cylinder studs stripped, drilling and tapping block
Discussion in 'The Garage' started by Lujo, Oct 6, 2014.
  1. Lujo
    Lujo Long timer
    Nov 30, 2003
    1,075
    Pittsburgh, PA, USA
    Reposting this from Road Warriors where it got no love.
    I'm removing the right cylinder on my R1200ST so I can helicoil the lower two cylinder stud sockets -- some genius over-torqued the nuts so badly that one of the bottom two studs got loose enough the nut to fall off in the head. It doesn't seem like too daunting a job, but if anyone's been there and has advice, I'd appreciate hearing it.
    Is there anything else worth doing while the cylinder is off? The bike's got 50k on it, and runs fine except for pinging on strong acceleration. Which I was going to start figuring out when I instead discovered that I have some helicoiling ahead of me.
  2. rodnok1
    rodnok1 Adventurer
    Sep 26, 2014
    59
    Helicoil not good for high stress areas. Depending on the size you need you can get something like a NormSert(used for car engine fixes) or timeserts(several sizes and designs/shorter/longer) which are designed to be high stress.
  3. JimVonBaden
    JimVonBaden "Cool" Aid!
    Feb 11, 2005
    101,524
    Alexandria, VA
    This has been discussed repeatedly. The factory even used Heli-coils, as have I a few times for this application. They work just fine!
  4. Anorak
    Anorak Woolf Barnato Supporter
    Jul 23, 2004
    73,073
    Petaluma
    Just about every threaded hole on a modern jet engine on commercial aircraft has a Heli-Coil insert.
  5. Sethro303
    Sethro303 Master of Disaster
    Jul 21, 2013
    752
    SnoCo, WA
    That is either:
    A-A perfect testament to the strength of a helicoil
    Or
    B-Going to really bother me the next time I fly
  6. Lujo
    Lujo Long timer
    Nov 30, 2003
    1,075
    Pittsburgh, PA, USA
    OK, I'll ponder the Heli-coil vs Time-sert issue. Where are Time-serts easily available?
    Currently more importantly, how does one remove the cylinder? The head came off easily, but the cylinder has been resisting my mallet. There seems to be some goo between the cylinder and the block that suggests it's on there pretty good. Should there be any goo? Is some RTV supposed to go between the block and the cylinder on reassembly?
    Again, constructive input (even on the Heli-coil vs Time-sert question) is deeply appreciated!
  7. JimVonBaden
    Feb 11, 2005
    101,524
    Alexandria, VA
    Damn, did no one ever clean that thing?
    You have some adhesive there, that shouldn't be, meaning someone has been in there before. Keep at it with a mallet, and IIRC there is a flat or two you can safely pry against.
  8. anonny
    anonny What could go wrong?
    Mar 20, 2007
    7,400
    Beautiful Revelstoke BC
    It's not that I'm doubting you..... I am wondering how you know this
    #8
  9. Anorak
    Jul 23, 2004
    73,073
    Petaluma
    Because I worked in the UAL engine shop at SFO for three years. I've removed and installed a lot of Heli-Coils.
    #9
  10. defib
    defib Portly Paranurse
    Jul 26, 2011
    556
    Winslow AZ.
    Anorak; not doubting but really curious. How do you remove a helicoil insert, and why would you?
    #10
  11. Beezer
    Beezer Long timer Supporter
    Oct 26, 2004
    12,155
    Anchorage, formerly Spenard (hub of the universe)
    Helicoils go back to the 30's & have been used extensively in aircraft piston engines too, both as new construction and as a repair. you have a high tension application, be sure to get coils with enough threads, either that or run two coils. I've never seen a Helicoil fail if installed properly. (almost 40 years as an A&P)
    #11
  12. concours
    concours WFO for 50 years
    Dec 2, 2008
    9,696
    USA
    What is your skill set? Drilling and tapping paralell with the original hole
    in two axi while in situ can be slightly more than many shadetrees can do well. Any veteran machinist buddy's you can bribe with beer?
    #12
  13. Cataract2
    Cataract2 Where to?
    Jul 5, 2010
    20,825
    CO
    Just let that sit in your mind.....:D
    #13
  14. Cataract2
    Cataract2 Where to?
    Jul 5, 2010
    20,825
    CO
    Block of wood + rubber mallet (you could just forgo the wood, but I like double protection.) and tap it. Probably going to take some work being I bet some knob butchered the job previously.
    #14
  15. Lujo
    Lujo Long timer
    Nov 30, 2003
    1,075
    Pittsburgh, PA, USA
    It doesn't look as dirty in real life. :-)
    Thanks for all the responses.
    Is anything supposed to go between the block and the cylinder on reassembly?
    @JVB @Cataract2: a block of wood and a mallet is what I've tried, but I'll keep going.
    @concours: my skills are more related to sitting at a keyboard and standing behind a lectern. I don't know any machinists, though, and for better or for worse I'm not too worried about the drilling and tapping.
    #15
  16. mcma111
    mcma111 Long timer
    Jul 17, 2007
    18,735
    San Francisco,Ca.
    Airhead stud repair has a guide plate that goes on the remaining studs to give the drill a straight shot. You might want to check if there is a kit for your bike.
    R100 kit
    #16
  17. mouthfulloflake
    mouthfulloflake Not afraid
    Aug 21, 2008
    37,174
    The Berkeley of Arkansas
    make sure you have that one hidden bolt removed too, its sort of in a pocket in the head.
    yamabond or similar, THIN bead between cylinder and engine upon reassembly, after a good cleaning of course.
    #17
  18. wadenelson
    wadenelson Rider/Writer
    May 18, 2014
    633
    Durango CO, Phoenix AZ
    I'm guessing:
    A) the A&P's who insert Helicoils on jet aircraft engine have done hundreds and have TONS of experience doing them properly
    B) Pratt&Whitney / GE intentionally left enough "meat" in the block for a helicoil to work successfully.
    A first timer doing a helicoil on a critical application? I'd hire a machinist (or A&P with tons of experience) to do it rather than learing the hard way what mistakes can be made. Buy the drill guide.... Nothing's as simple as the directions make it sound, machinists ALWAYS know tricks and nopes...
    Or find a new (used) block, which is what 99% of all AUTO techs do when faced with head bolts that are stripped in the block.
    #18
  19. paulgadget
    paulgadget Forever Learning
    Aug 18, 2005
    176
    USA Fulltime RV
    I would not go with a helicoil, this is from experience. I have an '05 r1200gs that at 600 miles service was found to have a stripped head stud, bmw na' warranty fix was a helicoil in the engine block, I filed a complaint, stating that the fix would not last. 40,000 miles later and it did fail. I found the nut had come off and the washer had dropped into the oil sump. Bmw na refused to do anything worth my while. My dealer stepped up and replaced it with an over sized insert, at no cost to me, not sure what make or type, but he described it as a thick disc of steel threaded on outside and inside.
    #19
  20. JimVonBaden
    Feb 11, 2005
    101,524
    Alexandria, VA
    Having done several of these, and not being a machinist, I can assure you that it is dead simple. Carefully drilling out the hole allows the drill to take off the very tiny amount of metal to clean out the hole before threading the metal for the new helicoil. It is not really precision work! The hole self centers unless you are truly hamfisted!:deal
    As for the helicoil holding, they do just fine if threaded right.:deal
    #20
