Suzuki DR650 Build - Transformation to an Adventure Bike
Discussion in 'Thumpers' started by motodavid2000, Aug 1, 2011.
  1. Zapp22
    Zapp22 ZAPP - Tejas
    Oct 20, 2004
    13,894
    Tejas Hill Country
    How many miles did you do between last Thursday and Monday?[/QUOTE]
    I would have more miles if it weren't for all the doggone paving of formerly interesting roads in these parts :puke1 :deal
  2. WeazyBuddha
    WeazyBuddha Carbon-Based Humanoid
    Mar 18, 2008
    12,681
    RGV Texas
    Nice build. :thumb
    Looks like you have a fan: LINK
  3. Bronco638
    Bronco638 Nobody Home
    Dec 1, 2004
    6,413
    Notorious EGV
    Thanks Dave, that's what I was curious about. :thumb
  4. pfy50
    pfy50 Professional nOOb
    Aug 25, 2006
    594
    Oneida, Tenn.
    DAVE,
    Thank You for some inspiration on possible future project(DR650 for Baja and Central America trip). Did your welder make preformed cutouts of those subframe gussets or was it just eyeball. Asking if you/he has the forms with dimensions on them we might get a couple of photos of them when work allows.
    :wink:
    Current project readying for Prudhoe Bay and D2D 2013(wr250r)
    Paul
  5. motodavid2000
    motodavid2000 MotoDavid
    Jun 2, 2009
    228
    USA - Florida and Ohio
    Paul -
    I suggest that you use card stock (such as on the back of a pad of paper) to make each of the gusset templates. The material is cheap, you can mark it easily with a Sharpie pen for making each template and it transfers easily to steel plate. I don't have any dimensions, but the card stock will work great for making a very exacting template for each gusset you want to fabricate.
    I really like your setup with your Yamaha WR250 - super tanker fuel tank & all ! Great stuff. :thumb
    I rode solo to Prudhoe in 2009 and my Ride Report to Prudhoe is in my signature line if you want to look at the routes I took. I highly recommend taking the Campbell across the Yukon Territory, rather than take the Alaska Highway north out of Watson Lake where the Signpost Forest is located. The southern terminus of the Campbell is in Watson Lake.
    The Campbell was mostly dirt and gravel when I went and they are gradually paving it -- ride it while it is still partially dirt and gravel. It is a very lightly traveled and remote road - a blast to ride it solo. Take the South Canol Road out of Ross River if it is open - I did not ride the South Canol when I went as I was advised there were one or more bridges washed out when I fueled / overnighted in Ross River. The South Canol ends at Carcross and you can then go north on the Alaska Highway towards Dawson City for the D2D party.
    Anyway, you will long remember the ride north - it is a great ride and let me know if I can provide any input to you on planned routes or trip prep. The Milepost is a great resource for planning this ride. I always take too much !
    Dave
  6. Tex83
    Tex83 Motersykle Advntyers
    Feb 17, 2012
    963
    Dallas, Texas
    Great thread! Very well equipped bike.
  7. Solo Lobo
    Solo Lobo airhead or nothing Supporter
    Mar 16, 2004
    13,668
    Shoreline, WA
    Here's a tip for you... I ended up replacing the stock locks on my Happy Trails panniers with the Southco locks below. The advantage is that you don't have to keep track of the padlocks and these locks don't bang on the boxes as you ride.
    I used the PN# K4-2833-07 IIRC
    http://www.southco.com/en-us/k2-k3-k4-k5?info=false&filters=
    Great build so far!
  8. oldschoolsk8ter
    oldschoolsk8ter Adventurer
    Jul 9, 2007
    84
    SNH
  9. motodavid2000
    Jun 2, 2009
    228
    Solo Lobo -
    Thank you very much for the tip on the Southco latches. I found a local distributor that carried the Southco product line, and ordered a set of identically keyed latches for all the panniers and I have installed them. I used stainless steel machine screws and red Loctite on the keyed latch vs. the stock rivet setup. The latches are one hell of alot better than the padlocks; and faster to open & close with the single keyed set of locks / latches. :clap
    Here are a couple of pics of my finished panniers with the new keyed latches:
    Side keyed latch on the extra large topbox:
    Riding my DR650 on the Tail of the Dragon...with the old pannier padlocks flapping in the breeze:
  10. bustedsprocket
    bustedsprocket Been here awhile
    Feb 13, 2011
    116
    Roaming CT
    I have been looking through the pictures posted on your build and was curious how you relocated the wire harness from behind the stock headlight. If you have any pictures or details it would be great. I have the same headlight on my dr650 and the wire cluster is held in place above the headlight plug. It would be nice to clean this area up.
    Thanks-
  11. motodavid2000
    Jun 2, 2009
    228
    Unfortunately I don't have any in-progress photos of how we disassembled the front wiring harness for the headlight and turn signals, which included circuits for the handlebar mounted switchgear.
    We unwrapped the entire stock wiring harness and then bundled the circuits according to final location and then "re-packaged" and re-wrapped them on either side of the main frame spar and behind the headstock primary gusset - location as shown below in the disassembly photo of the area where we ultimately relocated the majority of the bulky (& ugly) front wiring harness.
    The larger plastic IMS fuel tank also provided a little more space between the tank and the frame than the stock tank IIRC.
    Hope that helps - Dave
  12. TRAVELGUY
    TRAVELGUY Old Traveler
    May 20, 2008
    942
    Georgetown, In / Costa Rica
    A lesson learned the hard way.
    If you are going to work with your wiring harness anyway on a DR650 move the wiring and clutch cable to the left hand side of the steering head. This makes things much easier for inspectors at border crossings and less chance of errors which can really bite you at the next crossing. Wasted about 1/2 hour the last time I was leaving Mexico due to the fact that the inspector couldn't get a clear photo of my vin number.
    TravelGuy
  13. PPCLI-Jim
    PPCLI-Jim Been here awhile
    Feb 5, 2012
    221
    Victoria BC where I ride year round.
    I hear you on that , also give it less chance of rubbing through I took some old black garden hose that secured with a self tapping screw and used it as a loom guide after cutting a slice down one side and leaving a flap that the screw passed through. I then angled it up and through the LH side of my steering head. Sorry for the lack of pics as I am attending School on the mainland :huh
  14. Tukata
    Tukata ADV Demo Rider
    Jun 13, 2009
    1,852
    Canton, GA
    Updates????
    :lurk
  15. wayno
    wayno Long timer
    Mar 14, 2004
    7,850
    East of KCMO
    1st Great read and info.
    Shouldn't the siphoning(as mentioned before) of fuel by motor running negate most of the prob created by low fuel/pressure.
    It has always bothered me to see when the fuel line drops below inlet but have seen many bikes (DR especially) running that way with no prob.
    Really enjoying this build:thumb
  16. motodavid2000
    Jun 2, 2009
    228
    Tukata -
    Thanks for following the thread and for asking about the status of the build and the testing. The DR650 is slumbering comfortably during the cold & snowy winter up north :vardy in a garage while I am wintering in the south. :jkam
    Unfortunately I am also awaiting knee surgery in the May time-frame to repair / remove torn cartilage, so my moto days are limited due to this fairly recent, but rather miserable, problem. :(:
    Seems like the Grim Reaper is lurking around & getting impatient.....! :grim
    Dave
  17. BenS
    BenS n00b
    Nov 25, 2011
    2
    I appreciate the extra time and attention you have put into documenting your project for us. Despite my trepidation, I'm inspired to overcome my fears and perfectionism and dig in to my long neglected DR. Her problems are ridiculously trivial, but intimidating to me, nonetheless.
    Best of luck with your surgery!
    I'm a fellow Ohioan (Ashland), keeping the faith that spring is on its way. :clap
  18. wayno
    wayno Long timer
    Mar 14, 2004
    7,850
    East of KCMO
    Quote :I'm a fellow Ohioan (Ashland), keeping the faith that spring is on its way. :clap unquote
    I'll yell when it is coming up I-70. lol
    Sent using Tapatalk 2
  19. motodavid2000
    Jun 2, 2009
    228
    Hi Ben -
    The good thing about the DR650 is that it is a relatively simple motorcycle, and almost any mistake can be fixed by copious amounts of money and additional work time in the shop....:lol3
    Good luck & dive right in - Dave
    ps - I see yet another snow event is en route to Ohio.....:puke1
  20. manganos
    manganos Let me pontificate.
    Jan 11, 2008
    3,772
    Virginia
    OUTSTANDING BUILD! I'm looking to add a DR650 to the garage and really enjoyed your build. Thanks and stay safe.
