Sudden Death Syndrome Re-visited
Discussion in 'Thumpers' started by itsagas, May 24, 2005.
  1. itsagas
    itsagas Adventurer
    Jan 22, 2005
    34
    Vancouver, B.C.
    If this hasn’t already been figured out and posted, here it is. I’ve got about 2200 Km on a 2005 640 Adventure and have encountered “Sudden Death Syndrome” three times. All have occurred at low RPM. The first occurrence, now that I think about it, was the most telling. The bike made a little compression cough and died. I took the problem to the KTM dealer and initially they were stumped. I kept on pushing and they kept on digging. This is the explanation that I got, and I think they’ve nailed it. The bike is new and not broken in. The jetting is stock and lean. These things contribute t a rough idle. When the idle is rough and bouncy sometimes the automatic compression release mechanism will engage and kill the engine. The answer; let the bike break in, play with the jetting, air box and exhaust until you are happy with the performance. At this stage the idle should be much more stable so you should be able set the idle speed lower while also preventing the auto compression release from killing the motor.
    Creeper,
    Your thoughts?
    Itsagas
  2. ChrisC
    ChrisC Amal sex?
    Feb 25, 2003
    6,325
    Prescott, Arizona USA Earth
    And your idle speed warm is set to what? :ear
  3. dagwood
    dagwood Banned
    Aug 25, 2003
    35,395
    Vancouver, Not! BC...
    just bump up th idle a couple hundred should fix that. sounds to low if it stumbles and the decomp starts clackin. Jet it and set the idle up. likes to have a high idle anyway. :nod
