The Complete KLX250/KLX300 Long Term Review Thread
Discussion in 'Thumpers' started by bmwhd, Dec 2, 2005.
  1. sdunne
    sdunne Adventurer
    Feb 6, 2006
    51
    FT. Bragg Nc.
    And again! With a small whip in there.
  2. kyjelly44
    kyjelly44 Adventurer
    Mar 2, 2006
    26
    randy i looked up the seller histori and he payed $117 for the tank so that might be the rez on it.im not going to bid on it ,dont realy need a larger tank(as of yet)
  3. navyman
    navyman Adventurer
    Feb 12, 2006
    65
    Headed to Bremerton, WA
    $117 would be a steal if its new. Maybe green would be ok... :patch
  4. Nobiman
    Nobiman Orange... the color of insanity.
    Apr 20, 2005
    734
    La la land... republik of Kalifornia.
    Yea, I'll probably add a little more to it but not enough to get it to $120. I'm not sure I wanna mess with all of the things that you need to do to get it to fit right. I guess I should go back and read Todd's install instructions, maybe that will help me make up my mind how much its worth to me. We're going on a planned Dualsport ride on the 29th up to Arkansas to ride the Ozarks for 4 days, it would sure come in handy for rides like that.
    Randy.
  5. Nobiman
    Apr 20, 2005
    734
    sdunne, nice height on that table top dude!:clap :eek1
  6. nobrakes
    nobrakes Long timer
    Jan 19, 2006
    3,369
    North Carolina
    I just completed my valve clearence check today - both inlet and exhaust valves are still in spec. I could have sworn this was to be checked on the 600 mile mark on the maintenance schedule, but the first check is not until 7500 miles. Oh well, it really wasn't that bad and now I know what to do when it comes up again.
    Anyway, now that I have my bike all apart, the tank off, the radiator fan off, and the coil off, do you mind to post a close-up of your coil mount job? I have my IMS tank on order and expect it soon. I'd like to go ahead and do the coil remount now while I have everything off which will save me a little time once the tank comes in. But without having the tank here to test fit, I'd like to see a photo of yours if possible so I don't do it wrong and have to redo it later.
    On an unrelated note, I had to remove the exhaust air tubing stuff in order to get the cylinder head off. I know you have recommended to just leave that off and cap the holes which will lower the head pipe temperature. I'm all for that. Where do you get those caps to close off the engine and airbox fittings?
  7. motoguy128
    motoguy128 Adventurer
    Feb 11, 2006
    44
    Are you sure about the valve check at 600? I was sure that it was supposed to be checked. I just dropped my bike off at the dealer to have it done. I have ot remind them NOT ot change my oil since I did that myself already. Probably not bad to do anyway since I had my engine temp light come on several times while digging my way out of a mud pitt.
    For the caps, I used a threaded brass plug from a hardware store used for capping off threaded pipe along with some red RTV high temp sealant. That was for the reed valve on the enigine. For the plug on the airbox, I just filled a peice of the tubing with some regular clear RTV silicone. On teh carbs, I found a bolt that was the right size and used that with red RTV to seal it. Not the prettiest solution, but simple.
  8. rkutzner
    rkutzner Adventurer
    Mar 3, 2006
    14
    Nice height ! I used to get that kinda height on my Z400....not sure I'm ready to hit that kinda height until I get more time on her !
  9. nobrakes
    nobrakes Long timer
    Jan 19, 2006
    3,369
    North Carolina
    I thought for sure they needed checked at 600 which is why I did it. I know I read or heard that somewhere, but now can't recall where. My bike is actually at 800 miles so I've been taking it easy lately, not riding as much as I normally would because I thought I was overdue. But the Owner's Manual clearly does not show a check mark beside the 600 mile interval for a valve clearance check. The first check is at 7500 miles. Maybe my dealer told me that to try and get more money out of me. No worries, though. Checking the clearences is pretty easy. Adjusting the clearences is another matter and involves a lot more work including removing and re-installing the cam shafts which requires care when re-installing to make sure they are timed correctly. I'm working from a KLX250R service manual, which I'm assuming is similar to our bikes in this regard. Everything looked the same inside the engine, at least. I have a KLX250S manual on order and I'll verify the work then.
    Thanks for the tip on the brass plugs. Nobiman had some real nice looking caps - wonder where he got those? Randy?
    -Brian
  10. Nobiman
    Apr 20, 2005
    734
    Here ya go! You can pick these up at any major auto parts stores. I've done two de-smogs with this kit and still have all of these left over.
    Randy.
  11. bmwhd
    bmwhd God Bless Texas
    Dec 15, 2003
    1,476
    Texas
    On the coil: I don't know if I can get a photo without taking the tank off but I'll see about that tonight. You may not have to move yours, as it was a near thing on mine. But if you do, think of it like this: the coil is attached to the frame via square posts that extend from either end. You want these posts positioned on top of the frame brackets instead of in front of them. An easy way to do this is to use the existing holes (on the front) to anchor a small piece of strap steel and then bolt the coil studs to this from behind as they sit on top of the bracket. It'll make sense when you look at it.
    For the air injection, I just picked up an assortment of rubber caps from Lowes. I think the airbox hole is 1/2" and the carb vacuum port is 1/4". I used a plastic hose plug and some high temp ATV to plug the hose (cut off to 1/2" in length) on the front of the head.
  12. Nobiman
    Apr 20, 2005
    734
    Ok, someone tell me where they got thier 13 tooth CS sprocket from for the little KLX. I've got the part #'s from Todd's post #388 but my usual parts sources dont list any of these manufacture's or part #'s in thier data bases.
    Help a brutha out here with a link or two wud'ya?:wink:
    Randy.
  13. bmwhd
    Dec 15, 2003
    1,476
    Texas
    AFAMUSA.com, their part number is 24502 which is listed as fitting the '88-'94 Kawasaki EL250.
  14. nobrakes
    nobrakes Long timer
    Jan 19, 2006
    3,369
    North Carolina
    Don't go to the trouble of removing the tank - you've done so much already for which I am very grateful. I'll get my tank soon enough. I thought if you already had a photo of it from when you had it apart you could share it. But if that's not the case, don't worry about it. The weather is pretty crappy here for the next few days so I'm not in any great rush to get it back together.
  15. Nobiman
    Apr 20, 2005
    734
    Thank you sir! Its on the way.
    Randy.
  16. nobrakes
    nobrakes Long timer
    Jan 19, 2006
    3,369
    North Carolina
    I found that exact thing at a local Autozone and fixed me right up. Thank you sir!
    -Brian
  17. Nobiman
    Apr 20, 2005
    734
    Ain't this internet thing fantabulous? :clap Bruda's help'in bruda's out everywhere!
    :lol3
    Randy.
  18. Bill & Jo Ann Blue
    Bill & Jo Ann Blue Adventurer
    Nov 20, 2005
    31
    Wichita, Kansas
    The proper part number for the 13-tooth countershaft sprocket is Sprocket Specialists #514XK-13. This is on the wife's bike at this time - fits perfect!:clap
    Bill & Jo Ann Blue
  19. Nobiman
    Apr 20, 2005
    734
    Thanks B&J, any new fancy work done on the bikes lately to show us ?
  20. klxandy
    klxandy n00b
    Mar 20, 2006
    9
    Hi
    I have been readin all this great info on the KLX250 and decided to purchase the KLX300 big bore "kit" using the parts list which was mentioned in earlier posts. I have done the KLX300 dynojet kit, KLX300 exhaust, KLX300 tank, added computer fan, renthal fatbars...SO I am wondering what problems I may run into in doing this 300 upgrade. Any experts on this? I am buying the service manual and am doing all the work myself. I have a good selection of tools, and a clean workshop to do the work in. My bike is a Canadian version of the KLX250S. Any ideas you may have would be appreciated, especially if someone from North America has already done this! Thanks for your great site!
