Spare tire carrier for the Vespa GTS step-by-step walk thru
Discussion in 'Battle Scooters' started by klm4755, Jun 26, 2013.
  1. klm4755
    klm4755 Been here awhile
    Jun 19, 2006
    587
    Enclosed is a step-by-step walk thru outlining the fabrication and process for installation of a spare tire on a Vespa GTS 250ie. Note that the Vespa GTS rims are interchangeable. It is OEM recommended that the rear tire (130-70/12) be slightly larger than the front tire (12070-12), but a rear wheel/tire combo can be installed on the front hub without issue. Therefore, if you are to carry a spare wheel tire it is recommended to carry the rear tire size on the spare. The thread will be separated into 5 parts:
    1. Spare tire placement options
    2. Attach bracket Mock-up and proof of concept
    3. Bracket fabrication
    4. Wheel installation
    5. Horn relocation. Guess where the wheel will be mounted?
    6. Review and observations
    wheel placement option 1, in wheel well...loose quite abit of storage and foot placement
    wheel placement option 2, on rear rack, loose aft storage
    wheel placement option 3, upright on rear rack, not ascetically pleasing, would need to fabricate a bracket to mount
    wheel placement option 4, on scooter side---like a pannier this would occupy the space of a pannier as pannier space is more valuable and would make the bike asymmetric.
    wheel placement option 5, front faring mount. This location provides a few challenges. The challenges include:
    1. clearance with front wheel faring
    2. wheel attachment to scooter
    3. Horn relocation
    4. loss of front load carrying capability
    5. headlight visability
    headlight is partially blocked, I'll need to "rake" the wheel as to limit headlight beam blockage
    will mount on OEM front rack
    disassemble rack, won't need these parts
    re-install rack
    quick wheel fit check, wheel contacts post
    trim post, need to tuck wheel as close as possible to scooter
    make bracket from aluminum rectangle bar stock
    fit about here
    drill oversized hole matching the front bracket
    trim attach flanges
    light deburr all mounting holes
    rough machined bracket, repeat process
    break edges with deburr tool
    add loop adhesive velcro to the bracket to front rack contact/touch points as to spare the finish of the front rack
    mount check
    wheel base-plate out of wood first, then metal
    trim with band saw
    wheel check
    attach base-mount to bracket interface to front rack
    attach to scooter
    mount wheel to baseplate
    scooter fit check
    no front fender contact
    still some headlight blockage, need to rake the wheel and will try another mount approach
    vespa GTS front wheel hub ($30 from e-bay)
    opposite side of hub, these hole attach to your front brake disc
    need to trim off small tabs to make a flush surface, easy-peasy as hub is aluminum
    trimmed hub
    trim down the large disc to accept the hub
    remove front decorative trim as the tire will tuck to a lower position, plug holes with fastener
    aluminum sheet stock, 6061-T4 .125 inch gage
    outline transfer from wood to metal
    blend corners at 1.5 inch radii
    cut on band saw
    deburr
    mount on bracket
    mount assembly on rack
    prime (2x coats) + paint (2x coats) the wheel hub
    mount assembly on scooter
    front view, notice the assembly blocks the horn and running light
    countersink fasteners
    attach hub with course thread M6 fastener, use blue loctite paste
    fit check, no tire contact with scooter or bracket, only hub
    front fender check, no issues
    view from top
    remove stebel horn from cavity. Stable horn install can be found here:
    [topic114292]
    will mount the horn here
    need additional hose and elbow hose couplers
    bond straight coupler into stebel nozzle
    mount with fastener here
    straight connecter bonded in horn hole
    thread nozzle hole thru bracket
    horn as attached
    horn/hose backside view
    assembly on scooter
    assembly front view
    need to thread horn hose thru plastic trim, no real other option
    connect horn hose with hose elbow connector, easy to disconnect if assembly needs to be removed
    horn mounted
    wheel clearance to top of front fender
    front 1/4 view, closer tucked wheel, no headlight blockage
    outside front view
    side view
    front 1/4 view
    horn mount side view
    horn front view
    headlight view from ground
    Mod review and observations:
    1. Additional piece of mind if need to conduct fix a flat where plug is insufficient
    2. Certainly will mount for any long distance riding
    3. No additional noise at hi-way speeds
    4. Stebel horn is perceived to be ~30% louder, from re-location
    5. assembly weight ~ 20 lbs, this will have benefit in cross wind conditions
    6. some increase in front impact crash worthiness
    7. benefit to other vespa riders if touring with GTS scooters
    Enjoy!
    Keithm
  2. JerseyBiker
    JerseyBiker Living the life!
    Jan 31, 2007
    4,537
    Almost Asheville, NC
    Outstanding!!
    This would have been great to have on my last Vespa. Once I added a top case in the rear the scoot developed a front tire wobble - I'm guessing due to the weight being so far back. This weight in the front might have cancelled out the wobble.
    In any event, an absolute fantastic job and terrific step by step instructions!
    :clap:clap
  3. rpclark
    rpclark Been here awhile
    Aug 25, 2008
    172
    Central OH
    Will it fit on the back?
  4. gogogordy
    gogogordy Long timer
    Feb 25, 2009
    3,005
    Winchester, Southern California
    As usual Keith very well done farkle.
    I'd make 2 suggestions:
    1) Protective "clear bra" circles on the paint, under the rubber cups
    2) Your voltage regulator's already minimal airflow has just been reduced even further...they get plenty hot in normal use with just the small amount of airflow the horncast allows in. On my GTS, I drilled several air holes in the plastic shroud the VR mounts above, on the throttle side radiator. Can't hurt and did I mention that VR gets hot as hell?
  5. klm4755
    Jun 19, 2006
    587
    Good comments, I'll take alook at directing some flow to the cavity, unaware the cavity usage was for VR cooling. I'll also need to add aux front turn signals as the tire/wheel blocks view from head on.
    Keithm
  6. klm4755
    Jun 19, 2006
    587
    Yes, the wheel would fit on the back rack, but at the loss of the racks cargo carry ability.
    Keithm
  7. gogogordy
    Feb 25, 2009
    3,005
    The VR lives on top of the black plastic right-side radiator shroud and gets very little cooling air.
    I'm certain you know how much electonics like heat...and Im not saying the VR wouldnt fail otherwise, but on the Vespas they are buried so uncharacteristically deep when compared to most other PTW's I dont see a down side to adding some cooling.
    Anyway...great mod (I mounted my Rotopax up front in a similar fashion) and very well executed and documented. thanks for sharing.
  8. gogogordy
    Feb 25, 2009
    3,005
    Add'l benefit: The add'l weight up front from my gas or your spare actually improves the ride and handling/braking IMO.
    #8
  9. conchscooter
    conchscooter Long timer
    Feb 3, 2007
    3,681
    Florida Keys
    Thats a very clever and well thought out piece of work. From my own experience with a GTS removing the rear wheel is unnecessarily complicated and difficult- dealing with the exhaust and the fragile bushing (I used the Moto Amore bushing which I'm told also crumbles after a while) and the impossible to move bearing in the support plate for the wheel. I loved riding the GTS but the original vespa concept of simplicity seemed to have got left behind on these four stroke machines.
    #9
  10. Warney
    Warney Been here awhile
    Jun 6, 2010
    568
    Omaha, Ne
    Excellent fabricating skills and a clever solution.:clap Changing a rear tire on the side of the road on a Vespa GTS is impossible without pliers, a breaker bar, multiple sockets, hex bit socket, torx bit socket, a socket wrench, extensions, and a torque wrench. Who carries all that? Then there is the matter of that fragile graphite bearing...
    Vespaman video
    http://www.youtube.com/watch?v=eUNXDSvpN7I
    Alternate method requiring even more tools
    http://www.youtube.com/watch?v=iSvFcNRFEuM
    #10
  11. klm4755
    Jun 19, 2006
    587
    Good point, I'd suspect it would be desirable to carry these tools while in touring mode. I'm in the process of fabricating a lockable metal pannier for storage. Here are a couple of shots of concept:
    pannier rack
    rack + metal ammo can
    left side of scooter, not yet fabricated rack to can mount....
    I plan on carrying the tool list listed within the pannier.
    Keithm
    #11
