pivot pegz mk3 dimensions?
Discussion in 'Equipment' started by The Letter J, Sep 8, 2012.
  1. The Letter J
    The Letter J Long timer
    Aug 17, 2010
    2,136
    Santa Maria, CA
    Does anyone know the dimensions of the actual platform of the pivot pegz mk3? All I can find is "60mm" but that is from front to back, I'd like to know what they measure from left to right.
  2. Jamm
    Jamm Old man on 2 wheels
    Oct 17, 2010
    319
    The foot pad is 3-1/4" (L-R). If you look at a pic it is 2-1/2" from the outer edge of the peg to the main bar then the outsde bar extends another 3/4". At least that is what mine are for a F800gs.
  3. The Letter J
    Aug 17, 2010
    2,136
    Santa Maria, CA
    Very cool, thank you. It appears that the platforms are the same for any make/model, just the spindle/frame side of the pegs vary. I also emailed a friend who just installed a set and he said that his measure 3.75" from the center of the pivot pin (the one on the bike) to the outside edge of the peg. This is the same measurement as the oem KTM, Husky, and fastway pegs that I have in my garage. I'm still trying to decide if I want to spend this much money on them just to end up welding on extensions to get them to ~5" as measured from the pivot pin :hmmmmmto compensate for my crooked knees! Too bad nobody makes extensions for the mk3's like cjdesigns did for the mk2's:cry
  4. DustyWheels
    DustyWheels Nomadic motorcyle traveller
    May 15, 2007
    1,140
    Lake Macquaire, NSW, Australia
    I ended up making extensions for mine
    Jettn Jim likes this.
  5. The Letter J
    Aug 17, 2010
    2,136
    Santa Maria, CA
    That is pretty much what I had in mind! I made several sets for my other bikes out of mild steel and then welded them straight to the peg, the stainless steel will surely be more difficult so I'll have to bribe a friend to weld them for me (or bolt them on like you did, looks good by the way.) The real problem is that I no longer have free access to a CNC plasma cutter so making the teeth on the extensions uniform will be an interesting task.
  6. DustyWheels
    May 15, 2007
    1,140
    No plasma here either, 32 6mm holes an angle grinder, big flat file and lots of patience is all you need :D
  7. Johnnyktm
    Johnnyktm Been here awhile
    Nov 15, 2012
    120
    Spain
    I have got some pivotpegz for my 2012 ktm 500 exc, and I was thinking about welding an extension, and I took that pegs to my friends at the welding shop to inquire about it.. They had a look at the pivotpegz, and in a second told me:
    "are you sure thay are stainless steel?"
    I replied: Well, the manufacturer says:
    So I guess that they are stainless steel...
    My friend then searched for a magnet, and he approached it to the pegs, and I thought "the magnet will not stick"... well, I was wrong: It attached itself to the peg like crazy!!! :huh
    He then reached for some scrap stainless steel that he had on hand, and the magnet completely ignored the metal, as it should be. After this deception, what the manufacturer says:
    Is not as clear to me... :eek1
    I let you all know just in case you decide to weld an extension to the pivotpegz. It seems that the extension should be plain steel, instead of stainless steel :evil
  8. The Letter J
    Aug 17, 2010
    2,136
    Santa Maria, CA
    if it is 400 series (without nickel) it could be magnetic. I've also seen some SS varieties "become" magnetic when they are heated and then return to their non-magnetic state after cooling. I'm no metallurgist so take my info with a grain of salt.
    #8
  9. Johnnyktm
    Nov 15, 2012
    120
    Spain
    Thank you very much for the info! I had no idea about that, and Iwill take it into account when I enlarge the pegs. I still am debating if welding or bolting the extensions ;-)
    I will keep you posted :-)
    #9
  10. cjracer
    cjracer AWD please!!
    Sep 26, 2005
    4,312
    Mukwonago, WI
    MK3 version extension due summer 2013
    #10
  11. Johnnyktm
    Nov 15, 2012
    120
    Spain
    Thanks for the update! I'll try to fabricate mines, but for those that prefer to buy ready made extensions, it's great news! :norton
    #11
  12. Johnnyktm
    Nov 15, 2012
    120
    Spain
    Well I finally had time to enlarge the pegs, and after getting my inspiration from MudratinOz's pictures (thanks!! :clap):
    I asked a friend of mine that laser cuts metal to cut some extensions, and this is how it turned out:
    I have used the new pegs for about 1000 kms, and the extensions keep my ankles and knees straight when standing rather than bowed out from not enough contact area with my boot, and I can stand for long periods without any problem. After 30+ years of dirt bikes, I do not understand how I did not do something like that before... :clap
    I still have not crashed with them, so I do not know how will they endure it... I'll keep you posted! :D
    #12
  13. DustyWheels
    May 15, 2007
    1,140
    very nice :clap
    #13
  14. sdd04
    sdd04 Long timer
    Mar 5, 2012
    1,949
    The Ozarks....SW MO, NW AR-great place to play!
    Look great!
    How wide are they now (inside to outside)?
    #14
  15. Johnnyktm
    Nov 15, 2012
    120
    Spain
    Thanks! :thumb
    The new pegs measure 130mm from pivot centre to tip, and they have a width of 66mm (the stainless steel strips are 3mm thick + 60mm of pivot pegz = 66mm) :D
    #15
