Bings on a Race Bike Ponderings
Discussion in 'Airheads' started by Voltaire, Aug 18, 2013.
  1. Voltaire
    Voltaire Triumphant.
    Jun 4, 2011
    3,755
    Auckland,New Zealand
    I have been running 36mm Dells on my R90 race bike for 18 months, going to bump it up to 1000cc using info supplied earlier by Dirk from Germany.
    I'm short of coin so the best price I have found on a set of 40mm dells is $600 US, by the time post is factored in and the local taxes its getting up there.
    I have a set of 40mm Bings and are thinking of taking a punt on them just to see how they go on a race bike.
    Conventional wisdom suggests CV carbs are not as good a slide carbs.
    The D port heads I am going to use are 40/42 with an inlet stub for a 32 mm carb, 35 mm id on the port.
    Anton's site says there are 40/32 mm adaptors but I can't find them...:huh
    I welcome any thoughts on making Bings perform.
  2. Big Bamboo
    Big Bamboo Aircooled & Sunbaked
    Sep 29, 2010
    17,403
    Big Island of Hawaii
    Replace them with Mikunis... :D
  3. Voltaire
    Jun 4, 2011
    3,755
    Oh I forgot to mention that the class of racing is " no Jap parts"
    I even persevere with Amals on my Norton...:lol3 ( Winston would be proud of me)
  4. pommie john
    pommie john Long timer
    Apr 9, 2008
    2,244
    Brisvegas, Australia
  5. motu
    motu Loose Pre Unit
    Dec 28, 2001
    9,939
    New Zealand
    So no Japanese....that only leaves the rest of the world, time to think outside the box. My 34mm Blue Magnums are too small for a real big bike like yours, and I've only got one 36mm. Find another 36 and you've got 2, find a 38 and bore the 36 out ( I bored one of my 30's out to make 2 34's. The Blue Magnum is one of various carbs this guy designed, they are American and therefore don't tax the brain on tuning. How about a diaphragm carb? Tilotson or Walbro, you find big ones on outboards and jetskis, some people have used them on bikes. There was once a single Dellorto - like a twin choke side draught cut in half, I always wanted to give one of those a shot.
    Just trying to think outside the Bing, Dellorto, Mikuni box. Boxes can be restricting if you spend your life inside them, which Airhead types tend to do.
  6. Box'a'bits
    Box'a'bits In need of repair Supporter
    Sep 26, 2008
    5,217
    Wellington, New Zealand
    GuzziTony had Amals on his bike. He's replaced them with Mikinis recently... :D. I think you'd find the Bing CVs wouldn't give the 'snap' or immediate response you want.
  7. Voltaire
    Jun 4, 2011
    3,755
    I'm not so sure I need 'snap', as soon as I finish braking, turn in, you have to slowly get on the throttle. I'm keen to have a go and see. Sort of Airhead mythbusters.... I've proved that ATE brakes can be made to work well, why not Bings.
    My VW mate says I should mount a sidedraft dual 40mm Dell over the gear box..... :evil
  8. Box'a'bits
    Sep 26, 2008
    5,217
    So bet you're reasonably comfortable that they didn't sell at auction then...Only one way to find out.
    #8
  9. RGregor
    RGregor Been here awhile
    Oct 31, 2007
    914
    Bavaria
    Hello Voltaire,
    the german R100GS and R100R are using the 40mm Bings on the small port heads with the M42 threads.
    So part number should be: 11121338361
    But they're $55 each !!!
    No chance to get some fabricated?
    I could provide the dimensions if needed.
    Have a second look on your Bings. What's the diameter of the butterfly?
    The early 40mm Bings have 44mm butterflies, the later ones 42mm.
    And the spigotts should be built accordingly.
    Best regards,
    RG
    #9
  10. Rob Farmer
    Rob Farmer Long timer
    Aug 27, 2002
    7,500
    Vale of Belvoir - Nottinghamshire
    Good Man :thumb
    Amal Mark II carbs are brilliant carbs. I'm ordering a set for my project bike.
    #10
  11. Voltaire
    Jun 4, 2011
    3,755
    Was hoping to part fund the Dells from the sale of the big valve heads and 40mm carbs but no interest. oh well.
    #11
  12. supershaft
    supershaft because I can
    Sep 9, 2010
    9,116
    San Francisco Bay area
    From the sound of everything mentioned so far I would say you already have what would work best. 40mm Bings? Your 36mm Dell's will out perform them all through the rev range.
    I wouldn't listen to your VW mate! :D VW stuff rarely translates!!
    #12
  13. bmwrench
    bmwrench Long timer
    Nov 10, 2006
    10,195
    Keep the big valve heads and use them. I'd prefer 38mm Dell Ortos. There has to be some good used ones out there.
    #13
  14. Plaka
    Plaka Brevis illi vita est
    Jun 19, 2010
    9,608
    Interest depends on price. At some price there is always interest.
    The big Bings have a lot of lag. It's a vacuum carb, you open the throttle but it doesn't really open (at the slide) until the vacuum builds. So it is always lagging behind your input. You can just roll it on easy but the Bing will be rolling it on easy sometime later. A big disadvantage. I rode a 90/6 with flatslide Mikunis (TMs, no pumps as I recall). It was like there was a steel rod connected to the power. You moved that throttle a fraction and the engine responded immediately.
    #14
  15. Voltaire
    Jun 4, 2011
    3,755
    I had them listed locally for $280.00 US. BMW stuff does not attract much interest here unless its give away prices.:rofl
    Saying that....that's why I have built a BMW race bike as cheap and solid.
    I'll probably just bung the 36's back on and up the main jet from 155.
    I tried to sell a 1971 VW Beetle project recently, $1100 US, plates on hold, all parts, not one call.
    Parted it out and doubled that, I just wanted the space for bike stuff :rofl
    #15
