Gutted stock exhaust??
Discussion in 'Dakar champion (950/990)' started by KEELAYMONSTER, Nov 5, 2012.
  1. KEELAYMONSTER
    KEELAYMONSTER "Do one thing every day that scares you." KC
    Feb 11, 2012
    233
    Napa, CA
    Has anyone gutted the stock cans and tried them out? Im not talking just de-cat them, I mean gut everything. Im curious how they sound. My thoughts are they might sound like crap.:huh Im just looking for a cheap way to lighten them and make them run a little cooler. If they dont sound to horrible ill probably gut mine.
    I have already checked the stock cans "guts" on the HOW. Looks easy enough to do.:evil
  2. KEELAYMONSTER
    Feb 11, 2012
    233
    Napa, CA
    I suppose I should state these are off a 950 A. Could be helpful to know :deal
  3. DeepInIt
    DeepInIt Long timer
    May 19, 2006
    1,374
    Cordoba, Argentina
    Define gut. If you truly gut them, it will sound like an obnoxious Harley and run like crap until you rejet it.
  4. tunp
    tunp Been here awhile Supporter
    Apr 28, 2011
    342
    almost SE PA
    yes it can be done. i run a truly gutted and reworked can.
    But it takes some work. I cut both end caps right behind weld, then you need to hole saw out the exhaust outlet (1 1/2" hole) is what i used. On the back side of can you must cut all the way thru which will cut thru the cat pipe also
    After that you can slide the whole baffle assembly out.
    I then reweld rear cap back on, welded an 1 3/4 dia pipe to the end cap, then used a 1 1/2 stainless preforated baffle thru can packed with baffle material i suggest stainless steel wool as the normal packing did not last long.
    for the end cap i cut a pc off the interal baffle and welded to the inside of can so it projects enough to rivet the end cap on for repacking.
    It will work and sounds good but it is loud, i ended up fitting an FMF spark arrestor on the end cap to reduce noise level.
  5. idahoskiguy
    idahoskiguy Long timer
    Jun 22, 2005
    1,162
    Really?...............Your bike won't run any better and actually worse until it is rejetted. Glad I have left the stock exhaust unmolested, seems like a waste of time and money on these bikes for NO GAIN.
  6. KEELAYMONSTER
    Feb 11, 2012
    233
    Napa, CA
    I am aware of the necessary re jet. Did the setup you made weigh significantly less than original or is it relatively the same. Also do the cans run cooler?
  7. WARRIORPRINCEJJ
    WARRIORPRINCEJJ Forsaken
    Jun 29, 2009
    29,627
    The cats, not the baffling, is what makes 'em run hot...
  8. KEELAYMONSTER
    Feb 11, 2012
    233
    Napa, CA
    aaahhh. good to know. maybe just de cat them then.
    #8
  9. sailah
    sailah Lampin' it
    Aug 12, 2005
    7,804
    Turning expensive metal into scrap
    If you want some nice cheap light pipes, buy some carbon cans from a ducati and have a welder make a quick flange to the stock mid pipe. Takes a lot less time than gutting the stockers and lighter too.
    #9
  10. Sporting Wood
    Sporting Wood I
    Oct 18, 2011
    1,144
    Horneytown, NC
    The search button can be your friend. Theres several old threads about this, many with pictures and directions.
    #10
  11. tunp
    Apr 28, 2011
    342
    almost SE PA
    so wieght savings was part of my goal when i did this and yes it easy drops 10-15 lbs between the two cans. My other goal was to go to a 2 into 1 setup and use the other can as a storage box which now holds my elec pump, a front and rear tube, first aid, spare plug, zip tyes and jb weld.
    So was it some work, yes, does my bike look stock w/ addtioanl storage and more rumble, yes. are the cans much cooler, yes. Did it affect performance and or mileage, no.
    I looked at it this way if it all worked it cost me a few bucks for material and some time which i was willing to put into it. If it did'nt work, well then i buy after market cans which i was going to do. And now i dont have to.
    #11
  12. KEELAYMONSTER
    Feb 11, 2012
    233
    Napa, CA
    My thinking exactly. If i can spend some of my time to save some money Im all for it.
    The used cans was actually my next route if this doesnt work. I have access to a welder and a bunch of other fun tools at my work.
    Also the search button sucks. Every time I try and use it it shows me a bunch of totally irrelevant stuff if anything at all. I did try manually looking through the OC posts though and didnt see anything. I have also checked out the HOW and saw whats all inside the stock cans.
    Thanks for the input everyone. Ill post whatever I end up doing. Working on cutting my stock windshield down a bit today.:evil
    #12
  13. K2m
    K2m Long timer
    Feb 27, 2005
    2,262
    Sydney
    Sorry WP Not True ;-) Remove the cats as I did in 2005 and nothing changes heat wise.
    1/ The exhaust run through the middle of the bike makes the middle of the bike bloody hot
    2/ The standard muffler has 1mm of insulation under the outer skin to protect it from internal heat. This does 5/fifths of fuck all to help cool the outer skin down.
    3/ An aftermarket muffler is a perforated tube with 2 1/2 inches of insulation wrapped around it under the outer skin. with the exception of a little conduction of heat at either end where inner joins outer the outer it is well insulated.
    4/ The whole standard muffler is designed to function as a cat.
    There is only one way to get rid of the heat, get rid of the exhaust.
    You can build your own like I did or the GPR is a very attractive proposition.
    If you do not like the heat............
    You need to move the exhaust system out into the flowing air along with your voltage RR
    #13
  14. KEELAYMONSTER
    Feb 11, 2012
    233
    Napa, CA
    Allright.
    So I have been running a 2-1 setup with a de-cat stock muffler for a while now. It's just as hot as before and really made no difference in sound or performance.
    My next route is to use the outer of the stock can and replace the innards with a perf core and lots of packing. Im sure it will be loud, require a re-jet, and still be relatively heavy but it should be much cooler. Im have a stock muffler off an 08 CRF450 that i am going to rob the innards from. I'll report when I finish it...
    #14
  15. Zander
    Zander Been here awhile
    Mar 21, 2008
    194
    Montreal
    Hi K2M,
    Where do you relocate your voltage regulator to get it into clean air and keep it protected ?
    #15
  16. Head2Wind
    Head2Wind MotorcycleMayhem
    Mar 13, 2006
    2,723
    NorthWet Washington
    zzzzzzzzaaaaaaaaaaapppp...... dead thread revived :D
    As you start to cut the OEM muffler apart, you will discover that it is possible to gut and reconfigure. You also will discover that it can be a bit of a PITA to work with because the outer shell is not single walled so welding it all back together can be challenging at times.
    I believe that the OEM mufflers 'run hot' because the exhaust spends a bunch of time in the muffler traveling between the three chambers before it finally exits. The cat can be a contributing factor, however I do not believe it really makes all that much difference in surface temps one way or the other.
    #16
  17. Zuber
    Zuber Zoob
    Sep 28, 2004
    10,234
    West of the West, Oregon
    I've completely gutted a stock muffler, but did not install it. When you pull out the double wall with the soft packing, the muffler shell will ring like a bell. These would make a good high pitched wind chime. I suspect it will ring the same way when used on the exhaust too.
    #17
    Gryphus1 likes this.
  18. tunp
    Apr 28, 2011
    342
    almost SE PA
    My experiance with this will disagree. Once you get your preferated tube and packing material in place its now a muffler not a wind chime
    #18
  19. K2m
    K2m Long timer
    Feb 27, 2005
    2,262
    Sydney
    The reason Zuber did not install it is because even gutted it's a heavy heap of shit and a waste of time................ just buy some mufflers :lol3
    I have just had a complete year away from bikes, and ADV.... a sabbatical :freaky
    #19
  20. K2m
    K2m Long timer
    Feb 27, 2005
    2,262
    Sydney
    I guess the simple way would be........... anywhere the wires reach. I have changed my bike so much that it would no longer be relevant to a normal LC8.
    #20
