Up in Smoke
Discussion in 'The Perfect Line and Other Riding Myths' started by Roger Baker, Jun 7, 2014.
  1. Roger Baker
    Roger Baker FasterGS
    Sep 18, 2008
    10
    Almost Heaven- NW Arkansas
    Couple of weeks ago, I started my 2004 GS 1150 Adventure and went in the house to change shoes and jacket. (DON'T DO THIS) In about 12 min. a neighbor was beating on my door to inform me that my motorcycle was on fire:eek1. I found my motorcycle with fire coming out the front wiring and oil all over my garage!! Pushed it out in the yard and put the fire out and stood there wondering "Did I take out FULL coverage??":shog. Thank GOD I did! I had just changed to Progressive insurance 2 months earlier and dreaded making the call. Well there was a good vibe from the beginning because my adjuster's name was Jesse (like the bags). While I hated it, my bike was totaled:huh. I was preparing to argue my point for the value of my bike, but I did not have to. Progressive could not have been more fair. I also had additional insurance for accessories which helped bridge the expense. All and all, while I miss my old bike a lot. (Had many adventures together), I was able to get a another bike within a couple of weeks and I am back on the rode with little interruption! Thanks Progressive!:wings:wings
  2. Teckel
    Teckel Go Away, I'm Busy!
    Oct 4, 2012
    19,531
    In front of the TV
    What started the fire?
  3. Bill Harris
    Bill Harris Confirmed Curmudgeon
    Sep 20, 2008
    9,874
    backwoods Alabama
    Oilhead=oilcooled=overheat=oil fire? :eek1 Or coincidence? :dunno
    --Bill
  4. Spaggy
    Spaggy Long timer
    Apr 5, 2010
    1,188
    Western Canada
    Letting it run for 12 minutes just sitting. Start it, ride it.
    Even a few minutes balancing throttle bodies, I use a big fan or the sucker gets hot hot.
  5. catweasel67
    catweasel67 RD04
    Aug 18, 2009
    17,429
    Vienna, Austria
    Are you serious?
    You're suggesting that a GS will catch fire if left to idle for longer than XX minutes?
  6. Cogswell
    Cogswell Road General
    Jan 3, 2005
    13,187
    Riding with my pal Richard Cranium
    Yep, older bike with a loose/weak oil sight glass. Glass pops out, oil drains onto hot exhaust, combustion ensues. Not the first time it happened, and probably won't be the last.:deal
    Gear up, get on the bike, start it, and ride away.
    Mike
  7. catweasel67
    catweasel67 RD04
    Aug 18, 2009
    17,429
    Vienna, Austria
    Good god! and thanks :) Time to move my AT away from that old Dakar GS :p
  8. Bill Harris
    Sep 20, 2008
    9,874
    backwoods Alabama
    Yep. Since the engine is largely oil-cooled it dumps a LOT of heat into the oil, which relies on airflow through the oil cooler to remove the heat. Heat keeps building up and up and up. Also there are ignition sensors ("Hall Effect Sensors") that have a history of HES wire insulation problems when they get cooked if the bike overheats, even idling it for 3-4 minutes.
    --Bill
    #8
  9. Pecha72
    Pecha72 Long timer
    May 5, 2008
    7,255
    Helsinki, Finland
    The bike idles for less than 15 minutes, and it catches fire? Really?? In that case, there should be a system, that if the bike's not moving in, say, 5 minutes, the engine is turned off.
    #9
  10. TrashCan
    TrashCan Scary Jerry
    Oct 5, 2005
    11,973
    Louisville, Tn
    There is, it's rider controlled and called common sense.
    #10
  11. RodT
    RodT Been here awhile
    Sep 20, 2008
    376
    Westwood, CA.
    We don't need anymore sensors, just use common sense. These bikes already have more than we need in that department.
    #11
  12. tntmo
    tntmo Oops, I did it again.
    Jan 31, 2012
    1,850
    San Diego, CA
    How the hell would you ride through heavy traffic if the bike catches fire in 15 minutes?
    #12
  13. TrashCan
    Oct 5, 2005
    11,973
    Louisville, Tn
    Lane split?
    #13
  14. joef
    joef Long timer
    Oct 9, 2011
    2,653
    Western Ct.
    There is, it's called design flaw.
    #14
  15. Anonawesome
    Anonawesome Scenic Rider
    Feb 2, 2010
    2,554
    Germany I think?
    Are you all really so spoiled as to have never owned an air cooled bike? :huh
    #15
  16. joef
    joef Long timer
    Oct 9, 2011
    2,653
    Western Ct.
    How do you get spoiled from this? Oh you must be one of the smart ones, do me a favor give me a good stock tip while your at it.
    #16
  17. Kommando
    Kommando Long timer
    Nov 28, 2006
    12,492
    By the Great Lakes
    Learn how to properly use "your", "you're", and "yore" before even contemplating getting into the stock market.
    :evil
    #17
  18. joef
    joef Long timer
    Oct 9, 2011
    2,653
    Western Ct.
    Thank you for the grammar correction, get a life while you're at it.:D
    #18
  19. Pecha72
    Pecha72 Long timer
    May 5, 2008
    7,255
    Helsinki, Finland
    yeah, and it would up the cost by about 15 dollars, too.
    #19
  20. TrashCan
    Oct 5, 2005
    11,973
    Louisville, Tn
    On a BMW?
    :poser
    #20
