Yamaha WR250R Mega Thread
Discussion in 'Thumpers' started by Sock Monkey, Apr 7, 2008.
  1. grind
    grind Been here awhile
    May 3, 2012
    285
    Champlain Valley of Vermont
    Probably not but why risk it?
  2. Wreckchecker
    Wreckchecker Ungeneer to broked stuff. Supporter
    Dec 18, 2008
    9,738
    Damascus, MD
    Not if you can see the top of the oil. Get too much deeper and you can start problems.
  3. Wreckchecker
    Dec 18, 2008
    9,738
    Damascus, MD
    Simply hot gluing a hook piece of velcro strap to the cap and a piece of loop to the tube will do the same thing and is easier to use.
    Street or dirt, that is a lousy place for a tool tube.
  4. Llamaha
    Llamaha Been here awhile
    Jun 22, 2010
    898
    Bogota Colombia
    First of all do you have it on a stand when you check it? It should be on a stand on level ground.
    The oil level should be between the two little grooves you can see at the sides of the window.
    Remember it's 1400cc if you change the filter as well. If you do not it's less. I usually put about 1100cc and then top it up slowly until the oil is in between the two grooves of the glass.
    I would recommend draining the oil, be sure to wear a glove and don't drop the drain plug.
  5. Tewster2
    Tewster2 Long timer
    Jun 17, 2011
    7,951
    DeLand Flatistan
  6. Tewster2
    Tewster2 Long timer
    Jun 17, 2011
    7,951
    DeLand Flatistan
    You are right. It is brand new.
  7. Tewster2
    Tewster2 Long timer
    Jun 17, 2011
    7,951
    DeLand Flatistan
    Thanks for the tip. I will see if the stainless clamps do ok. The end cap is glued on and the other end has a screw cap that I will keep an eye on.
  8. vagabondmatt
    vagabondmatt Keep on keep'n on.
    Jun 26, 2014
    433
    Greensboro, North Carolina
    Just a little video of a dual sport ride I did this weekend on my WR with some buds at the Williams Hill recreational area in the Hollister BLM area just south of King City, CA. Beautiful day riding with great people in an awesome setting.
    <iframe src="https://www.youtube.com/embed/N4X25XlLR9c" allowfullscreen="" frameborder="0" height="315" width="560"></iframe>
  9. ER70S-2
    ER70S-2 Long timer
    Sep 30, 2009
    17,156
    SE Denver-ish
    I'm out of town and don't have my Valley of the Gods pics. :2cry
    Shafer Trail:
    :ricky
  10. coyote223
    coyote223 Adventurer
    Mar 4, 2014
    88
    Oregon
    Thanks. on level ground, but not on a stand. Managed to suck enough out, to where it's just above the upper notch. Gotta get out and ride with this nice weather. Will check it again in the morning. Thanks guys,,,
    I'll definitely sneak up on it next time, instead of putting the whole amount in first.
  11. KICKNBACK
    KICKNBACK Your never lost if you don’t have a plan
    Oct 16, 2012
    3,679
    Cancer Sucks!!!!!
    Why would you pull the plug when you can open the fill plug and just lean it over
  12. Llamaha
    Jun 22, 2010
    898
    Bogota Colombia
    With the method I described the bike was on a stand :1drink
  13. Reeksy
    Reeksy high state of hiatus
    Jan 9, 2010
    1,606
    Mt Mellum
    Syringe and a tube :freaky
  14. Tewster2
    Tewster2 Long timer
    Jun 17, 2011
    7,951
    DeLand Flatistan
    One of my favorite places! I'm there a few times a year on my GS. Looking forward to riding the Shafer on the MUCH lighter WR.
    Valley of the Gods
    [​IMG][/URL][/IMG]
  15. Chrisbarnes1
    Chrisbarnes1 Long timer Supporter
    Dec 28, 2005
    1,329
    Market Deeping, Lincs UK
    Just fitted the first one out of the mould--its a bit of an overkill on layers. Secured with 3M dual Lock--but can be bolted of course. I can do white, a vague blue or black. See earlier post 47179.
    Not a perfect straight line down the middle or a perfect flush fit against the shroud--but its hand built!(hobby).
    Note the front brake hydraulic connection is reversed to get the hose out of the way
  16. zekester63
    zekester63 Been here awhile
    Sep 8, 2011
    933
    Oklahoma
    I spent a week in SE Utah last October. Best.riding.ever!
    Wish I could ride there every year. Personally don't think I'd ever want to ride there without a skid plate though - never know when gravel might do something unexpected.
    Tons more pics if you're interested in my RR (below).
  17. dflores
    dflores blossoming advrider
    Nov 4, 2014
    113
    McAllen, Tx
  18. norcalwrx
    norcalwrx Been here awhile
    Dec 8, 2014
    193
    Probably incompatible with your clutch. Why risk it?
    I use mobil1 4t. Oil is cheaper than clutches, transmissions and engines...
  19. Tewster2
    Tewster2 Long timer
    Jun 17, 2011
    7,951
    DeLand Flatistan
    Well...I got a phone call from my best friend.....he said after looking at the 4 inch tool tube I made for the WR......it was the stupidist looking thing he has ever seen....he said he didn't know the WR was full of S%&*T and needed a septic tank cleanout.....so I made a 3 inch one with a better cap on the end...he called back and said it was better....I'm still gonna go out with his girlfriend when he's not in town :lol3[​IMG][/URL][/IMG]
  20. zekester63
    Sep 8, 2011
    933
    Oklahoma
    DIY projects are always fun IMHO...especially when they serve a good purpose! And like I said when I swapped tanks to the 4.7... it's for function, not looks. I remember the first time I saw these oversized, natural colored tanks thinking "no way"... Well, yes way - and I love it for what it does now.
