Final drive failure resulting in crash?
Discussion in 'GS Boxers' started by Grad, Dec 17, 2007.
  1. Grad
    Grad Wannabe
    Dec 7, 2004
    2,265
    Athens, GA and Blairsville, GA
  2. Lone Rider
    Lone Rider Registered User
    Jan 29, 2002
    26,342
    out and about
    Mechanically, sure, it can happen. Although there are few reported instances of this common failure resulting in a crash.
    All riders of BMW motorcycles with ring/pinion rear drive need to monitor the condition of their bike and be aware of potential failure symptoms. The same goes for chain-driven bikes, but it's not as clear and easy to determine upcoming failure on the BMW final drive system.
    In my personal experience, there is a noticeable progression in the final drive failure that can be felt while riding. Obviously, other factors could mask these tell-tales.
    It's good that he was geared-up well.
  3. JimVonBaden
    JimVonBaden "Cool" Aid!
    Feb 11, 2005
    101,516
    Alexandria, VA
    Scetchy information, but I think you might have hit it when you mentioned the lug nuts comming off. That could make a pop, or what might sound like one.
    I have never heard of a FD locking up completely and the wheel coming off. I am not sure it is even likely. The mechanical hold of the lugs, when properly tightened, would more likely cause the wheel to lock and the tire to slide. That has happened.
    The only way to know for sure would be to see the FD and see if it is whole, or in chunks, and the wheel for the same information.
    Glad he was fairly OK, and was dressed for the crash!
    Jim :brow
  4. Jettson
    Jettson Adventurer
    Sep 8, 2007
    16
    So Cal.
    I work for a local law enforcement agency and I noticed a log entry this week that stated one of our motor officers went down after, "his ABS locked up" I am pretty sure most of our guys ride BMW's and I will try and get a hold of him and see if he knows what happened.
    The rest of the log mentioned he was going approx 40 MPH at the time......not really something to look forward to.
    Jett
  5. JimVonBaden
    Feb 11, 2005
    101,516
    Alexandria, VA
    Seems that the ABS isn't likely to "lock up", but more likely to fail to prevent a lock up. Is that what you meant, or did you mean the brakes locked all on their own.
    Jim :brow
  6. Jettson
    Jettson Adventurer
    Sep 8, 2007
    16
    So Cal.
    From what I read he crashed.....with minor injuries, as a result of the "ABS locking up" be mindful alot of people who dont know what they are talking about come into play with this type of log item.
    I will get further info from him when I get a chance. I have never heard of ABS locking up all on its own and it seems something else came into play.
    the way it read he was cruising at 40 mph and the bike locked up.
    I will be sue to post follow up.
    Jett
  7. SocalRob
    SocalRob Super Moderator Super Moderator
    May 23, 2006
    37,467
    Los Angeles @ base of Angeles Crest Hwy
    I've had my rear wheel almost fall off (of an R1150R) after the dealer neglected to torque the lugs after tire service. To this day I think what saved me from a severe crash was sometime before my incident I had read on this board about a rear wheel falling off. I felt the vibration, and my thought process went pretty quick to the "dealer didn't torque up the rear wheel" thought, and I pretty quickly made for the side of the road. The harmonics were pretty radical by the time I got to the side of the busy freeway I was on. I believe if I had ignored the vibration for even a couple of seconds longer I may well have faced disaster. As it was, 2 lugs were completly out, one came out after about a third of a revolution, and the 4th was loose but sort of jammed. The rear brake rotor sort of kept the whole think going around.
    If you feel anything strange on a bike, get to the side of the road fast. Trust yourself, your subconcious knows when things are different. I've also picked up on the fact a front tire was losing air. If it feels wierd I check.
    The accident in this post sounds more like loose lugs to me. I can see a final drive locking up a rear wheel but I don't think there is enough force to rip the wheel off. Then again, one never knows.
    I'm not into lawsuits whatsoever, but if a dealer screwed up my bike & it was clearly their fault the wheel came off, and I was injured, to me thats a legitimate complaint they better make right. In my case, no injury, I did shame the dealer into giving me 3 used lug bolts. The rest just buffed out.:lol3
  8. Anorak
    Anorak Woolf Barnato Supporter
    Jul 23, 2004
    73,073
    Petaluma
    I have a friend who was a BMW mechanic when I-ABS was first available. She had a story of a bike locking the brakes completely. If I remember correctly, she said it actually forced either the seals or the actual pistons out of a caliper.
    #8
  9. rideLD
    rideLD The further the better!
    Jul 15, 2004
    5,412
    Omaha, Nebraska
    So let me get this straight. He *might* have been riding a BMW. He *might* of had the ABS lock up (which would make it not ABS). A trained motor officer *might* not have been able to ride out a 40mph rear wheel skid and keep it on 2 wheels. :confused
    I hope you don't take this the wrong way but I find it strange that you would feel the need to report this here with so little information and zero facts. I believe in the law enforcement business they call it hearsay and speculation. Why not at least try to get a few facts before reporting it in public forum full of paranoid types that already spend too much time worrying.:lol3 Perhaps since this thread is based on speculation you felt you would add in some of your own?:confused
    #9
  10. VanXR
    VanXR nOOb/NooB/noob/NOob/NOOB/ Supporter
    Apr 27, 2005
    934
    So. Ca.
    Not sure if it's possible for the brakes to lock. How do the pistons push themselves? Road Gremlins?? I call BS. Don't throw me to JoMama but just don't see how it would be possible.
    #10
  11. Anorak
    Jul 23, 2004
    73,073
    Petaluma
    Integral ABS has two hydraulic pumps that supply pressure to the calipers. What appear to be master cylinders are just sending pressure signals to the brain. If something were to send a spurious or corrupted signal excessive pressure could be created in the system. When doing a bleed test I recall seeing pressures of at least 1000 psi.
    #11
  12. Minisquatch
    Minisquatch Been here awhile
    Apr 10, 2007
    190
    utah-only one wife
    My thoughts exactly. ABS does not apply brakes, it releases them. Most of the time, if you get to the bottom of the issue, the driver panics when the ABS activates and they release the brakes completly thinking something is wrong. Not saying that this is the case at hand but it does happen.
    #12
  13. Rad
    Rad Done riding
    Sep 24, 2001
    12,174
    Mine locked at about 65 mph when I pulled in my clutch with the first final drive failure I had. Fully loaded on a tour at about 65-75 mph my pegs began to feel funny, a weird vibration and I was trying to figure out what it could be so I pulled in my clutch to coast for a moment to see it would stop the vibration, that could mean the "problem" was forward of the tranny. Well, when I did that the rear wheel locked so I dumped the clutch and the rear wheel started turning again. At that point the noise from the rear drive was horrific and I got her stopped asap.
    #13
  14. rdwalker
    rdwalker Long timer Supporter
    Jan 3, 2005
    2,640
    The Badlands (of NJ)
    So which is it? BS or ABS? :evil
    By the way, my thoughts exactly. The guy describes unknown lockup. Which could happen, of course - for example, as other inmates mentioned, by lugnuts coming off.
    I just don't see how brakes would do it, even if he had a machine with brake assist.
    Let's wait for details.
    #14
  15. Wallowa
    Wallowa Diver Down
    Nov 30, 2006
    6,095
    NE Oregon
    What bike were you riding? What specifically failed?
    #15
  16. airansun
    airansun Ride Wet!
    Jun 8, 2005
    307
    NorCal
    Goodness, this is a thread to cherish.
    Remind me never to get caught in a suddenly stopped high rise elevator with you guys!
    #16
  17. Rad
    Rad Done riding
    Sep 24, 2001
    12,174
    01' 1150 GS, large main bearing in the FD went south.
    #17
  18. clifffffffff
    clifffffffff Adventurer
    Oct 23, 2007
    40
    Brooksville, florida
    I had both the FD fail and the rear wheel almost fall off my 2002 1150 GSA. the FD failed about a 2 hours after i started feeling unusual vibrations in the foot pegs. It was the big bearing that failed. i was in the desert of Peru at the time and had to limp back to Lima ( at around 20-30 mph) for repairs, the wheel never locked but it felt very loose.
    The rear wheel almost fell off about 1,000 miles or so after i replaced the FD. the vibration was very similiar as when the FD drive failed and i thought the bearing had gone again, but when a checked the lug studs, all were very loose and ready to fall out. I had used a torgue wrench ( granted a cheapo one)on the studs when i put the wheel on after replacing the FD. needless to say i check the studs very often and they have not loosened at all so i dunno what happend.
    #18
  19. TUCKERS
    TUCKERS the famous james
    Dec 23, 2005
    22,466
    Villa Maria Sanitarium, Claremont, CA. USA
    I may have the oldest, first generation, oil head final drive failure.
    1995 BMW R1100RSL 90,000 miles:
    About 03/04 I was 'racing' my nephew up the mountain to reach the Continental Divide, Colrado. Bike had been running perfect, but on reflection I did feel a slight 'hiccup' now and again, like it popped out of drive for a nano second, this had happened a few times that year. Any way, I was doing about ninety, pulling up the hill and taking curves 'on power', it was really nice. Sean, my nephew was right behind me, trying to keep up on his dads BMW R100GSPD, and doing a stellar job too! All of a sudden, without any warning, the bike just kinda dragged in the rear and slowed from ninety to twenty in a second or two, the wheel didn't lock or skid. I managed to pull over to the side of the mountain, I was perhaps half a mile from the summit. I was still on the road, but over to the right, I got off the bike as it wouldn't move. I couldn't push it on my own, the rear was 'kinda' locked, but not completely. Sean by now had doubled back and he helped me push, the rear end went clang, clang, clang as we moved it, got worse and worse, until we had to skid push it in the dirt to a safe place. When the tow truck came we had to skid it on the flat bed. Nothing was smashed, no oil leaks showing, but the rear was locked. That's all folks, I parked the bike at BMW of Colorado Springs on Sunday night, borrowed a truck from my brother in law, and went to Sturgis! I phoned the dealer on Tuesday to tell them to drag my bike in and check it out. NO BIKE! I guess someone stole it from the lot! I got $4500 off the insurance company, added some and bought a 2000 BMW R1150GS. Worst part was riding bitch on my wife Colleen's bike from Castle Rock, Colorado to Los Angeles, California! I've beat the GS to heck and back, 50,000 miles and no trouble, just changed the rear drive oil about every 10,000 (or more). I ride it pretty hard in to corners, changing down and engine braking, it has held up fine, so far. I'm worried though, if it locks and pitches me I guess I'm fucked.
    #19
  20. Beeming
    Beeming Itchy Feet
    Jun 4, 2007
    636
    Australia
    A good tradesman never blames his tools:evil BTW your web site is broken as well.
    Tads
    #20
