KLR650 Engine Rebuild Photos and Questions!
Discussion in 'Thumpers' started by rectangular, Jan 8, 2013.
  1. ADW
    ADW 'tard bike restos
    May 29, 2009
    898
    Rochester MI
    No, go with an OEM oil filter from Kawasaki. Oil filter aftermarket manufacturers only have to make an oil filter they think you'll buy. Kawasaki's oil filters have to pass a validation test developed by Kawasaki that ensures it will stand up to temperatures, pressures and flow rates that Kawi knows for that engine.
    EDIT: no slam meant on DirtyDog, BTW.
    #81
  2. rectangular
    rectangular Adventurer
    Mar 5, 2011
    65
    Salt Lake City, UT
    Will do. It shouldn't take very long anyways. I'm getting pretty familiar with both sides under the engine covers.
    #82
  3. larryboy
    larryboy Just obey!
    Jan 9, 2005
    30,814
    Nebraska, Flat Earth!
    If you're careful you might be able to save the gasket. The oil pump surface should have a mirror surface, use a hand impact driver to get the screws out.
    #83
  4. ADW
    May 29, 2009
    898
    Rochester MI
    A tip I learned a while ago is when you're putting on a new gasket, coat one side of the gasket with a light film of grease. Just a light apply, not much. That will be enough to prevent it from sticking to the metal when you remove the cover again someday but won't hinder it sealing.
    I tend to grease the side than goes toward the engine, not the case. This is because it's easier to scrape the gasket off a case that you can take to the bench or whatever than the engine itself.
    #84
  5. rectangular
    Mar 5, 2011
    65
    Salt Lake City, UT
    I don't have a hand impact driver :(
    And it won't cause issues with coolant leaking? Interesting. I might have to give this a shot.
    Also, I haven't found a definitive answer if the side cases on the KLR should have silicone gasket maker (rtv bond/hondabond/etc) applied to the paper gaskets or not. Are the paper gaskets just applied as is? Seems strange to me.
    #85
  6. larryboy
    larryboy Just obey!
    Jan 9, 2005
    30,814
    Then use your biggest fattest phillips head and tap on the handle with a hammer while turning. Impact driver is about $10, can be found everywhere.
    The only place a KLR engine needs sealant is the center cases, no paper gasket there, you found the result of using too much goo on the center cases. A dab of RTV on a new valve cover gasket will help hold it to the cover when you install it, don't go crazy, apply long before you want to put it back on.
    Awesome tip on the grease idea, ADW!! :clap
    #86
  7. rectangular
    Mar 5, 2011
    65
    Salt Lake City, UT
    Edit: Nevermind, the oil pump is phillips head. I follow now. :D
    Also, I'm probably going to be going in and checking on the oil pump tonight. Anything specific that I should look for once I remove it?
    #87
  8. larryboy
    larryboy Just obey!
    Jan 9, 2005
    30,814
    Oil pump man, come on, I'm trying to help you here.
    :beer
    Scoring, it should have a mirror finish...no lines of any sort.
    #88
  9. rectangular
    Mar 5, 2011
    65
    Salt Lake City, UT
    Yeah. I'm a little slow today.
    I figured out what was going on once I started looking up pictures of the oil pump. :lol3
    #89
  10. Kawidad
    Kawidad Long timer
    Jul 9, 2005
    6,620
    Central Coast, Cal
    Don't forget to prime the oil pump after disassembly. :deal
    #90
  11. rectangular
    Mar 5, 2011
    65
    Salt Lake City, UT
    On it! I should underline that step in the Clymer manual.
    I should have posted build threads like this ages ago. It's good to find out all the stuff I'm doing wrong. :rofl I don't have any actual mechanical training. All of my "experience" is a combination of always taking stuff apart my whole life, and tips from friends or threads on the internet. It's nice picking up better methods and craft from other users that have much more experience.
    #91
  12. Dan in Grand Rapids
    Dan in Grand Rapids Been here awhile
    Dec 19, 2011
    154
    Grand Rapids
    Why did you have to have the cylinder honed at a machine shop? I thought the jugs from Eagle Mike were ready to bolt on without having to go to a machine shop.
    #92
  13. Beezer
    Beezer Long timer Supporter
    Oct 26, 2004
    12,155
    Anchorage, formerly Spenard (hub of the universe)
    if you reuse the copper gaskets on the oil fitting banjo bolts you should anneal them. they work harden when torqued up. get them on a coat hanger or something.... heat them to red & dunk them in water. they will be soft as butter. if there are ridges in the washer I file or sand them out before treating
    I usually stick the gasket to the cover with RTV & grease the side that goes to the case. it can be removed many times with no damage
    the 2 cutouts on the valve cover gasket need something to help them stick. the book shows putting a bead of goop along that whole side, I don't do that. I put a big fat dot of RTV on the outside of the head & over the rubber of the cutout. this is easier to clean up when checking the valves & nothing falls into the engine. YMMV
    only thing I would have added to the doo change is to put a couple punch marks on the woodruff key... that keeps it from getting pushed out of the crank when the rotor is installed. this has happened... later in life the rotor slips & the ignition timing goes off
    #93
  14. rectangular
    Mar 5, 2011
    65
    Salt Lake City, UT
    I didn't get a jug from Eagle Mike. There's a pretty awesome local motorcycle machine shop. I had them do all the machine work on the cylinder jug that came with my bike.
    #94
  15. rectangular
    Mar 5, 2011
    65
    Salt Lake City, UT
    I have some new copper gaskets for the banjo bolts.
    Sounds like using grease is the way to go so that gaskets can be reused. I like it!
    I'm a little paranoid about modifying the woodruff key in case I mess something up. Probably a better chance of me botching that than the woodruff key getting pushed up.
    #95
  16. newcastleadam
    newcastleadam Artful Tagger
    Oct 14, 2007
    3,511
    Gainesville, Fl
    Must have missed this, what's up with your woodruff key?
    #96
  17. rectangular
    Mar 5, 2011
    65
    Salt Lake City, UT
    Nothing is wrong. Beezer mentioned above to put some punch marks in it. But, I think I'm going to pass on that. Pretty sure I would mess that up. :lol3
    #97
  18. DirtyDog
    DirtyDog Omnia mea mecum porto Supporter
    Apr 27, 2007
    16,973
    Tulsa... it's OK
    We aren't gonna turn this into an oil or filter debate, but your paranoia regarding oil filters is odd to me. I suggested Hi-Flo due to the price point (half or less of OEM).
    Let's not kid ourselves about the tolerance levels and high performance specs of this motor from 1980's vintage technology. A KLR would probably run for years with a wadded up shop rag jammed in there instead of an oil filter.
    #98
  19. newcastleadam
    Oct 14, 2007
    3,511
    Gainesville, Fl
    Brilliant
    #99
  20. DanishDR
    DanishDR n00b
    Aug 4, 2011
    6
    Jackson Wyoming
    First, I agree that the tiny difference will probably make no difference in filtration on this motor. That being said, I was surprised when we pulled the K&N to see such a premium filter with such blatant seal issues. Perhaps it wasn't the right filter or the seals had some issues.
