What's involved in removing this??
Discussion in 'Airheads' started by ScottishAirhead, Nov 14, 2014.
  1. ScottishAirhead
    ScottishAirhead Been here awhile
    Oct 24, 2014
    139
    Glasgow, Scotland
    Hi guys. What's involved in removing the finned part at the front on the engine. I want to get it blasted and painted. Anything special to look out for??
  2. Caddy82rats
    Caddy82rats Long timer
    Mar 8, 2007
    1,365
    South France
    nothing special, no specific tool
  3. ScottishAirhead
    Oct 24, 2014
    139
    Glasgow, Scotland
    Do I need to do anything special with the crank? Block it up ect ?
  4. Big Bamboo
    Big Bamboo Aircooled & Sunbaked
    Sep 29, 2010
    17,403
    Big Island of Hawaii
    You will need the special hardened bolt/tool to remove the alternator rotor. It may help to heat the area around the front crank bearing, so it doesn't come off with the cover. Upon reassembly, don't forget the small round paper gaskets on the top two studs. Flywheel will hold the crank from moving forward, assuming it's still mounted...
  5. rambozo
    rambozo Been here awhile
    Feb 20, 2012
    763
    Armagh, Northern Ireland
    There is a special tool needed to remove the rotor off the end of the crank, it's
    basically a bolt with an end, snowbums page which you were given a link to, has
    directions on a home made one, or you can buy this -
    http://www.motorworks.co.uk/vlive/Shop/Parts.php?T=6&Q=Rotor+removal+tool&x=0&y=0
    This one is from motorworks, I have the one from Shaw stainless, same thing. The
    rotor can come off with some force, someone on here, wirespokes I think, recommended
    catching it in a box which is good advice, or advise, depends who's giving it :D
    Edit, bamboo types quicker than me!
  6. Disston
    Disston ShadeTreeExpert
    Aug 31, 2009
    22,034
    Silver Spring, Md
    Buy a new gasket and the two small donut gaskets. That is the timing chain cover. Under it is the inside of the engine. Keep it clean.
  7. supershaft
    supershaft because I can
    Sep 9, 2010
    9,116
    San Francisco Bay area
    You will need something to heat the timing chain cover with as well. Putting the diode board back on without the right tools is a pain too. I use quarter inch Snap-On flex sockets.
    Painting that cover is going to make the rest of your engine look real bad. Personally, I would clean it up real good and re-sand the ribs and what for when you need a timing chain and crank sprocket before I pull that cover.
  8. ScottishAirhead
    Oct 24, 2014
    139
    Glasgow, Scotland
    What would be the best way to clean it up? I think i can see old paint flaking off it
    #8
  9. bmwrench
    bmwrench Long timer
    Nov 10, 2006
    10,195
    Clean it with your favorite solvent, than soap and water. When dry, bead blast it. Wash it again, then paint it if you wish. Sand the ribs if you want it to look like new.
    #9
  10. Rob Farmer
    Rob Farmer Long timer
    Aug 27, 2002
    7,500
    Vale of Belvoir - Nottinghamshire
    A phosphide acid based cleaner (wonder whells etc) and a small stainless brush will bring your cases up but you must wash it down with an alkaline based cleaner after.
    Poweder coat the front case and then painstakingly clean the powder off the fins and other surfaces.
    #10
  11. ScottishAirhead
    Oct 24, 2014
    139
    Glasgow, Scotland
    Looks amazing.. Exactly what I'm aiming for. Will Probably paint instead of Powdercoat tho
    #11
  12. Beemerboff
    Beemerboff Long timer
    May 23, 2005
    4,191
    Adelaide, South Australia
    Most of the flaking seem so be on the end of the ribs , so Supershafts advice to sand the ends without removing the cover seems sound.
    Clean up the existing paint with a good cutting polish, then finish it off with black Rub-N-Buff which will fill in thr scratches and nicks.
    #12
  13. ScottishAirhead
    Oct 24, 2014
    139
    Glasgow, Scotland
    Got it off earlier no bother. Made my own bolt for pushing the rotor off. Slight heat to remove the casing and that was it. 20 min job. I will take it into work and use our glass blaster in it (it might not be aggressive enough).
    Thanks for all the great advise guys
    #13
  14. ScottishAirhead
    Oct 24, 2014
    139
    Glasgow, Scotland
    My next job once I clean up the timing casings is to remove the engine. Got the rear mounting bolt moving with a 3lb hammer. The front however seems solid. Will try some heat tomorrow.
    I've also got the sump off to blast it clean. Took the strainer screen off and it is perfectly clean in there.. Result!!!
    #14
  15. Airhead Wrangler
    Airhead Wrangler Long timer Supporter
    Mar 4, 2008
    7,275
    Back in Seattle, FINALLY
    Careful with that. Though I've never personally ruined an engine that way, a lot of people (even car companies) will tell you never to use glass bead to blast anything that gets exposed to motor oil. Microscopic shards of glass embed themselves in the surface of the part being blasted and don't come off when washed with water or blown with compressed air. When the part gets reinstalled and the running motor heats up and expands the part, the shards of glass get released into the motor oil causing big damage to bearings.
    #15
  16. ScottishAirhead
    Oct 24, 2014
    139
    Glasgow, Scotland
    I've never heard of this. My friend has an ex Rolls Royce wet blaster which uses water and glass. He uses this all day every day on engines. Il maybe take it over to him instead.
    #16
  17. ScottishAirhead
    Oct 24, 2014
    139
    Glasgow, Scotland
    Guys with regards to the required gaskets... I can see the main paper gasket but where are the two smaller gaskets located??
    #17
  18. Disston
    Aug 31, 2009
    22,034
    Silver Spring, Md
    The parts picture only shows one. The other is to it's left. They are both under a couple of the attachment bolts holding the cover on. If they are left off the cover may warp and bend, we are told. The really weird thing about the "donut" gaskets is they are sold separate from the main gasket and you have to buy 2.
    #18
  19. ScottishAirhead
    Oct 24, 2014
    139
    Glasgow, Scotland
    Number 9 then? I swear there wasn't any fitted. I've checked everywhere.
    Ok thanks il get them ordered up
    #19
  20. chasbmw
    chasbmw Long timer
    Feb 19, 2006
    3,831
    Bath Uk
    Before getting the lump hammer out, try drawing the front mounting bolt out using the nut and various washers and spacers. The front mounting bolt picks up all the salt and other crap thrown up by the front wheel, lacks any lubrication from gearbox oil leaks :rofl:rofl and can be a bugger to remove. When replacing use lots of copaslip.
    #20
