Salt Pilot sub-frame?
Discussion in 'Airheads' started by Evo1, May 20, 2014.
  1. Evo1
    Evo1 Been here awhile
    Feb 24, 2014
    134
    Sydney
  2. Big Bamboo
    Big Bamboo Aircooled & Sunbaked
    Sep 29, 2010
    17,403
    Big Island of Hawaii
    Would not buy. There are so many questionable design choices; curved uprights, single sided top shock mounts, <- mounted on curved uprights, no cross brace... etc
  3. Evo1
    Feb 24, 2014
    134
    Sydney
    But if the bike isn't a racer, then how important are those issues?
    I'm after something bolt on that I can attach myself. I've seen the Vonzeti items and those don't look much better.
    Getting a fabricator to put something together won't be cheap either.
  4. Big Bamboo
    Sep 29, 2010
    17,403
    Look how the factory did it. The top shock bolts are supported in two axis and from both sides. That one pictured is supported on one side only and welded to presumably thin wall tubing, in the middle of that tubing, and it's already BENT... :huh What could possibly go wrong...? Racing or not, I see a lot of stress being placed on that brace and welds. Why not modify the stock one?
  5. Evo1
    Feb 24, 2014
    134
    Sydney
    Understood. But how much stress is going through the rear subframe? Isn't the main stress in the actual main bike frame?
  6. Big Bamboo
    Sep 29, 2010
    17,403
    The triangles formed by the stock subframe supports the entire rear end of the bike through the shocks, big heavy final drive and all... True, they basically eliminated the need for it on the Monolever bikes, but added a big cast chunk to hold the shock... :deal
  7. infinityedge
    infinityedge Long timer
    Jun 27, 2013
    41,421
    Tuolumne County
    Where do you think the force on the shocks winds up?
  8. robtg
    robtg Long timer
    Jun 29, 2007
    2,003
    san jose
    Total piece of shit.
    #8
  9. Evo1
    Feb 24, 2014
    134
    Sydney
    Cheers guys. Appreciate the feedback.
    My quest for a new rear subframe continues!!! With all the bikes being built these days its a shame no one does a quality item. I'd pay my money on the spot!
    #9
  10. Evo1
    Feb 24, 2014
    134
    Sydney
    #10
  11. east high
    east high Long timer Supporter
    Oct 13, 2009
    1,499
    The Lost Coast, CA
    You talking about the silver frame with orange snowflakes? That subframe is close, but not the same as the one on ebay.
    #11
  12. chollo9
    chollo9 Screwed the Pooch
    Jul 7, 2003
    1,628
    Silk Hope, NC
    IMHO, having spent quite a bit of time in both, the daily grind is often harder on chassis than racing. Race tracks are generally smoother and more predictable.
    Now engines, on the other hand . . .
    #12
  13. Evo1
    Feb 24, 2014
    134
    Sydney
    OK thanks. To my untrained eye they looked the same!
    #13
  14. Jim K in PA
    Jim K in PA Long timer Supporter
    Mar 15, 2011
    7,011
    Pocono Mountains, PA
    That frame connector is pretty unique.
    #14
  15. Padmei
    Padmei enamoured
    Mar 12, 2008
    4,116
    Nelson New Zealand
    Yeah Thats what I thought when I first saw it. Whether they may or may not work is debatable however he's made a nice job of that - nice lines.
    Can't work out how the rear brake works unless there's a disc on the other side.
    #15
  16. Jim K in PA
    Mar 15, 2011
    7,011
    The only area of structural doubt is that clamped front mount on the tube. I would have welded an elongated tab there to capture the leading mount point.
    Stock rear disk. You can see the caliper stay and the vented rotor holes if you look through the wheel right below the muffler.
    You can also see more pictures if you follow the links.
    #16
  17. chollo9
    Jul 7, 2003
    1,628
    Silk Hope, NC
    Could be wrong, but that mount looks to be a curved strap (something along the lines of a band cut in half) welded to the downtube, not a clamp. I didn't see the other pics, though.
    #17
  18. Kai Ju
    Kai Ju Long timer Supporter
    Jul 29, 2009
    7,094
    Long Beach, California
    It sure is. That S-curve really screws it up for me though since it essentially becomes a spring under compression, at least in theory. I think it would have been better, and looked better, if he had come forward in a straight line. Also the front mount looks a lot like the stock horn mount, which is actually overbuilt for holding a horn, but might just work for a frame brace.
    Having said all of the above, it probabaly still adds to the frame stiffness, just not as much as it could.
    #18
  19. Jim K in PA
    Mar 15, 2011
    7,011
    I looked again, then at my frame, and it is the horn mount. Which is ironic, since I was thinking of using that mount for a frame stiffener before I saw that picture, but completely forgot about it when I posted.
    I agree that either a straight tube, or two complimentary arced tubes would be stiffer than the s-profile. Depending on what you are trying to accomplish, this may be adequate, and does not add as substantial a stress concentration point(s) to the frame.
    #19
