Someone broke off my Garmin V antenna
Discussion in 'Mapping & Navigation' started by XPADREX, May 4, 2010.
  1. XPADREX
    XPADREX Funslinger
    Nov 12, 2003
    16,320
    Flyover Country
    I came out of work to ride my bike to lunch, and noticed that the chunky block antenna on my Garmin V was broken off for me.
    Can I get this fixed or replaced inexpensively?
  2. Jamie Z
    Jamie Z I'm serious. Supporter
    Oct 17, 2006
    12,804
    Around the World
    Remove Garmin V. Replace with a newer unit.
    Really, I have no idea. I know that seven or eight years ago, the V was most full-featured GPS available.
    It might be time for an upgrade. A used or refurbished 2610, 2720, or 2820 can be had for a couple hundred dollars and the features compared to the V will blow you away.
    Or you can probably find a replacement V on eBay for $100 or less.
    Jamie
  3. XPADREX
    XPADREX Funslinger
    Nov 12, 2003
    16,320
    Flyover Country
    I knew someone would say "get a new one". :lol3
    The thing is, I haven't made the decision to want/need/get a new one- and if I do, I'd like to give this one to my kid to play with.
  4. mcnut
    mcnut Long timer Supporter
    Apr 26, 2006
    1,812
    Bakersfield CA
    Is the mount for the antenna on the back of the GPS undamaged?
    You can buy a replacement antenna unfortunately more $$ than you might want to spend ($30 some years back). Other wise probably be looking for a dead unit for parts. I think the III, III+, V, 176, 276, 378 etc all use the same piece.
    Bruce
  5. 9Dave
    9Dave Bazinga!
    Aug 4, 2005
    13,630
    Central Ohio
    Broken off? or just missing in action? They do fall off.
    If it is broken, and the unit is undamaged, you can install one of the auxiliary antennas that are sold.
    If the unit is damaged, I doubt Garmin provides repair services any more. Even if they did, it would cost more to repair than its worth.
  6. Jeff@TheQuadShop
    Jeff@TheQuadShop TAT survivor, TOI T1 finisher
    Nov 28, 2004
    8,452
    Crestwood, Kentucky
    Yes, you can buy a replacement antenna. I like getting stuff from www.GPScity.com
  7. Jamie Z
    Oct 17, 2006
    12,804
    Around the World
    If all else fails, it looks like the GPS V can be found on eBay for less than $50. Whether you keep or replace your V, I still recommend checking out newer units. You'll be shocked.
    Jamie
  8. 02short
    02short Adventurer
    Nov 24, 2006
    10
    I have a dead one you can have for the postage. The unit appears complete but it would't locate satilites and was replaced with a Zumo.
    I' m in Mid-Mi.
    #8
  9. XPADREX
    XPADREX Funslinger
    Nov 12, 2003
    16,320
    Flyover Country
    I might take you up on the offer.
    I'll take a pic of what's "left" and post it today.
    #9
  10. summerinmaine
    summerinmaine Hells Atheists MC Supporter
    Sep 27, 2003
    142,383
    Humboldt Bay & San Felipe BCN
    I have a V among others, and I will check, but I'm pretty sure that the antenna is easily replaceable.
    Yup, just checked and it pops right off (once you've aligned the 'tit with the slit,' so to speak :D). Unless you can see a metal "male" bayonet connection where the antenna used to be, then it is broken off, and the remains will need to be removed.
    #10
  11. summerinmaine
    Sep 27, 2003
    142,383
    If you need a replacement, I'd be happy to send one. I always use a radome with my 176C, as a remote antenna is necessary with my Jeep.
    #11
  12. SilverSpringsKLR
    SilverSpringsKLR Been here awhile
    Jun 17, 2009
    102
    Niger, West Africa
    I have a remote antenna that I use with mine. It pulls in signals much better than the stock one.
    However, the LCD is cracked on my V, so am looking for a V as well.
    #12
  13. summerinmaine
    Sep 27, 2003
    142,383
    I intend to sell mine, but I want to sell the Touratech mount for it as a package deal.
    #13
  14. maiden.jade
    maiden.jade Been here awhile
    Mar 5, 2008
    698
    Seattle, WA
    I have a V which I'm looking to get rid of. If anyone wants it, just offer whatever you want. It's just sitting in the closet unused anyway. It works and is in good condition.
    #14
  15. XPADREX
    XPADREX Funslinger
    Nov 12, 2003
    16,320
    Flyover Country
    This is the back of my unit.
    #15
  16. summerinmaine
    Sep 27, 2003
    142,383
    Antenna is gone, not broken.
    #16
  17. 9Dave
    9Dave Bazinga!
    Aug 4, 2005
    13,630
    Central Ohio
    :nod
    If you can't get one cheaper, something like this would work.
    http://www.gpscity.com/garmin-ga25-bnc-antenna.html
    Of course it's probably worth at least half of what the unit is, but you can always use it on something else when the V dies.
    #17
  18. summerinmaine
    Sep 27, 2003
    142,383
    That's similar to the one I use for my 176C. Definitely a better signal than the stock antenna.
    #18
