve changes affect the feel and esp looking forward to trying out a balanced crank.
  2. Ras Thurlo
    Aug 5, 2010
    906
    Hillcountry, Italy
    a dry run:
    WP50mm forks, Trail Tech Rally light, TAG kevlar tank
    I hope some of you pick up on the Samcro look
    Check out my neighbour
  3. Rob Farmer
    Rob Farmer Long timer
    Aug 27, 2002
    7,500
    Vale of Belvoir - Nottinghamshire
    The engine turned then up on time then Ras? Looks great. cant wait to hear how well it goes.
    Jota as well. Very nice.
  4. Prutser
    Prutser Long timer
    Aug 5, 2012
    2,073
    The Dutch swamp
    Those are what you call ROX RISERS :evil
    Looking forward to a new bike build. I sure like the TAG gadgets.
  5. Chad M
    Chad M 14880
    Jan 11, 2006
    2,300
    N53.5
    :photog
  6. GESII
    GESII Gerry with a G
    May 31, 2005
    128
    Between nowhere and somewhere - Hyndman, PA
    I want one of those TAG aluminum monolever swingarms bad!
  7. hardwaregrrl
    hardwaregrrl Can't shoot straight Supporter
    Jan 26, 2006
    10,219
    Atlanta
    Neato!!!:thumb
    A buell fairing on a G/S???? RAd!!!!!!!
    Looking forward to your progress:lurk
  8. bgoodsoil
    bgoodsoil Dare to be Stupid
    Jul 9, 2008
    4,724
    Washington, DC, USA
    does TAG have a website? I can't find anything on them.
    Also, are those swingarms currently available?
    #8
  9. hardwaregrrl
    Jan 26, 2006
    10,219
    Atlanta
    TAG
    #9
  10. Ras Thurlo
    Aug 5, 2010
    906
    Hillcountry, Italy
    Mainframe strengthened by TAG, with a 2 degree change in rake and engine mounting moved forward.
    Using stock KTM triple clamps that came off a '98 300exc. The offset is negligible, but wanted to try this out for now. Given that I have a steeper rake angle, I wanted to play it safe on the offset, until I got a feel for the bike.
    Chopped GS subframe, cut just behind the rear pannier rack mounting point. I prefer the look of the G/S subframe (as in earlier dry run picture), but I have seat and pannier racks that will fit onto a paralever frame, so wanted to minimize brain damage for now.
    I hear that there is a risk that the greater suspension travel of an extended monolever could cause the wheel to hit the mudguard on the longer paralever subframe. Am going for a smaller mudguard, so lets see.
    #10
  11. Ras Thurlo
    Aug 5, 2010
    906
    Hillcountry, Italy
    Horror shots from a fleabay set of WP50s
    Paid 60 Euro for them, so did not mind the complete overhaul
    and then there's the XXX shot:
    #11
  12. hardwaregrrl
    Jan 26, 2006
    10,219
    Atlanta
    Good lord those suckers are filthy!!!:eek1
    #12
  13. Airhead Wrangler
    Airhead Wrangler Long timer Supporter
    Mar 4, 2008
    7,275
    Back in Seattle, FINALLY
    Oooh, I was waiting for this thread to happen. :clap :ear
    #13
  14. Ras Thurlo
    Aug 5, 2010
    906
    Hillcountry, Italy
    In order to calibrate the required rim offset, I put on some 140 Michelin Deserts, as this is the widest tyre that I will be using.
    After quite a while setting up the offset, still have a problem with clearance:
    man, this job has a terrible work to results ratio. Packed it in after I could see at least 1mm of clearance:
    #14
  15. Ras Thurlo
    Aug 5, 2010
    906
    Hillcountry, Italy
    450w alternator kit
    have also gone for the Moorespeed programable ignition as an alternative to double plugging. As I assume the high compression pistons would not be as happy as I am to be riding in mamma hafrica
    #15
  16. Clay Spinner
    Clay Spinner Been here awhile
    Nov 6, 2008
    771
    Nova Scotia
    More....more..:clap
    #16
  17. DK Dan
    DK Dan Been here awhile
    Jan 14, 2013
    532
    Europe (DK)
    Yes please :lurk
    #17
  18. Rapid Dog
    Rapid Dog bikes, booze, broads...
    Oct 28, 2003
    10,464
    Strangel Living West of Hell, SoCal
    woot
    #18
  19. Ras Thurlo
    Aug 5, 2010
    906
    Hillcountry, Italy
    Front wheel is a 21x 1.6 Excel rim with Talon Hub.
    Sanity check that the new Hub is the same as the original KTM, by placing OEM disk onto mounting points:
    Have a problem with the spindle tube (whatever its formal name is).
    Top tube is correct width, but unfortunately 20mm internal diameter. Lower tube is correct 17mm diameter, but wrong width. Awaiting replacement from helpful guys at Talon:
    #19
  20. Ras Thurlo
    Aug 5, 2010
    906
    Hillcountry, Italy
    Front:
    320mm disk, HE relocation bracket, Brembo calliper all courtesy of Boxer Toko:
    Rear:
    Inverted rear lever
    #20
