stuck brakes
Discussion in 'Old's Cool' started by Bloodweiser, Sep 5, 2011.
  1. Bloodweiser
    Bloodweiser honestly
    Sep 12, 2007
    3,157
    way over yonder in the minor key
    So, yeah. I'm pretty green when it comes to most modern things.
    Keep that in mind.
    The calipers on my new-to-me RD where frozen.
    After a nice long afternoon I got both pistons moving,
    and was able to pump them out as far as I could before they bumped each other.
    But at this point, even after splitting the caliper in half,
    I still can't pull the pistons out completely.
    I've read a lot about using air pressure, or pumping grease in there
    but the caliper needs to be bolted together for either of these methods to work.
    Is there a puller or something to use at this point?
    I mean, what's a boy to do? :dunno
    Related: My rear MC doesn't pump fluid.
    I feel air pressure pulses if I cover the end of the banjo with my fingers,
    but couldn't get any fluid out the business end.
    Is there anything else I should check before I pick up a rebuild kit?
  2. Solo Lobo
    Solo Lobo airhead or nothing Supporter
    Mar 16, 2004
    13,668
    Shoreline, WA
    Split the halves, and use and air tip with your compressor to push out the pistons. Sometimes you can block the Passages using c-clamps and a bit of gasket material oar copper sheet.
    I Think with the pistons moving under fluid pressure, they should come out with air. The grease trip is for real lay stuck pistons.
