2007 R1200S Brake Bleed "Non-Servo"
Discussion in 'Road Warriors' started by CHOPPASTYLE, Jul 24, 2014.
  1. CHOPPASTYLE
    CHOPPASTYLE Been here awhile
    May 20, 2009
    303
    San Antonio, TX (Heart of the Hill Country!)
    Hi I have a 2007 R12S now. It does have ABS but not Servo. Can I bleed the brakes like normal without the bleeder funnel (which i have). Or is there some other special way to do this?
    Also, I'm going to lube my splines and flush the final drive. any tips on how to do this without a center stand?
    I doing the service with my Trusty Jim Von Boden JVB maintenance CD i bought for my GS back in the day.
    Thank you,
    Choppastyle
  2. Mike Figielski
    Mike Figielski Been here awhile
    Jul 26, 2003
    630
    Asheville, NC
    No funnel needed, just normal old school bleeding. You could use a jack under the engine/trans to lift the rear for spline lube/final servicing, etc.
    Mike
  3. CHOPPASTYLE
    May 20, 2009
    303
    Thanks Mike. I'm going to get cracking today. I'm at the point where I can do the..........:
    final drive oil
    transmission oil
    engine oil
    brake bleed
    belt
    air filter
    spark plugs
    valve adjustment
    ..........in a few hours. Can't believe I paid over $800 at one point in time to BMW when I can do it myself for less than $150 same day.
    Choppastyle
  4. JimVonBaden
    JimVonBaden "Cool" Aid!
    Feb 11, 2005
    101,516
    Alexandria, VA
