Ktm 525 To 520
Discussion in 'Thumpers' started by endurists, Feb 20, 2010.
  1. endurists
    endurists Been here awhile
    Feb 28, 2008
    126
    Talsi, Latvia
    Hello!
    Is KTM 525 EXC exhaust pipe interchangable to 520 double pipe? Are the heads similar 520 and 525 @ exhaust side?
  2. CodyY
    CodyY ADVenture Capitalist
    Jun 19, 2006
    9,765
    Fort Worth, TX
    Yes. 520/525 have no engine differences. just a model designation
  3. Crit Rat
    Crit Rat Been here awhile
    May 26, 2008
    241
    Arvada, CO
    It will work but you will need to use the whole 520 system. I'm pretty sure there is a difference in how the midpipe fits to the can between the two systems.
    FYI - I've heard the dual header setup of the early RFS bikes promoted better low end torque and also better mid-range. Top end is better on the later single pipe styles.
  4. GR0NK
    GR0NK Got some screws loose!
    Sep 24, 2006
    10,118
    Stuck in 80s
    The dual-pipe exhaust just runs better all around but the single pipe breathes better on top. On a 525 you wouldn't really notice it much.
    Sean :bmwrider
  5. riverside
    riverside Been here awhile
    Jun 4, 2007
    131
    Yep like they all said. I have done the swap and if I recall the head pipe mount on the cylinder is different between the two. Also the tab above the foot peg is in a different place. I ended up cutting the tab out and letting the newer single head pipe version float when being used on an '02 frame. It wasn't right but never caused me problems at all. I did too many mods at once to give my personal seat of the pants opinion. My stuff had compression increase and small port work at the same time. I sure can say that otherwise stock RFS motor sure ran good!
    Michael
  6. endurists
    Feb 28, 2008
    126
    Talsi, Latvia
    Thanks You all!
    Could You explain more about "small port work" and will there be really noticable benefits if I will do theese changes? 1. Dual exhaust from 520 and 2. "small ports"
