Help! Just bought a crashed R1200GSA
Discussion in 'GS Boxers' started by Roughseas, Nov 7, 2012.
  1. Roughseas
    Roughseas Adventurer
    Apr 14, 2010
    66
    Pune
    Just picked up a crashed 2011 R1200GSA for a friend. Bike has done 500kms on the odo and barring the accident damage seems to be in pretty good shape.
    The right magnesium cover has disintegrated and the cam holder has slight damage at the edges but does not seem stressed. The front bodywork is totally smashed but that is not my immediate concern as I want to see if the bike cranks first. I've tried turning the engine by rotating the real wheel and the bike in gear and it rotates freely (i think :) ).
    Since the lcd has cracked I don't see the error messages showing up when I try to crank the engine with the starter. I had to scavenge the ignition kill and the starter switch from the switch housing in order to try this.
    On switching the ignition key on I get the yellow caution sign for a few seconds followed by the red caution sign and then the steady ABS warning sign which stays on. If I press the ignition kill microswitch, all warnings disappear but nothing happens if I press the starter button. Without depressing the kill switch, if I press the starter button, I get a loud knock from the starter motor. I've tried a fully charged battery but same results. BTW side stand switch looks ok and I get a Neutral indication on the dash but after a few tries the neutral light goes away.
    The clutch and brake master cylinders are cracked and the brake lever microswitch is missing. Can the lack of oil in the clutch or brake system inhibit the starter motor from engaging?
    I've tried cranking the motor with the crankshaft at different positions but all I get is a loud knock from the starter and no movement.
    Any pointers anyone? I've ordered a replacement brake master cylinder with the right side switches and a new meter so should at-least get some insight into the alarm messages. Will try purging the clutch today and see if it helps.. What oil goes in there, mineral or brake fluid?
  2. Stinkyb
    Stinkyb GS"eh" rider
    Aug 19, 2009
    370
    Grande Prairie
    As far as starting it goes, sounds like the battery is dead.
    Starting due to lack of brake/clutch fluid shouldnt have any effect, so long as your in neutral...dont expect to get far:norton
    Clutch has microswitch so you cant start engine clutch engaged/ in gear...
    Clutch takes magura blood mineral oil NO DOT FLUID
  3. Roughseas
    Apr 14, 2010
    66
    Pune
    I have tried it with a fully charged car battery but the starter still doesn't turn. Will give it another shot with proper jump cables, i've been using makeshift cables made out of house wiring :D since I didn't have anything at hand.
    My first guess was the ring antenna but then the starter should not even give the loud knocking sound if that was defective. What about the anti theft alarm (wherever that is)? I am sure that is almost dead as the bike has been standing for about two months.
  4. viz
    viz I Ride Ms Piggy
    Nov 12, 2006
    1,832
    Sydney, Oz
    Something don't sound right - you say you can rotate the engine via the rear wheel - how easily and in what gear?? Realistically I would expect it to be almost impossible to turn the engine over due to the very high compression.
    The knock you hear when the starter button is pressed would I expect be the starter motor teeth engaging the flywheel - but for some reason the starter motor may not be turning over. This would be something in the starter mechanism, maybe wiring within the starter motor, earthing, or corroded contacts or similar. If that is proven to be the problem you would need a r&r of the starter motor.
    Or a thoroughly jammed engine, though unlikely if you can turn it over via the rear wheel.
    Check that the engine *can* be turned over (best to remove the plugs to do this), otherwise check the starter motor is functioning correctly - to do this properly would it would need to be removed and bench tested
    viz
  5. semaja2
    semaja2 Been here awhile
    Jan 7, 2012
    241
    South Australia
    If you end up scrapping it ill take the rear ESA shock if its still good ;) however seems like you got a handful of fun for the next coming months :)
  6. Roughseas
    Apr 14, 2010
    66
    Pune
    Bad news for you!
    It started! :D :freaky Problem was the bad battery and my home made jump cables. Thanks Stinkyb.
    Could not run it for long as the oil was spraying all over but the engine sounds silent and good.
    @viz.. it was difficult to turn it over with the rear wheel, I also have a 2001 R1150GS and this was harder to turn compared to that as the engine has hardly been run in.
  7. viz
    viz I Ride Ms Piggy
    Nov 12, 2006
    1,832
    Sydney, Oz
    OK good. Problem with those "fully charged" batteries - sometimes they're not :D That loud clunk you heard was prolly the starter motor engagement but did not have enough berries to do the rest. What threw me was that usually you get a chatter from the starter motor and no turn-over with a battery that is flat...
    But good that it went
    viz
  8. Dan Alexander
    Dan Alexander still alive and well
    Nov 8, 2003
    9,286
    Montreal
    #8
  9. Kingsized
    Kingsized Kingsized Adventurer
    Mar 22, 2012
    1,050
    Central MS
    WURD! I'd like to see this!
    #9
  10. Roughseas
    Apr 14, 2010
    66
    Pune
    Enjoy!
    #10
  11. jdbalt
    jdbalt Been here awhile
    Jun 22, 2010
    201
    How about pictures of your friend in the hospital? It all looks repairable.
    #11
  12. jdbalt
    Jun 22, 2010
    201
    Looks like instrument cluster and half of the windscreen mount.
    #12
  13. GB
    GB . Administrator Super Moderator
    Aug 16, 2002
    72,225
    Can you buy bmw motorcycle parts in India? :ear
    #13
  14. Dan Alexander
    Nov 8, 2003
    9,286
    Montreal
    Looks in good shape besides the front ... worth the go I think .. depending of course on how much you've got into it. :D
    #14
  15. Roughseas
    Apr 14, 2010
    66
    Pune
    Getting them from motorworks in the UK, they do have dealerships here but they end up taking a couple of months to source the parts.
    jdbalt - those are all the bits I took off..beyond repair types :D
    Looks worth the effort as they sell for USD 50k brand new here.
    #15
  16. Roughseas
    Apr 14, 2010
    66
    Pune
    How much mineral oil will go into the clutch system considering its totally dry? I'll be ordering online and don't want to fall short later.
    #16
  17. Stinkyb
    Aug 19, 2009
    370
    Grande Prairie
    It is highly recommended to use magura blood, which believe it or not, is the same fluid they use in there mtb brake levers.
    Clutch doesnt hold alot of fluid, youll waste more in the purging process(dont reuse obv)
    If for some reason you go through a whole bottle, chances are you could source some from your local mtb shop.
    Btw, clutch bleed is quite retardedly easy..enjoi
    #17
  18. Roughseas
    Apr 14, 2010
    66
    Pune
    And I am one :baby
    Ordered two bottles just in case. Thanks!
    #18
  19. Roughseas
    Apr 14, 2010
    66
    Pune
    PANIC STATIONS!
    Had the bike up and running yesterday and today after a new dash and battery its displaying the dreaded EWS warning and no low beam.
    Will a new ring antenna solve the problem? The bike also comes with a BMW on-board alarm system but guess that has been deactivated from the day I bought it because it never went off and the key fob is broken.
    Can the alarm system display the EWS warning or its only the ring antenna?
    Help please! Dont have a dealer in my city to take the bike to :cry
    #19
  20. Bobby Ginger
    Bobby Ginger Cat Herder
    Nov 2, 2012
    1,064
    Denver
    White guy Village People? :rofl
    #20
