Tool Bags
Discussion in 'Trip Planning' started by Doc True, Nov 13, 2008.
  1. Doc True
    Doc True Time Lord
    Sep 23, 2008
    201
    Stumbling around Loo'vul
    What recommendations does anyone have for storing tools and other gear such as chain lube, oil, and what not whil traveling? My current method is to have the tools in canvas rolls and the other hard things in plastic grocery bags. My problem is that the tools are slowly wearing through the canvas and the hard stuff in the grocery bags don't even make it through one trip. I'm worried about hardened tool steel wearing through my expensive and soft aluminum panniers.
  2. LostMan
    LostMan Desert Rat
    Dec 26, 2005
    257
    Just Below Tahoe
    bubble wrap
    small towels
    rags from heavy cloth
    1/2" thick foam pieces
    carpet pad
    Foam-Core 1/4 & 1/2"
    Velcro ties and blue tape
    I know what you're saying ... I had a bag of bits, sockets and assorted parts in a plastic bag, wrapped with a rag, in a tool bag on my dirt bike. Everything was polished like they had been in a bead blaster. Wrap the tool rolls and loose stuff tightly in padding. Tape or tie them. Even a thick rag like from a sweatshirt works well. I use foam sheeting too. Foam-Core board is very useful under and between items. You can make dividers and shelves in panniers. I try to tie or wedge things down so they can't bounce or vibrate. Sealed plastic containers are convenient for tightly packing the small stuff. Yada, yada.
    My $.02
  3. GreaseMonkey
    GreaseMonkey Preshrunk & Cottony
    Jun 16, 2006
    6,001
    The only county in Illinois with no train tracks
    I keep all my tools in a shaving bag, and I also have a small towel that I lay on the ground and put the tools on. I've never had a wear problem, but if I did I would simply wrap the towel around the shaving bag and wrap it firmly with a piece of cord or bungee strap.
  4. Lone Rider
    Lone Rider Registered User
    Jan 29, 2002
    26,342
    out and about
    I should get a decent tool roll, but I probably never will.
    I've worn through a few a few zip-closing bags, even one that was a tight, stiff canvas. A heavy (Courdura type) nylon bag has been holding up...so far.
    The laying a cloth on the ground idea is a good one. I wind up just dumping the bag, finding what I need, then refilling it after I'm done. Sometimes I'll have a couple of tools on laying each side of the bike - axle removal, etc. I've also left a few tools out in the boonies.
    A tool roll helps with organizing, and also helps keeping them to use another time. :D
    A flourescent tape or paint spot on the tools might also help.
  5. Boston12GS
    Boston12GS Banned
    Dec 25, 2005
    3,886
    Boston/Maastricht
    For long rides:
    Tool set #1
    Water-tight case fits in one side of Aerostitch pannier, with room enough for some bug spray and visor cleaner.
    Tool set #2
    Fits in other pannier pocket:
    Room on top for small air compressor (in freezer zip-lock bag):
    No torque wrench, but this lets me do just about anything that could reasonably be expected to be handled on long trips, including valve adjusts, oil changes, etc.
  6. HaChayalBoded
    HaChayalBoded Brooklyn Bored
    Oct 11, 2006
    8,357
    BRC \ NYC
    I've got a small MSR roll, they are less than $10, holds all my tools. For misc. stuff and spares I keep them organized in these
    http://www.sears.com/shc/s/p_10153_12605_00948426000P
    http://s.sears.com/is/image/Sears/00948426000?qlt=90,0&resMode=sharp&op_usm=0.9,0.5,0,0
    As you can see the big pouch has two pockets, the small pocket holds my motopump, a cigarette plug to SAE adapter just in case and a 6" bungee cord (to hold up the pump while its running so I don't have to).
    The large pocket holds a small can of WD40 a full sized set of reamers\pluggers that store inside its own handles which I never used and my tire patch kit (in an altoids tin) which includes patches, worms, valve cores, valve core removers\valvecaps, reamer and plugger with the handles sawed off (use vice grips to hold em) and two tubes of liquid cement, oh and a small folding razorblade. Yes all that fits in the altoids tin.
    The mid sized bag holds my electrical and misc. stuff which includes
    20ft of dual conductor zipcord wire (14g speaker wire)
    small set of ez outs in various sizes
    quick steel
    blue loctite
    sm, m, and l wormgears\hoseclamps
    zipties
    test light
    mylar bladder folded up (spare fuel carrier)
    6' 3\8" siphon hose
    credit card sized multimeter
    Motion Pro fork seal cleaning thingy
    wire stripper\crimper
    and a small electronic plastic box with dividers for
    20ft electric tape (rolled over itself to about the size of a 14mm socket)
    3 different sized heatshrink cut into 3" sections
    wire taps
    male and female spade crimps in 8-12g and 14-18g
    ring terminals in 8-12g and 14-18g
    assorted posilocks (the case is a posilock case)
    mini DPDT switch with wire and male spade connectors soldered on
    extra set of battery bolts and nuts
    the small bag replaces the cheap OEM toolkits in all the bikes and in it are oddball OEM tools for all the bikes. Also rarely used tools. In it are
    spark plug sockets for various bikes
    large and angled 22 and 27mm axle wrenches
    handle for above which doubles as chain slack guide for certain bikes.
    shock adjusting tool
    Torx bits
    MSR tool roll contains
    channel locks
    6" needle nose vice grips
    6" craftsman beak nose adjustable wrench (opens to 32mm)
    6" craftsman prybar with fuse pullers on the ends to keep it from tearing anything
    needle nose pliers
    dykes
    8-17mm box and double ended wrenches
    6" hex bit extension with hex bit-1/4" adapter on the end
    husky 1\4"x5\16" ratchet
    in the pouch on the tool roll are
    spark plug gapper
    motion pro tire buddy
    motion pro 3" extension driven by 1\4" ratchet or 14mm socket\wrench or a screwdriver and it drives a 3\8" wobble
    3\8" to 1\4" reducer for the above extension
    and an altoids tin which contains
    8, 10, 12, 13, 14 sockets (1/4")
    8, 10, 12 deep socket
    3" locking extension
    10mm wrench\socket driven 1\4" hex bit holder
    1\4" square driven magnetic 1\4" hex bit holder
    1\4" magnetic hex bit (just a magnetic picker upper)
    3, 4, 5, 6mm hex, 00, 01, 02, 03 phillips, s, m, l flathead bits
    and yes all that fits into the altoids tin
    tire irons are on their own, along with some custom jumper cables
  7. HaChayalBoded
    Oct 11, 2006
    8,357
    BRC \ NYC
  8. colomtnbiker
    colomtnbiker wimpy old guy
    May 17, 2005
    614
    mountains of western Colorado
    I take a lot of tools with me on trips but I have found when I pack my panniers, if my tools are to bulky, it takes up to much room. So I use a couple of bicycle rollup packs for the heavy tools and ziplocks for the smaller fuses, wire, tape, etc. This way I can pack my stuff in voids.
    #8
  9. HaChayalBoded
    Oct 11, 2006
    8,357
    BRC \ NYC
    thats why I use the small bags, depending on the bike I will put all those little bags in a military medic\mechanic bag thats a small 6x6x10, or I will keep them seperate, putting the pump bag, 'lectric bag, and misc. bag under the seat and the tool roll either in a pannier or tankbag pocket. jumper cables sit in the cruiser.
    #9
  10. Lone Rider
    Jan 29, 2002
    26,342
    out and about
    I keep meaning to go to the large tackle store in town and get some of those small plastic boxes they use for hooks, lures, etc.
    Would be good for things like valve cores, patches and glue, and other small stuff you don't want meshed in with the heavy things.
    #10
  11. HaChayalBoded
    Oct 11, 2006
    8,357
    BRC \ NYC
    You probably won't find a small one, the little ones I have are from containers that once housed either posilocks, nuts\bolts, electrical parts, e.t.c. Next time you need those types of things find ones that come in a "mini" tackle box. Also, hit an autoparts store if you ever need any tire repair stuff, they make a "tire tackle" kit, which is a small tackle box thingy with tire repair stuff, costs about $2.99, worth it just for the box and maybe a couple of items in it.
    #11
  12. isa671
    isa671 blah blah blah....
    Jul 22, 2007
    263
    SF
    This is what I use for the little stuff. There's a lot of room when you utilize the dividers. You can get them at Target for $12.49. The only problem is that it takes about half of the space of my HT panniers. Definitely worth the price and the piece of mind.
    http://www.target.com/DBL-LOCK-DOUBLE-COVER-LOCKJAW/dp/B000HJ9514/sr=1-19/qid=1226713689/ref=sr_1_19/177-7922748-8565310?ie=UTF8&index=target&rh=k%3APLANO&page=1
    #12
  13. Lone Rider
    Jan 29, 2002
    26,342
    out and about
    I'm not riding a Wing with trailer. :D
    I know what you're saying, but I stuff my tools and other things.
    #13
  14. BSK
    BSK Ohhh mist! Die Bullen!!!!
    Apr 23, 2006
    419
    The mountains in Germany
    I use an old laptop bag from compaq. works fine
    #14
  15. Greg MacD
    Greg MacD Been here awhile
    Aug 13, 2008
    496
    State of Confusion
    Sears and other home stores always sell "Tool bags" most are a duck type canvas, but a heavy material that wont wear thru easy.
    I use an aviation headset bag made of nylon and is padded, the bag works great for me.
    The small "pelican" case is also a great idea, they are impossible to break, we use them for shipping items at work. the bonus is they are weather resistant too, so all your tools wont rust if the box gets wet.
    #15
  16. sleak
    sleak TANSTAAFL
    Sep 13, 2008
    119
    Helena, MT
    I just got a set of these. Their stuff seems to stand up to a lot of abuse. I guess I'll see how these stand up.
    Go to www.duluthtrading.com and search for item 28094.
    :slurp
    #16
  17. heetseeker
    heetseeker Hopelessly addicted
    Oct 9, 2007
    373
    Wilton CA
    I carry 2 bicycle tool bags made by Bell, found at Walmart. They have a hard plastic bottom with a large and small pocket area. Very tough and about ten bucks each. One in each tank panier is enough tools to take care of just about anything on the road.
    #17
  18. ajayhawkfan
    ajayhawkfan Rock Chalk
    Dec 29, 2006
    6,563
    Kansas City, MO
    I found my tool bag at Bass Pro Shop. It was a soft sided tackle box. It is very sturdy and had side pockets. It cost less then $15.
    #18
  19. dfwscotty
    dfwscotty Long timer
    Apr 9, 2006
    4,059
    Denton, TX
    #19
  20. drakehouse
    drakehouse Burnin' & Turnin'
    Nov 30, 2008
    141
    Pruned up from swiming in the sea of life
    Found a great canvas bag at a G.I. surplus store (camp supplier) It has held of for over 10 years of use. It is rubber coated and keeps things dry. Very flexible.
    Another idea (have you ever been caving) They use build a pig. They take old gas cans. Cut the tops off each. One will fit into the other. For you cycle, think of using plastic qt oil bottles. They will hold your tools, Wont wear thru like your soft canvas/cotton/rags/socks and if it does not work. You have tried your part at being green and recyling a used product.
    #20
