Old 11-26-2013, 01:37 PM   #46
Sticky Throttle
Happy wanderer
Sticky Throttle's Avatar
Oddometer: 71
Originally Posted by trc.rhubarb View Post
Before you buy an acrylic shield, check out this video and know the difference.
Useful info as well as hilarious, Sir Rhubarb. How can I join the NationalCycle testing crew?
2014 BMW R1200GS
2013 BMW K1300S
2010 Bonneville T100
Sticky Throttle is offline   Reply With Quote
Old 11-26-2013, 02:20 PM   #47
Sticky Throttle
Happy wanderer
Oddometer: 71
Polycarbonate vs Acrylic
BTW, I assume the stock BMW screen for the water boxer is polycarbonate? Please advise.
2014 BMW R1200GS
2013 BMW K1300S
Old 11-26-2013, 08:52 PM   #48
IrishCatholic OP
Oddometer: 72
Originally Posted by despistao View Post
The wunderlich reinforcement support fits to any screen wich uses the standar fitting points (most of the aftermarket ones) and can be bought separately
Nice, thanks!
'Thanks to the interstate highway system, it is now possible to travel across the country from coast to coast without seeing anything.'
- Charles Kuralt, On the Road
IrishCatholic is offline   Reply With Quote
Old 11-27-2013, 02:14 AM   #49
pebe
pebe's Avatar
Oddometer: 72
Originally Posted by IrishCatholic View Post
Two questions:
1. Just to clarify, you fitted a Wunderlich support to the Puig screen, correct?
2. If you own a Wunderlich support, it stands to reason you own a Wunderlich screen too - if so, do you prefer the Wunderlich or Puig screen?
Thanks, in advance, for your reply.
1) Yes
2) Only purchased the Wunderlich support
* Puig screen is super :-)
pebe is offline   Reply With Quote
Old 11-27-2013, 09:47 AM   #50
kindofblue
Ride it like you stole it
kindofblue's Avatar
Oddometer: 829
Originally Posted by pebe View Post
I mounted the Wunderlich support bracket and now the screen is perfectly stable in any condition.
Hi, I took a look at this support on their site and then looked at the bilateral supports for the brackets that are stock. I'm not quite sure how this increases the stability of the windscreen. Would you please explain? Thanks.
Doc Reid
Wondering about your drinking? www.drinkerscheckup.com
Get saddlesore when riding? Check these shorts out
kindofblue is offline   Reply With Quote
Old 11-27-2013, 10:34 AM   #51
pebe
pebe's Avatar
Oddometer: 72
The larger screen "wobbles" in turbulent air (when riding behind another vehicle) or flexes backwards at speeds above ~80km/h (~50mph)
The lower part of the stock support brackets are plastic and flex in conditions as described above.
The Wunderlich support bracket is an additional position where the forces on the screen are distributed by, resulting in a stable screen.
(Hope this makes sense as English is not my mother tongue)
Sent from my iPad using Tapatalk HD
Old 11-28-2013, 05:54 AM   #52
kindofblue
kindofblue's Avatar
Oddometer: 829
Yes, it does make sense and your English is quite clear. Thanks.
Doc Reid
Old 11-28-2013, 09:23 AM   #53
backroadbill
backroadbill's Avatar
Oddometer: 251
Screens...
I put 80k on my 08GS with the stock screen and an adventure screen with winglets (and about 10 other brief tries with other screens-Givi airflow worked the best but couldn't stand the look). My new GS (2013) is way better stock than my 08 was, no buffeting. I'm 5'10". I did add a laminar lip (works pretty well here in the Wisconsin cold) but am planning on the BMW adventure screen and winglets when available. I do notice more torso/upper leg wind on the new bike....
backroadbill is offline   Reply With Quote
Old 12-02-2013, 08:06 AM   #54
Loutre
Cosmopolitan Adv
Loutre's Avatar
Oddometer: 3,815
saw the Puig screen today: Very nice indeed! First windscreen from them that I actually like!
Loutre is offline   Reply With Quote
Times are GMT -7.   It's 03:08 AM.
