Am I crazy?
Discussion in 'Parallel Universe' started by JGoody, Jul 7, 2012.
  1. JGoody
    JGoody Been here awhile
    Nov 20, 2011
    296
    Tendonitis in left (clutch) hand -- driving in traffic irritates it. The front brake is much lighter. Is it insane to think of the clutch on the right, brake on the left? Could the perches and handles be swapped? Is this asking for a giant accident? Has anyone else tried this?
  2. castroses
    castroses Adventurer
    Mar 12, 2011
    78
    Glasgow, UK
    Are you confident you can 're-programme' your brain to pull the correct lever in the event of an emergency stop??:huh
  3. KG6BWS
    KG6BWS Been here awhile
    Jul 12, 2010
    895
    Lancaster, Ca
    x2. I know I sure as hell couldnt do that.
    Sure its not something like carpal tunnel?? My dad had that and said it felt similar to tendonitis. Surgery fixed it.
  4. Deuce
    Deuce Crazy Canuck
    Nov 30, 2001
    3,676
    Vancouver Island, Bitchin' Columbia, Canada
  5. KG6BWS
    Jul 12, 2010
    895
    Lancaster, Ca
    He brings up a good point. WHat about putting in a Rekluse clutch?? The way I understand it, you only use the clutch when coming to a stop. To prevent you from having to hold the lever in, kick it into neutral as you stop and let the lever back out.
    Edit - Just found this on their site.
    Do I have to use the clutch lever?
    You have the option of using the clutch lever at any time, but it is not necessary. Some riders find that they rarely use the clutch lever to override the Auto-Clutch and choose the Rekluse Brake Kit. The Rekluse brake kit replaces the clutch lever with a left hand brake lever to actuate the rear brake. Note some models come with a 2-Finger Override lever to retain the clutch override feature.
  6. JGoody
    Nov 20, 2011
    296
    This is the question!! I have switched from right gearshift (old British style) so maybe... The irony is that I actually like manual transmissions -- have them in my cars! I don't think they make a Rekluse clutch for my F650 GS twin. Wondering if anyone has tried the switch -- guess not.
  7. 990
    990 Krap To Maintain
    Apr 10, 2011
    192
    East London ZA
    What about a hydraulic clutch from toura twot?
  8. Jooka
    Jooka I grow everywhere
    Apr 6, 2010
    39
    Boulder
    Was Jimi crazy? If it makes it work for you, it works.
    #8
  9. JGoody
    Nov 20, 2011
    296
    They tell me that will not fit the F650GS Twin.... I'll probably try the Moose Racing box maybe with an aftermarket lever. I am confused about how it (or a new lever) can reduce effort without compromising engagement / disengagement. But I'll give it a try before making a dyslexic motorcycle. I was hoping some one would have gone there first.... oh well....
    #9
  10. jackalsour
    jackalsour Xennial
    Dec 14, 2010
    1,106
    Transient
    You mean like re-programming our brains to use the BMW indicator switches and horn? :huh
    #10
  11. Snowy
    Snowy Long timer
    Dec 2, 2008
    2,608
    Rekluse don't list a clutch replacement for the BMW - AFAIK.
    I've been checking regularly.
    #11
  12. KG6BWS
    Jul 12, 2010
    895
    Lancaster, Ca
    Nope, not for the twin. They do for the F and G singles.
    #12
  13. Otisguy
    Otisguy n00b
    Jan 22, 2012
    4
    Chattanooga TN
    Of course you can.Ride your bicycle until left
    hand front brake becomes natural and take off.
    #13
  14. Kitedans
    Kitedans In love with my AT !!
    Dec 9, 2009
    39
    Catalonia - Spain
    Take a look at the Twalcom/Magura hydraulic cluch for f800gs, that coul help a lot !!
    #14
  15. JGoody
    Nov 20, 2011
    296
    Will not fit F658 -- checked with Twalcom.
    #15
  16. LukasM
    LukasM Long timer
    Nov 15, 2006
    5,513
    On a RTW ride - currently touring the U.S.
    Bullshit, they just don't have a clue. There is nothing different between the two bikes in this regard.
    Both clutch perches are exactly the same part, if the cable/hose length is different by a tiny bit it won't matter.
    #16
  17. JGoody
    Nov 20, 2011
    296
    That's weird -- they claimed they check with Twalcom --- I'll email them again. Are the internals of the clutch different? Would that matter?
    #17
  18. JRP
    JRP Old guy Supporter
    Apr 4, 2004
    1,634
    Hampden, MA
    The F800 has larger diameter bars, that could be what they mean. The F800 bars are tapered though so the clutch mounting lever should be the same.
    #18
  19. LukasM
    LukasM Long timer
    Nov 15, 2006
    5,513
    No, it's not. Just like on (all) other bikes the thicker F8 bars are tapered with 28mm (1 1/8") in the center, and 22mm (7/8") on the outside. Industry standard.
    #19
  20. JRP
    Apr 4, 2004
    1,634
    Hampden, MA
    I corrected myself as you were proving me wrong :D
    #20
