gs 100 bumble bee tire?
Discussion in 'Airheads' started by Backmarker, Mar 4, 2011.
  1. Backmarker
    Backmarker Long timer
    Mar 23, 2005
    1,267
    Bought new frt. and rear tires for a gs 100. The frt. tire is marked tubeless the rear tire says tube type. Both tires are the same model just different sizes. Is it ok to run the rear tire without a tube like the front or should I use a tube in the rear?????? The gs wheels are made to run tubeless tires b.t.w..:ear
  2. fishkens
    fishkens Long timer
    Nov 14, 2009
    5,511
    Seattle, WA
    Here's a friendly tip: when asking questions about tires no one really cares what color the bike is. But, responders would be interested in the specific tire you purchased, esp. considering the discrepancy between the front and back as you describe.
    In general, if the tire says "tube type" then run a tube. But, if you provide info on the specific tire you bought you might get responses based on experience.
    For example, I've run IRC GP 110s on my GS (on the rear) and they were tube types. I've run 'em both w/ and w/out tubes. Never ran the GP 110 on the front though.
  3. Backmarker
    Mar 23, 2005
    1,267
  4. Toyanvil
    Toyanvil Adventurer
    Feb 8, 2004
    2,071
    Bakersfield CA
    When I order tires for my red and white GSPD :D, the same tires could be order in tube or tubeless. I would replace it with a tubeless, as the bead will be different.
  5. Albino Reino
    Albino Reino Junky
    Feb 13, 2006
    700
    The Great Sage Basin
    I have a teal and black PD and have always gone tubeless. I suppose the bead on the tire would be an issue but, I always thought it was the design of the rim. The spokes are located on the outside of the wheel rather than in the middle so there is no air loss. My 2 cents.
  6. Backmarker
    Mar 23, 2005
    1,267
    Yes but what I really need to know is, will that work on a yellow & black model..:D
  7. fishkens
    fishkens Long timer
    Nov 14, 2009
    5,511
    Seattle, WA
    Cute. You'd think that someone who's failed to get an answer in 3 1/2 days would appreciate a friendly tip. But you decide to flip me off.
    Classy.
  8. bgoodsoil
    bgoodsoil Dare to be Stupid
    Jul 9, 2008
    4,724
    Washington, DC, USA
    #8
  9. Steve G.
    Steve G. Long timer
    Oct 30, 2004
    16,658
    West is the Best
    Generally, the yellow & black models use the same tires as the white/red models, the purple models, the green models, the white & blue models, and lets not forget the red models with the tire tread on the tank, especially those ones.
    Of course I've seen many use other tires than ones you may see on the yellow & black models. You never can seem to pin down those yellow & black models, they can be tricky as heck. I've seen them with other types of tires before, kind of black tires, with tread all round. And surprisingly roundish.
    I hope this clears up what has started out as a totally stupid question offering very little info to anyone who may have the kindness to answer.
    Now go away unless you can offer Fishkens an apology and give us some basic info on the type of tires you bought so we can answer your question.
    Steve
    #9
  10. Backmarker
    Mar 23, 2005
    1,267
    Steve. My first post asks a simple question. The color of the bike makes no difference. Why Mr. Fishkens even brought up the bike color is beyond me. Hence my responce to his attack on me for posting the color of my bike. Why is my org. post (a totally stupid question)????The type of tires I bought is in the org. question (frt. tubeless,rear tube type) both the same model. By post # 6 the color was a joke..
    #10
  11. gronk
    gronk HIGH ANGLE RIGGER
    Dec 20, 2006
    341
    Very High Above Ground!North of The 49th parallel
    My Camo ride's on Bullet proof run flats while riding in war zones.:deal
    #11
  12. bikerfish
    bikerfish flyfishandride
    Aug 18, 2010
    4,769
    western pa
    my gs is flat black, what the hell tires should I use??!!
    BTW, I see nothing wrong with the original question.
    I've actually wondered about that as well, what the actual difference is between tube and tubeless. maybe a small difference in bead design to hold air better? it can't be to hold the tire on the rim better, the tire really doesn't care if it has a tube inside it or not, the air pressure pushing against the inside of the tire will still be the same, tube or no tube.
    #12
  13. Backmarker
    Mar 23, 2005
    1,267
    btw, Mr. fishkens gave you the benefit his tire mounting experiences in post 2 ... which you seem to have missed.
    :dunno[/QUOTE] Nah, didnt miss it I acknowledged it in post #3 before I gave him the adv salute.:D
    #13
  14. Backmarker
    Mar 23, 2005
    1,267
    As far as I can tell both beads appear to be the same. I think I"m going to install a rear tube just to be safe. However I would like to know why the tire manufacturer requires a tube in the rear but not the front of the same tire. Thanks for the reply.
    #14
  15. Ullr
    Ullr C+ Racing
    Feb 18, 2006
    823
    PAMR
    Why not just tell us what tires they are? You just might get a good answer.
    #15
  16. Backmarker
    Mar 23, 2005
    1,267
    Tire brand should not matter and would only pit a war against brand a. vs. brand b. etc.. The question is, why make the front tubeless and not the rear. Is it safe not to put a tube in the rear If you have a tubeless rim?
    #16
  17. bmwblake
    bmwblake upside down parker
    Mar 3, 2004
    3,294
    nashville, tn
    i run tube type rears without a tube on my r100gs a good majority of the time. take that for what it's worth.
    #17
  18. Backmarker
    Mar 23, 2005
    1,267
    Thanks and its worth a lot..
    #18
  19. eric123
    eric123 Gott Mit Uns
    Mar 26, 2009
    1,537
    Idaho
    So...What kind of oil do you guys use? :ear
    #19
  20. marksbonneville
    marksbonneville Long timer
    May 12, 2008
    1,337
    Arizona, Prescott more less.
    It all depends on the color of the bike.
    #20
