'91 GSPD problem
Discussion in 'Old's Cool' started by rob, Jul 23, 2006.
  1. rob
    rob Been here awhile Supporter
    Jun 24, 2002
    582
    Arma, KS, USA
    was riding the '91 GSPD today. The bike has 78,300 miles and a recent tune up ~2,000 miles ago. It has a Stayntune (sp?) muffler with 7 disks. The weather was clear and in the mid 80's. It was running great until I got to some stop lights.
    As I was waiting to proceed I noticed the idle was in the 2000 rpm area. I checked the trottle cables in the carbs and they seemed to be in place. The next grouping of lights, the idle started at 2000 and creeped up to 3000.
    I hightailed it home and started to look. No luck, everything seems in place.
    Any idea's where to look? What to do?
    Thanks in advance.
    Rob Lessen
    '73 XL250
    '91 R100GSPD
    '95 R11RS
    '05 R12RT
  2. jtwind
    jtwind Wisconsin Airhead
    Nov 19, 2004
    3,501
    Madison WI
    One cause of increasing idle can be a bike that wasn't warmed up enough when the carbs were synced. Another can be airleaks in the rubbers etc. JT
  3. Mully
    Mully Kineticist
    Jul 9, 2001
    3,769
    The Comstock
    Run a propane torch around the inside of the carb bodies with the engine warmed up and idling, and if the idle drops when it's near the starter enrichener covers, that's your problem - the gaskets have shrunk and the covers are leaking air.
    mully
  4. Anorak
    Anorak Woolf Barnato Supporter
    Jul 23, 2004
    73,072
    Petaluma
    Don't light the torch.
  5. bmwblake
    bmwblake upside down parker
    Mar 3, 2004
    3,294
    nashville, tn
    for rob that is some good advice to add. :D
    had any time to figure out the issue yet rob???
  6. rob
    Jun 24, 2002
    582
    Arma, KS, USA
    Thanks blake!!:D
    I've just had a few minutes to poke around. Bette has me politiciting after work. Plus the 100 degree heat is back. I may be able to dig in later this week or the weekend.
    How's the family??
    Rob
  7. bmwmick
    bmwmick Old and Slow....Sorta
    Nov 27, 2003
    341
    Arizona, USA
    Rob,
    Same answer, different forum. :)
    Rob,
    Couple of ideas.........
    Clean and lube the 'bean can' advance mechanism. The grease can harden
    and when hot, the plate sticks in the advanced position. To test, disconnect the
    battery, remove the front cover. Reconnect the battery and take it for a ride. When it begins to fail, stop and see if you can rotate the advance plate and lowerthe idle RPM.
    Another source can be air leaks around the carb spigots or the rubber hoses. Spray some WD-40 at these areas when it is idling high to see if it drops. If so, fix the leaks. : ))
    StainTune mufflers do NOT have 'plates'. You must have an old Super Trap on there. :)
    Mick
    Tucson
  8. Solo Lobo
    Solo Lobo airhead or nothing Supporter
    Mar 16, 2004
    13,668
    Shoreline, WA
    when mine did the same thing I found that one of the lower choke cables had broken and the choke was stuck partway on. One the bike is running, push down on the choke actuator arms to make sure they are fully open.
    #8
  9. rob
    Jun 24, 2002
    582
    Arma, KS, USA
    THanks Mick, I'll start this weekend. The rubber bits in front of the carbs look new but I'll break out my supply of WD-40. Would air leaks cause the increased idle when warmed?
    As for the muffler, yeah, my bad, it's a Super Trap.
    Thanks again. I'll let y'll know what I discover.
    Rob Lessen
    Arma, KS
    #9
  10. rob
    Jun 24, 2002
    582
    Arma, KS, USA
    Boy I want that to be the problem. I really don't want to break out my wrench.:evil It always gets dirty and I have to clean it.:lol3
    Thanks I'll look at it first.
    Rob Lessen
    Arma, KS
    #10
  11. bmwmick
    Nov 27, 2003
    341
    Arizona, USA
    Rob,
    Yes, air leaks will cause an increased idle but from your description, I'd bet it's the advance unit.
    Mick
    #11
  12. Johann
    Johann Long Timer
    Feb 11, 2006
    9,916
    Europe
    Another vote for choke cable(s).SOLO LOBO diagnosed the same fault for me a couple of months back. Had same symptoms, bike would start fine, run OK for a few miles, then the first time I came to a stop the tickover began rising to 1500rpm then 1750 rpm with no discernible cause.
    Choke cable on my bike ('91 R80GS) came in three pieces and took about ten minutes to fit.The only mildly difficult bit was the plastic divider where rhe cables split which had clearly never been touched since the bike left the factory.
    The same symptoms will show if the screws covering the vacuum plugs are missing from bottom of carbs (don't ask me how I know!).
    My cables went at 37,000 miles. From other people I have spoken to life of all control cables seems to be somewhere in the 35-45000 mile range.Given the mileage on your bike seems due for a second set of control cables soon.
    #12
  13. Johann
    Johann Long Timer
    Feb 11, 2006
    9,916
    Europe
  14. Solo Lobo
    Mar 16, 2004
    13,668
    Shoreline, WA
    And to be honest, I only know because I checked for air leaks, re-adjusted my valves sixteen times and pulled out a considerable amount of hair before I checked my cables.....
    #14
  15. CaptTurbo
    CaptTurbo Long timer
    May 29, 2006
    1,099
    Ft Myers
    This problem sounds very serious. Better sell me the bike very cheaply! LOL :lol3
    #15
  16. bmwblake
    Mar 3, 2004
    3,294
    nashville, tn
    the heat is cutting into my riding time a bit as well. i haven't even thought about riding my dirt bike since its been so warm.
    the family's doing well, thanks for asking. palmer likes making vroom vroom noises and sitting on the bike already.
    #16
  17. Boojum
    Boojum I Miss the PartyBoss
    Jan 7, 2004
    6,144
    Ringgold, Ga.....Saaalute!
    She's a Cutie Blake!!!! Gonna make a Motorcycle Rider out of her?
    How's the GS doing? ANy more cleaning secrets? :lol3 :lol3
    Boojum!
    #17
  18. GS Tom
    GS Tom Been here awhile
    Oct 30, 2002
    168
    Route 66 Joplin,Missouri
    Rob, I could come over from Joplin this evening and take the problem off your hands to relieve you of further worries.:deal
    GS Tom
    #18
  19. rob
    Jun 24, 2002
    582
    Arma, KS, USA
    Mmmmm, let me think.......not yet.:rofl
    The PD always gives me the grins. Except when stuff happens and I have to get the wrench out of the sock drawer. Plus it is so big that I have problems with getting on to the smaller nuts and bolts. :wink:
    Thanks though.
    Rob
    #19
