Mini Come Along?
Discussion in 'Equipment' started by EKhatch, Jul 30, 2012.
  1. EKhatch
    EKhatch Adventurer
    May 3, 2012
    62
    Let's say that hypothetically you end up off the side of some tight single track down the side of a mountain. Is there any winch/ratchet type device out there small enough to fit in a backpack to help retrieve a small dirt bike?
    Not that anything like that has ever happened to me and I was lucky enough to be with a group of guys to help but just in case. lol
  2. sierraoffroad
    sierraoffroad Long timer
    Oct 3, 2007
    1,358
    tolland, ma
    you could buy a pulley system that deer hunters use to hang deer before butchering, and or a boat winch?
  3. mac10
    mac10 Adventurer
    Sep 21, 2009
    68
    Look up whitewater canoe rescue gear. Some rope , a couple of carabiners, and some brains. Light, cheap effective and small. Commonly called a Z drag system. There are other variations. Used for retrieving pinned canoes weighing a couple of tons. A small bike should be easy for a z drag set up.
  4. Butters
    Butters Kwyjibo
    Oct 10, 2008
    14,793
    NoVA
    My old DRZ slid down off an embankment. Even though it is a lighter dual sport, I couldn't get the thing back up to the road. Luckily, a guy came by with an ATV winch. But I wondered the same thing. Of course, you need to be sure to bring along enough rope/cable to attach it to something.
  5. KawaYamaSaki Ho
    KawaYamaSaki Ho Reality burns!
    Jun 7, 2010
    257
    The Burnt Woods in the Rouge State
    Not sure of a small come along, I use 100' of parachute cord and four lightweight pulley's that can attach to tree's or other high enough to lift vantage's. It is compact (small thermos size ) and doubles as my clothesline and tie downs for my hammock. The parachute cord can also be used as a tow strap if in a pinch. YMMV, KYSHO.
  6. Yellow Pig
    Yellow Pig Allergic to asphalt! Supporter
    Oct 28, 2004
    10,575
    Thousand Oaks, CA
  7. nwdub
    nwdub Banned
    Jul 25, 2011
    1,097
    PNW
    A couple of snatch blocks (pulleys that attach to trees) and you could pull it by hand with a rope
  8. JohnnyWaffles
    JohnnyWaffles Long timer
    Jul 16, 2012
    1,023
    San Jose, CA
    http://www.adventureengineering.com/index.php/products/available-products/bringalong
    With a load limit of 600lbs, you're at maximum rated load capacity with most of the ADV bikes here. Know that a winch line snapping can cause some serious injury, even one this small. The reach of a flying, broken line can be limited by throwing your riding jacket or similar over the taught cable.
    I've never used the product but I do know winch safety from 4x4 experience.
    #8
  9. Flashmo
    Flashmo Whatever...
    Dec 21, 2008
    2,687
    Vagabond Hippie
    #9
  10. EKhatch
    EKhatch Adventurer
    May 3, 2012
    62
    Wow, great info everyone. There is a Happy Trails location near me as well so I will go check that out first.
    Thanks again. :thumb
    #10
  11. L.B.S.
    L.B.S. Long timer
    Feb 26, 2010
    1,919
    Just a couple reminders here.
    -Synthetic winch rope versus steel cable does not do the same thing when it breaks. It does not store any potential dangerous energy. You still have to be careful with it of course, if you attach the one end to a tree saver strap or a chain/whatever as these can stretch, snap and do the damage. Also be careful of rope burn and damaging the line with sharp edges.
    -Remember, snatch blocks/pullies will reduce the load by 1/2 for each one used, so add one or two, make the pulling easier (although it will take a longer amount of time to do the same work, and you will need that much longer a line) and reduce strain on rope and winch.
    #11
    CA-Cincinnatus likes this.
  12. Flashmo
    Flashmo Whatever...
    Dec 21, 2008
    2,687
    Vagabond Hippie
    Now you've given us your location......................................as there is only one Happy Trails. The town where the KLR is KING!
    In fact, it's just down the road from me (227 miles, road being I-84).
    :rofl
    #12
  13. EKhatch
    EKhatch Adventurer
    May 3, 2012
    62
    Turns out the company that makes teh EZ Pull is also located in Boise. Damn there are a lot of things made here or near by. Promoto Billet/Fastway, Rekluse, etc...
    #13
  14. GerryL
    GerryL Been here awhile
    Feb 1, 2010
    156
    western MA
    I've got a set of these that seem to work pretty good. I've lifted an engine block with them. They definitely fit the small requirement.
    http://www.akcooltools.com/hitchmaster.html
    I'd practice with them before you need them so you are comfortable setting the system up. Good mechanical advantage though!
    #14
  15. jonnyc21
    jonnyc21 Trials Ninja
    Feb 8, 2011
    4,467
    Boise aria
    #15
  16. the_gr8t_waldo
    the_gr8t_waldo Long timer
    Feb 28, 2006
    2,743
    tacoma warshington
    1st and formost, carry some rope to do this (real rope that carrys a rating that exceeds the requirement.. after that youre only adding tools to make it happen faster. i would suggest at least 100 foot of mule tape 2500 test.
    #16
  17. hogdoc
    hogdoc Been here awhile
    May 23, 2011
    258
    Id Ho
    Less than 3 miles up Eagle road for me. :D:D:D Nice to run by and pick things up on the way home from work! Rekluse is even closer.
    Lots of cool things invented/made in Idaho:clap:clap:clap
    #17
    bluemtnridr likes this.
  18. SnowMule
    SnowMule still learning what is and isn't edible Super Supporter
    Jul 2, 2009
    24,956
    I LIVE IN A GIANT BUCKET
    I carry rope and carabiners. I have one section of rope that's about 2ft, and another that's ~50ft.
    Use it mostly with snowmobiles, when those go down the side of a hill or into a tree well.... unless there's a way around, you're going to be digging and pulling on ropes/bunje's.
    It's come in handy with the bike once or twice before too.
    A few people that know what they're doing can get a stuck sled out pretty quick.
    #18
  19. RVDan
    RVDan Long timer
    Jun 4, 2010
    8,529
    Abbotsford British Columbia Canada
    it still stretches, it still stores energy, it still hurts when it whacks you. The experts disagree, but I was there. I still use synthetic line on my jeep though, because I believe it won't kill you like steel will.
    #19
  20. Gale B.T.
    Gale B.T. Long timer
    Jun 14, 2005
    1,857
    Pagosa Springs, CO.
    Mule tape for emergencies, I have lots , 0.05 a foot including shipping to lower US ie 100 feet, $10.00 shipped to you.
    Let me know with a PM
    gale,pagosa springs.
    #20
