XR650R owners.
Discussion in 'Australia' started by jack82, Mar 12, 2009.
  1. Cruz
    Cruz Lost but laughing.
    Nov 3, 2008
    19,682
    Northside Brisbane, Qld Australia
    Still wet and slippery here and there?
  2. digga1111
    digga1111 bann ed
    Oct 15, 2009
    4,343
    wynnum
    little bit biased I know, but they are still a good lookin dirt bike.
    do you like it?
  3. DRjoe
    DRjoe Long timer
    Sep 6, 2007
    7,483
    Sunshine coast qld
    Well done doug very nice job mate.
    What's next?
    And yea digga there not a bad looking motorcycle.
  4. Fogo72
    Fogo72 I Bleed Green
    Oct 6, 2009
    1,581
    NSW
    If I was done and dusted on the KLX's I would be all over one of these.:evil
  5. Sean-0
    Sean-0 straya carnt
    Oct 19, 2010
    4,934
    Mumblebum Northern NSW
    fogo time to upgrade mate :evil
    looks good doug ....thanks for the lil test ride today ...it goes well
  6. poppy
    poppy Slow and Steady
    Mar 8, 2006
    3,709
    G.C QLD
    Thanks all, its been a bit of a project thats for sure. One of those jobs were you just keep replacing things until just about everything is new. Still got a way's to go, but at least i can ride it while i get the rest sorted.
    Got to take it for a ride today. Had a fun few hours out and about getting to know it and only lost 3 things:lol3. Lost the 2 speedo nuts and the rear brake pad pin cover screw. So not to bad, no oil leaks, no water leaks and it still goes, whoo hooo.
    1st light of day since i bought it home
    Heading up toward Mt Tamborine. Plenty of whoa boy's on this track to test the suspension.
    Up at the lookout on Mt Tamborine
    Nice place here. There were a couple of people just about to load some canoes into the water for a paddle.
    Found some long grass to play in
    Back at home, most things in tack
  7. Cruz
    Nov 3, 2008
    19,682
    So, compared to your Husky, how is it Poppy? :ear
  8. poppy
    Mar 8, 2006
    3,709
    G.C QLD
    G'day Bruce, different bike to ride. Feels bigger than the 610, it feels like it has more torque and power than the husky, which it should, i need to have a play with the carb still. The brakes have less feel to them than the husky, but that is probably more personal and just need time to adjust. Ha, and get this, no magic button, not sure on this yet.
  9. Sean-0
    Sean-0 straya carnt
    Oct 19, 2010
    4,934
    Looking for a rad guard for the right hand rad ... mine fell off :huh
  10. ditchwitch650
    ditchwitch650 Long timer
    Mar 10, 2008
    1,088
    does it still have the rubber front brake line mate? they need to be upgraded to braided to get any real power to the caliper, from memory that bike already had a 280mm oversize ebc rotor, they don't stop any better till the line is upgraded :evil
    jetting
    68S pilot S is for small hole, I think they are Honda genuine only.
    170main
    2 turns out on the air screw then fine tune,
    stock needle on 3rd clip down (middle clip)
    trim the float level up (less fuel) about 2 or 3mm from spec
  11. poppy
    Mar 8, 2006
    3,709
    G.C QLD
    G'day Ditchy, yeah mate it has the 280 rotor and rubber Michirin hose on it, which i would assume as standard. I will have a look into the braided line for sure. Dont see there is much to be gained from just adding the large rotor apart form surface area, caliper can still only apply so much pressure.
    Thanks for the tips on the carb, no idea how it is set up, just as it was when i bought the bike, so will pull it apart and have a play.
  12. ditchwitch650
    Mar 10, 2008
    1,088
    shame lostsaffa just sold a good 2nd hand goodridge braided line a few weeks ago,
    You can get Goodridge brake lines in several color options from most bike shop they are supplied by John Stamos I think it is,
    I have had 1 made at Enzed before, the braided lines from USA will fit but aren't quite right and end up having a half twist in them as they run A different master cylinder crf style
    grab the rubber line as you squeeze the lever you will most likely feel it bulge as it pressures up
  13. Cruz
    Nov 3, 2008
    19,682
    You can get Hela braided lines off of their website and they are local around Redcliffe or Scarborough some where. Good price too, fitted one to the Transalp.
  14. slickwill
    slickwill Exhiled
    Dec 31, 2011
    209
    Ohio
    I run a Goodrich on mine. I've had a few brands of SS lines over the years and I really like the build quality of the Goodrich.
    Sent from my DROIDX using Tapatalk 2
  15. MymoJoe
    MymoJoe Ride Ride Ride
    Sep 30, 2005
    3,515
    Fernvale QLD not close enough to the desert
    http://helperformance.com.au/
    Yeah I second that Cruz. I have bought several lines from HEL. Grat to deal with Brisbane based. He has made custom brake lines when I needed extra length, also made a clutch line for a KTM for half the price of an OEM one.
    Joe
  16. Leydos
    Leydos 2 Stroke
    May 2, 2012
    13
    Brisbane QLD AU
    My 04 XR650 has 12000km on the clock and is making an intermittent metallic clicking noise, anyone else had this problem? From internet searches it seems it could be worn cam chain guides, should I just replace the guides or the entire cam shaft drive components?<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:eek:ffice:eek:ffice" /><o:p></o:p>
  17. digga1111
    digga1111 bann ed
    Oct 15, 2009
    4,343
    wynnum
    sounds pretty open ended to me mate, fair bit involved replacing all the timing components. better to try and isolate the noise first.
    is the manual decomp adjusted properly. if it is not disengaing fully it will make a tick clickety tick noise
  18. Leydos
    Leydos 2 Stroke
    May 2, 2012
    13
    Brisbane QLD AU
    Thanks Digga I have had a bit of a look around, disconnected the decomp cable and checked valves etc. It is no way rhythmic like a two to three clicks with half a second gap then quiet for a few seconds then will click again for a few times, very erratic. It does go away when the engine is revved past a certain point. Is there a way to check cam chain wear without taking the top end apart?<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:eek:ffice:eek:ffice" /><o:p></o:p>
  19. digga1111
    digga1111 bann ed
    Oct 15, 2009
    4,343
    wynnum
    maybe the timing chain adjuster is stuck or binding.
  20. ditchwitch650
    Mar 10, 2008
    1,088
    I remove the cam chain adjuster to let it fully extend then push it back in the hole it should stop before the face of the adjuster meets the barrel
