GPS Power from 12GS Harness?
Discussion in 'GS Boxers' started by pedalmike, Nov 28, 2006.
  1. pedalmike
    pedalmike Horizontally Opposed
    Sep 19, 2006
    165
    Canton, CT and Tucson, AZ
    I'm interested in using the stock 12GS wiring harness to get power to my GPS. Other threads have said there is a connection near the headstock where the BMW Nav II or III can be plugged in.
    Can you confirm where on the bike I would find this plug?
    Can I get a compatible plug to power up an aftermarket GPS like the Garmin 276C or Zumo?
    Any experience here with trying this?
    Mike
  2. rick danger
    rick danger The further adventures of Supporter
    Dec 24, 2005
    16,645
    Oneonta, NY and Durham, Ct.
    The plug should be taped up on the left side of the steering head. You have to get a flashlight or something in there to pick it out from all the other black stuff. It will have a cap over it. Get a little screwdriver and pop off the cap. I was gonna order a mating plug and do things the right way but wound up doing what I did on the old bike. I drilled a hole in the plug the size(a little smaller ) of the outside caseing of the gps harness. Push the cap over the GPS harness. Then I stripped the wires about3/8" And cut of a little ( to decrease the guage say(smaller diameter) ThenI tinned them to get them stiff and pushed em into the plug. The red and yellow is hot and the brown is ground. (I think but double check it with a meter) There is one you don't use. Then push the plug back on and I put some ultra flex ( from the aerostitch catalog) To seal and glue the GPS caseing to the plug. It lasted that way on the old bike so we'll see. Good luck
  3. footloose
    footloose and fancy free.
    Jul 6, 2005
    217
    Melbourne, Australia
    I did the same thing as Rick Danger, 12 months on and no problems at all.
    His "guess" as to live and ground wires is correct.
    I'm using a Garmin 276C, that circuit stays on for a couple of minutes after the ignition is switched off.
  4. 2wheelsrule
    2wheelsrule youth survivor
    May 24, 2006
    160
    Petaluma, CA
  5. JimVonBaden
    JimVonBaden "Cool" Aid!
    Feb 11, 2005
    101,516
    Alexandria, VA
    Is that power only when the key is on?
    Jim :brow
  6. johnboy
    johnboy Been here awhile
    Sep 6, 2005
    221
    Montana
    I've had mine on for almost a year this way. So far it works as intended.
    JVB - it is switched power but remains on momentarily after the key is turned off, 30 - 40 seconds. I'd like to have it remain on indefinitely and may re-wire mine to the battery directly.
  7. mrmaico
    mrmaico Long timer
    Feb 26, 2005
    1,711
    High Plains
  8. rick danger
    Dec 24, 2005
    16,645
    The 276c can be set to have it stay on ,on its own battery power after external power is lost
    #8
  9. JimVonBaden
    Feb 11, 2005
    101,516
    Alexandria, VA
    Thanks, that is what I thought. I prefer to be always on.
    Jim :brow
    #9
  10. pedalmike
    Sep 19, 2006
    165
    Excellent, guys.
    Thank You
    #10
  11. footloose
    Jul 6, 2005
    217
    As does mine or, you can setup the GPS to switch off when external power is lost.
    #11
