the DR650 thread
Discussion in 'Thumpers' started by sleepywombat, May 1, 2006.
  1. ER70S-2
    ER70S-2 Long timer
    Sep 30, 2009
    17,156
    SE Denver-ish
    Imma need to rethink my retirement plans. :vardy
    Cave Creek, Arizona, March 3rd. :D
  2. villageidiot
    villageidiot Long timer Supporter
    Apr 29, 2010
    20,243
    Orange County, CA
    back to the shop after work, which is also a shop, but a different shop. yeah
    got the Oatey plug to fit, turns out it wasn't the rubber that was too big it was the inner plastic piece, a quick lap around the plastic on the disc sander remedied that.
    so then i tested the Oatey plug, works great, looks poopy
    then put my 1/4" plate from the one i made the other day and got rid of the red outer Oatey plug, and it looks good.
    i then made a flat "wing nut" out of some flat aluminum bar, trying to see what looks right.
    i think i like the flat bar, but it needs a little refinement, ill try another rendition on the mill tomorrow, as i was busy making parts to fill another order.
    i took the tube home and installed on the bike, with the regular wing nut.
    i think I'm pretty satisfied. i still need to drill and safety cable the stud for the wing nut, but other than maybe the wing nut itself, this is a pretty done project.
    i figure i can sell it with the plug and cap and everything ready to bolt on, for $90. if anyone's interested, I'm ready to make the next batch of 5.
  3. Molonlabemike
    Molonlabemike Been here awhile
    Apr 11, 2013
    799
    Los Angeles
    Looking at 3 on my coffee table as I type :rofl
  4. Chill
    Chill Been here awhile
    Aug 30, 2012
    359
    QLD Australia
    Good advice. :thumb
  5. Molonlabemike
    Apr 11, 2013
    799
    Los Angeles
    Ok need some help guys. I was working on the bike and I noticed that my front sprocket has a little side to side play. Its not a whole lot maybe 1mm or so but I am not sure if thats normal. Running a 14T sprocket and the procycle retainer.
  6. ADV8
    ADV8 Long timer
    Nov 10, 2007
    2,767
    North of Sydney.
    That wobble is normal.
    The retainer plate is simply holding the sprocket inline for the most part
    Of course the sprockets spline needs to be a reasonable fit on the matching output shaft spline.
  7. ER70S-2
    ER70S-2 Long timer
    Sep 30, 2009
    17,156
    SE Denver-ish
    Yer good. :nod I hate my CSS being loose, but that seems to be the best Zuki engineers could do. (and it seems to work :nod)
  8. Molonlabemike
    Apr 11, 2013
    799
    Los Angeles
    Ok thanks guys, I wanted to make sure everything was GTG. Don't need to bust an output shaft for a correctable mistake (should that have been the case)
  9. bdesj
    bdesj Long timer
    Jan 2, 2011
    1,095
    Reno, NV
    Exterior cap = minimum interior space.
    I think this one cost me about $6 from my local hardware store.
  10. frogandtoad
    frogandtoad Long timer
    Sep 5, 2014
    2,058
    Lake Lure, NC
    You should see the CSS on xr650l:eek1
  11. plugeye
    plugeye MC rescue
    May 11, 2007
    8,020
    Garland, Texas USA
    pm me and i'll check for one tonight
  12. PHILinFRANCE
    PHILinFRANCE Long timer
    Aug 8, 2010
    1,745
    S W France my little bit of paradise
    OK guys , i've been toying with getting a TM40 but to be honest the Donk runs fine , little bit of cougthing and farting at low speed and roll off but nothing i can't handle , and mainly ride at 270m (890ft)home to 2000m (6500ft) Pyrenees
    So .... would getting this kit help any
    ProCycle Jet Kit for the Stock Carburetor
    This said she carried me with no hassel at over 3000m in the high Atlas
  13. thump!
    thump! Adventurer
    Jan 16, 2007
    5,307
    Northeast Tennessee
    I assume your bike already has the adjustable jet needle (European standard). Before installing the after market jet kit (which will likely dramatically affect your fuel consumption) I'd suggest you experiment with the clip position on the needle and idle mixture screw.
  14. Rusty Rocket
    Rusty Rocket Life behind "Bars"
    Dec 22, 2005
    20,445
    Tri- Cities TN
    I've gotta get outta my spot too. 33 degrees this morning, but 2" of slush that weighs about 50lbs per shovel full. Temps are gonna drop this afternoon and it will turn to concrete. 5 degrees forecast for Fri mon, after "plowable" snow Thursday... F***ng groundhog!!
  15. adam728
    adam728 Long timer
    Dec 1, 2014
    2,653
    Michigan
    Yea, got home this morning to wet havy snow. -4 F tonight, so I have to get everything cleaned up today. Plow truck is warming up....
  16. kumatae
    kumatae Been here awhile
    Feb 10, 2014
    532
    Orange County
  17. cyberdos
    cyberdos Easy Bonus Loop ♦♦
    Sep 2, 2005
    49,239
    Queen Creek, AZ
  18. cyberdos
    Sep 2, 2005
    49,239
    Queen Creek, AZ
    :augie
  19. PHILinFRANCE
    Aug 8, 2010
    1,745
    Cheers Thump :freaky
  20. procycle
    procycle ~Retired~
    Jun 7, 2007
    11,527
    It ain't New and it ain't Mexico
    Not if it is dialed in properly :thumb
