Swapping modern-ish forks onto a Tonti Guzzi
Discussion in 'Some Assembly Required' started by farmer_fred, Mar 29, 2015.
  1. farmer_fred
    farmer_fred mostly paved
    Mar 18, 2012
    10,447
    OK, firstly, I know I could accomplish this easier by simply buying some Gixxer forks off Ebay.
    Stock Guzzi stem and lower clamp.
  2. Cogswell
    Cogswell Road General
    Jan 3, 2005
    13,187
    Riding with my pal Richard Cranium
    Interesting project Fred.
    The steering stem is likely on splines into the lower tripple clamp. At a cursory look your wheelbase will be shorter by the difference between the two sets of clamps. Looks like turning radius will be decreased as well with the fork tubes further back. :ear
    Mike
  3. Beezer
    Beezer Long timer Supporter
    Oct 26, 2004
    12,155
    Anchorage, formerly Spenard (hub of the universe)
    the stem either has a shoulder or a split ring on the bottom end. that keeps it from being pulled through the lower triple by the adjuster nut on top... it will only press out "top" to "bottom". you need to do some research on rake & trail.... that much change may not be too good... guessing it would be twitchy
  4. pennswoodsed
    pennswoodsed lizards,bugs and me
    Jan 20, 2007
    1,142
    Reading,Pa
    Ok, are fork lengths roughly same ? can the blank wp triple be drilled to match original offset ? need to measure center of both fork legs O-O to center of stem. -O-
    I would expect something like 25mm to 50mm . Maybe a Guzzi guru will reveal lost secrets of Italy here ?
    Ed
  5. fritzcoinc
    fritzcoinc Enjoying my last V8 Supporter
    Apr 30, 2008
    10,582
    Hockley, Tx
  6. nickguzzi
    nickguzzi Long timer
    Feb 17, 2010
    10,899
    below the sea
    The steering stem on the Guzzi triples I have messed with are just an interference fit with a step to stop it being pulled through.
    I cut and steepened the head stock in mine to increase nimbleness. No unforeseen consequences after 25 years.
    The Toni frame is pretty conservative, and very forgiving.
    The only thing I may have a slight concern about is if the much better forks allow/encourage you to over stretch the rear suspension, which wouldn't be difficult.
  7. FR700
    FR700 Heckler ™©®℗
    May 4, 2007
    18,164
    Your imagination.
    All else being equal, length of fork legs, etc, the less offset between the fork and stem centerline will result in more trail. More trail adds stability as the tendency to self correct is greater. Downside of that is that it will require more effort to turn into a corner at speed. Potholes and speed bumps will be a thing of the past
    More offset = less trail will speed up the steering, with the downside being that if you go too far it will result in a twitchy front end.
    More offset is usually coupled with more rake to balance out the equation. You'll likely want about 4" of trail.
    Set of bm' trees and forks that I slapped on a sporty. Both stems wouldn't work for the application, so I turned up a new one.
  8. FR700
    FR700 Heckler ™©®℗
    May 4, 2007
    18,164
    Your imagination.
    That's a seriously nice rim, and those forks are pretty sweet, too :thumb
    If the rotors clear the inside of the upper legs on compression I can't see why it shouldn't work. Machine a stepped axle and a collar/sleeve for the other side where it passes through the the fork, if needed.
    You also have the option of playing with various length rear shocks, sliding the tubes through the trees, tire profiles, or a combination of all of the above to get you to where you want your trail number to be.
    Something that may be of assistance to you. Don't freak out when you see when you see the pic's of choppers :lol3 The trail calculator is at the bottom of the page. Have fun :thumb
    https://www.rbracing-rsr.com/rakeandtrail.html
    #8
  9. Yamarocket630
    Yamarocket630 Long timer
    Sep 15, 2011
    5,206
    Pleasant View, TN
    Maybe I'm thinking about this wrong, but more triple clamp offset (more of a V shape to the clamp like the originals) would give MORE trail, not less?
    #9
  10. FR700
    FR700 Heckler ™©®℗
    May 4, 2007
    18,164
    Your imagination.
    Move the tube centerline forward. What happens to the trail ?
    #10
    smolt and OldDog like this.
  11. Euromad
    Euromad Been here awhile
    Feb 16, 2010
    684
    Lower Slobbovia
    Nice project! You're starting with a Cal III? What else are you doing to the Guzzi? I'm looking at improving the stock 35 mm's
    i have on my modded Cal II. I want to keep the stock exteriors and swap internals for adjustable cartridge assemblies.
    #11
  12. Dino de Laurentiis
    Dino de Laurentiis Working on it
    Mar 20, 2010
    576
    Ultima Thule
    What does the wheel clamps on the stock fork look like? It's not unusual that they are mounted off the fork leg centerline, which in turn also affects trail.
    #12
  13. Scudman
    Scudman Long timer
    Apr 30, 2009
    4,628
    So far I have used Suzuki, Kawasaki and Honda front ends on my Tonti frames. I also have 2 loop projects with modern front ends but have not ridden them yet so no update on handling. Never gave much thought to the offset or frame geometry. I do use a fork that is close to the same length as stock. All of my projects handle better than stock. Some of the better handling can be attributed to the shorter wheel base and much better suspension components. I also use the stock wheels to maintain the older classic look even though the wheels weigh in at crazy heavy numbers. I draw the line on classic look with better brake components. Bottom line, don't over think it, just bolt the front end on and ride it.
    #13
  14. Roadracer_Al
    Roadracer_Al louder, louder, louder!
    Aug 5, 2007
    2,986
    Oakland, CA
    Since you have, literally, a blank canvas to work from, begin by determining how much trail you want.
    I'll throw out that 110 to 115 mm has been a popular, proven number for lots of years.
    Now, determine what your rake and rolling diameter of the front tire are, then figure out what offset you need in the triples.
    It's easiest to do this with a full-scale drawing. The drawing has to have: ground plane, tire diameter, the center-line of the fork tubes, fork length, triple clamps and a known steering tube rake angle.
    If your forks are significantly longer or shorter than stock tubes, take that into account when determining the rake of the steering head tube. Also, don't forget to include sag when making this measurement.
    I consider that it's a given that the fork tubes and steering stem are parallel, although that is not always the case with choppers.
    Draw a line at your rake angle which intersects the ground plane XX mm AHEAD of the contact patch of your tire, extending all the way up to the triple clamps. XX being the amount of trail you have selected.
    Now you can directly measure how much triple clamp offset you need to achieve the amount of trail you want.
    #14
  15. nickguzzi
    Feb 17, 2010
    10,899
    below the sea
    In order to make my guzzi steer faster, I chopped off the steering head and moved it a couple of degrees steeper. It worked OK in so far it didn't become a head shaking mess. I also dropped the forks through the triple clamps about 1/2 inch. I think your geometry changes are reasonably modest in comparison.
    What didn't work was fitting wider rims and tyres. Made it all sloppy and vague. I was trying to make the tip in a bit smoother, but big tyres only made that worse. They were a lot narrower than what you are proposing. I think they are pretty sensitive to tyre profile too.
    Best change was fitting lighter brake rotors. Biggest single improvement.
    There are several different lengths of swing arm available. The late Cali ones being the longest I think. Are you playing with that too?
    After owning several Tonti Guzzis since 1979, I came to the conclusion that the factory had optimised the components the best they were going to be. I tried and altered everything, there was not one original untouched component on my bike.
    Decent forks (Guzzi ones are pretty crap) may just highlight the inadequacies of the rear suspension and short fat contact patches may affect stability in ways the frame is not prepared for.
    #15
  16. nickguzzi
    Feb 17, 2010
    10,899
    below the sea
    Have you tried a dry fit to test out steering lock yet?
    Even with small risers on mine, the bars comes close to the tank.
    #16
  17. nickguzzi
    Feb 17, 2010
    10,899
    below the sea
    While I was concerned about you denting your nice tank or trapping your thumbs, having even less steering lock than standard I found made the bike surprisingly clumsy.
    With guzzi forks I could just pull the bar back to the stop and the bike would twizzle on a sixpence, at least a normal (UK) city street.
    After I fitted Marzocchi 38mm ones I had to reduce the lock quite a bit - made U turns a bit wobbly.
    You will have even less clearance.
    Have fun.
    #17
  18. Scubawerx
    Scubawerx Scubawerx
    Dec 19, 2012
    1,070
    North Georgia
    Me likey. This should be interesting and intelligent reading. Thanks for the pictures.
    #18
  19. NorCalslowpoke
    NorCalslowpoke Long timer
    Apr 19, 2005
    1,536
    RE: swingarm
    Years ago I tried a later, longer/wider swingarm on my T-3 based bike to fit some wider wheels I bought 2nd hand. I think it was off an SPIII. I hated the way it turned. I still have it around and would only use it again if I shortened it.
    I went back to the short stock T-3 swingarm and the stock skinny rear tire. It handled way better for me, especially in tighter corners.
    I did like the change from the stock 18" rim wheel to a 17" rim in the front.
    #19
  20. waylongway
    waylongway madmax
    Dec 16, 2009
    4,216
    NorCal
    #20
    Bananapete likes this.
