Bulb exploded!
Discussion in 'GS Boxers' started by Osmin C, Aug 6, 2014.
  1. Osmin C
    Osmin C Been here awhile
    Jul 24, 2012
    111
    SoCal
    So, my second bulb went out today at 28300(ish) miles while on my way to work. For no particular reason, I looked at the bulb through the front of the headlight housing and realized it not only went out, it shattered inside.
    I searched and found no other examples of this happening. My concern is that now I have tiny shards of glass inside of my headlight assembly. Has anyone experienced this? Any tips on how to remove all of the shards?
    Any advice is appreciated. Thanks! :D
  2. LaurelPerryOnLand
    LaurelPerryOnLand Long timer
    Jun 9, 2009
    3,482
    Denver, CO
    Take out broken bulb...WHEELIE?:rofl
    Otherwise..VACUUM with small crevice attachment (don't have one?) or reverse the thought and BLOW OUT?:huh
    Don't think that any remaining (after vacuum/blowout) small pieces of shard will present any problems if you don't get them all.
  3. marchyman
    marchyman barely informed Supporter
    Jun 30, 2005
    20,836
    SF Bay Area
    Not sure about the GSA, but the GS headlight assembly comes off in about 45 seconds. Take it off, pull out the remains of the old bulb holder, turn the headlight up, and shake. Most of the stuff will come out.
    Or use a vacuum as LaurelPerryOnLand suggested. Or a combination of both.
  4. Osmin C
    Jul 24, 2012
    111
    SoCal
    Should be the same process. What should I be looking for in order to get it out?
  5. JimVonBaden
    JimVonBaden "Cool" Aid!
    Feb 11, 2005
    101,516
    Alexandria, VA
    Three bolts and the connector. Ignore the arrows. The connectors are right and left and bottom center.
    Pull the headlight, remove both bulbs and shake. You will get 99% out.
    By the way, not common to see a bulb pop, unless it was installed with greasy fingers.
  6. Osmin C
    Jul 24, 2012
    111
    SoCal
    Thanks Jim! I try to be careful when installing, but might have slipped up last time 'round.
  7. def
    def Ginger th wonder dog
    Feb 28, 2004
    14,308
    The woods and mountains of Alabama
    Jim, I assume that is your headlight in the photo? Are both low and high beam HIDs? If so, do you miss the flash-to-pass of an incandescent?
  8. rideLD
    rideLD The further the better!
    Jul 15, 2004
    5,412
    Omaha, Nebraska
    Its very rare for a bulb to explode. I have heard that touching bulbs with bare skin leaves an oil on the bulb which causes hot spots which will eventually cause it to explode. Could that be what happened?:ear
    #8
  9. JimVonBaden
    Feb 11, 2005
    101,516
    Alexandria, VA
    Nope, I don't miss it because it still works as well as the non-HID did, contrary to popular belief.:deal
    #9
  10. Oggie
    Oggie Been here awhile
    Feb 24, 2012
    129
    NOVA
    ha, is that what that thing is supposed to do.. Might need to tell the cagers here in in DC.....:rofl
    #10
  11. Callisto224
    Callisto224 Long timer
    Jan 5, 2010
    10,695
    Atlanta(ish), GA
    This!
    You can have clean hands and still leave a bit of oil from your skin on the bulb. Eventually the bulb will get hot enough and explode. Next time use gloves (or even a paper towel) when installing the bulb. :deal
    #11
