Low Beams Question
Discussion in 'GS Boxers' started by ckinneavy, Aug 22, 2011.
  1. ckinneavy
    ckinneavy Adventurer
    Sep 19, 2009
    55
    Seacoast NH
    I have gone through 2 low beam bulbs in the 12000 miles I have had my 09 gs the first lasted about 8000 miles and the second just went on the way to work this morning I was just wondering if this is normal or should I be worried
  2. JimVonBaden
    JimVonBaden "Cool" Aid!
    Feb 11, 2005
    101,516
    Alexandria, VA
    Normal. Look around, on this very page is a thread about it. Also, check out the G-Spot FAQ at the top of the page.
    Jim :brow
  3. AZuwere
    AZuwere Been here awhile
    Jan 9, 2006
    383
    Gilbert, AZ
    Ckinneavy, if you ever find the mystery links could you share them here? You got me curious about this issue but after burning a half hour in the FAQ's, I give up.
  4. RED CAT
    RED CAT Bumpy Backroader
    Jun 2, 2005
    3,757
    Western Canada
    Your bulbs anywhere but the Beamer Dealer. Got mine at Canadian Tire and this last one has over 30,000 miles on it and is constantly on.
  5. opposedcyljunkie
    opposedcyljunkie Heavyweight Boxer
    Feb 20, 2007
    4,899
    By the Lake
    I must be lucky. Mine's at 30K miles and is still the original bulb.
  6. ckinneavy
    Sep 19, 2009
    55
    Seacoast NH
    Ok guys thanks i decided to try the 9 dollar napa special see how long in lasts
  7. BeachMoto
    BeachMoto Been here awhile Supporter
    May 30, 2008
    987
    Va. Beach
    I go through a low beam bulb every 9-10K miles. I have been buying two packs of [FONT=arial, helvetica] Philips Xtreme Power from Costco for around $25. They are cheap enough and it takes 5 minutes to swap one out. One of these days will take the leap and go with HIDs.
    [/FONT]
  8. opposedcyljunkie
    Feb 20, 2007
    4,899
    By the Lake
    I just love the slightly-yellowish Osram All-Season bulbs :deal
    But the high beam stays as stock (white).
    #8
  9. hojo in sc
    hojo in sc Long timer
    Oct 4, 2007
    1,232
    I got 9-10,000 miles and finally put HID in low beams.
    #9
  10. Chat Lunatique
    Chat Lunatique aka El Gato Loco
    May 9, 2011
    1,476
    Niagara, Canada
    Got a Crappy Tire part number handy pardner? I'd like to throw one in the luggage for an on the road spare. Thanks!
    #10
  11. bemiiten
    bemiiten League of Adventures
    Jul 10, 2003
    5,860
    Hamilton NJ.
    Not normal unless you have a BMW R1200GS. Hopefully BMW will address this in the next model.
    #11
  12. JimVonBaden
    Feb 11, 2005
    101,516
    Alexandria, VA
    It is not a BMW issue, except for the choice of the H7 bulb. Every vehicle I have had that has the H7 has a similar burn out rate. My Hyundai Elantra went through 6 bulbs in 3 years. It was so bad that Hyundai extended the warranty for the bulbs to 5 years.
    Jim :brow
    #12
  13. Brit in SF
    Brit in SF Been here awhile
    Aug 23, 2010
    230
    SF
    My guess it is grease from your fingers. If you are buying your bulbs at different times/places it probably rules out at bad batch. Use a paper towel to hold the bulb as you put it in.
    #13
  14. opposedcyljunkie
    Feb 20, 2007
    4,899
    By the Lake
    But the bulb is inserted by holding it's metal base. I don't see how one can easily touch the bulb itself.
    #14
  15. def
    def Ginger th wonder dog
    Feb 28, 2004
    14,308
    The woods and mountains of Alabama
    A clean bulb is necessary when you change. Finger oils will cause cracks and failures once the bulb heats up, and they get very hot...the filament is boiling electrons off the surface and there is lots of infrared emitted from an incandescent.
    Wash the lamp capsule with alcohol before you instal it and handle it with a paper towel or clean rag...or, instal an HID and never change lamps again.
    #15
