I recently moved the remote pre-load adjuster while I was grinding off the passenger footpegs, and I cannot for the life of me figure out how the adjuster and rear brake reservoir attach to the mount.... Anyone have any pics they can post up real quick so I can finish up? Thanks!
If not, explain in more detail as I did not understand what you are looking for. [/url][/IMG] [/url][/IMG] [/url][/IMG] [/url][/IMG] [/url][/IMG]
The remote pre-load adjuster for the Elka Shock is moved back by where the brake fluid resevoir typically is. It's attached through a bracket and a few bolts. I mixed up some bolts and forgot how it attaches... Here is a pic of the area for reference
I still have the stock rear shock - so I probably can't help you. If I can, just explain in newb language. On a side note: 1. I do see you have the front forks done by Alex @ Konflict. He did mine as well and I love em. 2. I would like to do my rear shock this winter, just have not decided which option. Good luck!
