Tire Air Seepage
Discussion in 'GS Boxers' started by PRW, Aug 9, 2010.
  1. PRW
    PRW living @ 11.5740741uHz Supporter
    Mar 3, 2003
    5,503
    North Branch of the Chicago River
    Up until my last tire change, I had been running TKCs for years. Besides being excellent (though short-lived) tires, they always held their air pressure at a rock-solid PSI for months at a time.
    I switched to Anakee-2 on my last tire change - based on a higher ratio of on-pavement vs. off-pavement riding planned for this summer. Also an excellent dual-sport tire and very pleased with it overall.
    One thing I have noticed however, is that both the F & R tires lose about 1#/week - not a huge deal, I know, but it is a bit of a nuisance. I've thoroughly checked for leaks around the valve stems and rims - nada. Does anyone have experience with some tire brands "seeping" air more than others?
  2. JimVonBaden
    JimVonBaden "Cool" Aid!
    Feb 11, 2005
    101,516
    Alexandria, VA
    Assuming you changed your valve stems, the tire shouldn't leak at all.
    That said, the Pilot Road 2 tires on my ST leak a bit, about a pound a week.
    A couple things I would normally suggest, like scratches on the bead seat, or debris in the bead, don't make sense on your, or my, tires since both are doing it.
    Jim :brow
  3. PRW
    Mar 3, 2003
    5,503
    Hi Jim - thanks. Agreed - they shouldn't leak - but since it's happening on both my tires, and at a fairly equal rate, then I'm wondering if certain rubber compounds inherently "seep," osmosis-like, through the compound itself. In describing the Anakee-2, Michelin's website indicates that they incorporated a new "Silica-charged rubber compound."
    Again, having to top-off 1-2#/week is hardly worth whining too much about, but I am curious as to what might be going on here.
  4. lopaka
    lopaka Curiouser&Curiouser
    Mar 10, 2006
    114
    Neverwhere
    Yup.
    I've got Anakee 2's, GSA spoked wheels, and front & back seems to lose ~1 psi/week.
    Since it's consistent, it provides a cadence to check the pressure (beyond the normal preride tink-tink-tink/thunk-thunk-thunk front/back tap).
  5. Wallowa
    Wallowa Diver Down
    Nov 30, 2006
    6,095
    NE Oregon
    Hey..I hear you folks talking about 1-2 psi differences..I know you realize that ambient temp makes a big difference; as does the temp of the air you put in...stabilize tire pressure [if you filled or added to it, let it sit for a day] then re-check at the same ambient room/shop temp ..obviously not after running on the road and generating heat..
  6. PRW
    Mar 3, 2003
    5,503
    C'mon Phil - give us more credit than that... :beer
    Yes, of course - I'm checking these pressures under an "all else equal" setup, i.e. same ambient temperature. What other method can you use when expecting an accurate tire pressure reading? Also, I haven't merely done a 1-week sample. The 1-2#/week pressure loss has proven to be cumulative.
  7. RogerA
    RogerA Continually Confused
    May 3, 2007
    73
    DeLand, FL
    Had the same problem until I started using Ultraseal, now the pressure remains stable for months.
    Since the valve didn't change I seems to me the leakage must have been general porosity.
    Just my $0.02
    Roger
  8. Nitzo
    Nitzo Long timer
    Jan 2, 2006
    4,958
    Daytona
  9. Wallowa
    Wallowa Diver Down
    Nov 30, 2006
    6,095
    NE Oregon
    Credit? Sorry only cash! No disrespect intended...I saw 1-2 psi and thought that most gauges don't even have that precision and hell the needle on my gauge is almost that fat...and of course temps come and go...no, I understand that you leveled the variables.
    #9
