Induction trigger for lights to avoid CANBUS
Discussion in 'Parallel Universe' started by Singletrack_mind, Nov 19, 2010.
  1. Singletrack_mind
    Singletrack_mind Been here awhile
    Aug 29, 2008
    518
    Northern New Mexico
    I'm hoping someone out there in ADV land will have a suggestion or two about this:
    What I want to do is add lights to my BMW F800GS. It's a CANBUS system. I've tried HID conversions for the low & High beams, but so far haven't found a system that plays well with the CANBUS & doesn't deliver a big "Lamp Failure" code & warning light. While studying the problem, I realized that a big part of my problem with the stock lights is that the high beam light pattern does not extend beyond the low beam, it just makes a hot spot in the middle. This makes me want to ad auxiliary lighting instead of improving the OEM high beam. Ideally, I'd like those lights controlled by the high beam switch. That way the high beam will brighten up the near distance, and the aux. lights would reach further into the distance, all with one switch. When I need to dim my lights, I want to just use the one switch. I can't just tag on to the power line to the high beam feed though, that will annoy the CANBUS.
    So here's my question: Is there any sort of device that would perhaps sense the current in the circuit to the high beam that I could use to trigger the aux. lights simultaneously? I'm thinking of the way a timing light senses current in an ignition wire, but hey . . . what about a photo cel in the high beam light housing??
    Thoughts?
  2. Luke
    Luke GPoET&P
    Aug 25, 2004
    5,444
    Beaverton, OR
    Wire it up aux lights with a relay, exactly the same way as you would on a non-canbus bike.
  3. Singletrack_mind
    Aug 29, 2008
    518
    Northern New Mexico
    Perhaps I wrote too much and clouded the issue. I am trying to trigger the aux. lights with the OEM high beam switch, along with the OEM high beam, without introducing any additional current draw in the high beam circuit that will cause an error message from the CANBUS system.
  4. marchyman
    marchyman barely informed Supporter
    Jun 30, 2005
    20,836
    SF Bay Area
    Wire the lights through a relay with the relay trigger connected to your high beam. The relay will pull about between about 80 and 175 milliamps. Your high beam is pulling 3500 ~ 4000 milliamps. Your bike's electronics module won't care about the difference.
    I use the low beam of my R12GS to trigger all of my switched accessories. That way they aren't powered until after the bike starts.
  5. Luke
    Luke GPoET&P
    Aug 25, 2004
    5,444
    Beaverton, OR
    The extra current drawn by the coil of the relay is very small and won't cause an error in the canbus system.
  6. big adv
    big adv I need supervision
    May 26, 2007
    1,073
    Kelowna, BC. CND
    Just be sure to trigger the relay for the aux. lights of the hi-beam light circuit, not off the switch. The switch is just a low(very)current ground input to the ZFE, completely separate from the lighting power circuits. Oh and by the way, none of this has anything to do with CANbus.
  7. matkal
    matkal Assault Commuter
    Jul 1, 2005
    1,721
    MI's Thumb :)
    I assume then that two relays triggered by the high beam circuit would also not be a problem? I am thinking of running two sets of aux lights on a r1200gs, one HID and one LED :evil
  8. jengel451
    jengel451 1 Cool MotherF#$cker
    May 2, 2011
    1,766
    Bitterroot Montana
    3 years. Nicely done!!
    #8
  9. matkal
    Jul 1, 2005
    1,721
    MI's Thumb :)
    Yeah, I know but why start another thread?! :huh
    #9
  10. Loutre
    Loutre Cosmopolitan Adv
    Nov 28, 2010
    14,471
    :o)
    :raabia Reaver, can you adopt him aswell? Ready to share my shed with him!
    #10
  11. FredRydr
    FredRydr Danger: Keep Back 300 Ft.
    Aug 16, 2005
    4,530
    Carlisle Pennsylvania USA
    This is getting really weird.
    Fred
    #11
  12. jengel451
    May 2, 2011
    1,766
    Bitterroot Montana
    Getting? it's been borderline Deliverance for a long time. Now it just went to Pulp Fiction, Which one is Zed and which one is Maynard?
    #12
  13. Reaver
    Reaver Hasta luego
    Aug 7, 2008
    23,222
    No Fumar espaƱol
    You're going to need a bunkmate. Another Severe Cold Advisory here today. Good luck getting the door open buddy.
    I tolerate him cause there's an ocean between us. If he shows up at my door I'm calling the gang.
    #13
  14. MTrider16
    MTrider16 Ridin' in MT
    Oct 16, 2006
    1,870
    Eastern Montana
    If you want instructions on where to tap into the light circuts, this is what Tourtech does with their Fog+HID aux light combo. They have thier istruction sheet on line.
    David
    #14
