New LED's for cars, copper mesh heat management, can it work on a bike?
Discussion in 'Equipment' started by ACD, May 14, 2015.
  1. ACD
    ACD old nOOb
    Aug 22, 2011
    660
    Brazil
    LED H1 4300K 2500 lumens already installed, fits perfectly on this low beam 1150 GSA without the cap, of course. Space inside the housing with cap on is almost nil. The copper mesh is very malleable so it can be bent, there is also one wire that has to come out somehow. The cap would have to be modified to allow the wire and copper mesh to come out but keeping system water tight.
    My test bench (or sofa, actually!)
    Nice cutout.
    Opinions? Suggestions? Thanks
    Sent from my iPad using Tapatalk
  2. Mr.JAJA
    Mr.JAJA Long timer Supporter
    Nov 29, 2010
    2,006
    San Diego, just north of BAJA "
    a little air flow for cooling? why not.
    Do you have a part number?
  3. Corroded
    Corroded Been here awhile
    Aug 25, 2014
    281
    Bay Area, California
    Do you have more details of this? can't see much in the photos?
  4. JR356
    JR356 Long timer
    May 4, 2005
    7,062
    Way Northwest
    Check the Vendor forum,think Sanjoh is already offering similar.
    JR356
  5. def
    def Ginger th wonder dog
    Feb 28, 2004
    14,308
    The woods and mountains of Alabama
    My RPTV uses a similar design to cool the 3 high power LEDs in the light engine. Of course the TV needs a fan to move some air down the cooling duct where the copper radiators are located.
  6. def
    Feb 28, 2004
    14,308
    Yes, current draw, specttum and anything else of interest would be appreciated. Or, how 'bout a link.
  7. Bruincounselor
    Bruincounselor North Plains Drifter Supporter
    Apr 1, 2006
    2,765
    Northen Plain
  8. ACD
    ACD old nOOb
    Aug 22, 2011
    660
    Brazil
    Just google "LED H1 bulb copper" and you get a lot of info.
    I believe the draw is 10W.
    Got these pics from ebay:
    Unfortunately there is not a lot of space inside the headlight assembly to jam the copper mesh in, as you would in a car (pictured above). You have to modify the cap anyway so the black wire can come out. I am considering using a dremel to make a small letterbox like opening in the back or bottom of the headlight assembly cap, to let the metal mesh hanging outside. I made a few preliminary tests, the mesh gets very hot quickly. After a few minutes it is perhaps too hot to hold in your hands. It really draws heat away from the "lamp" itself, increasing performance and durability.
    I am really trying to make this work on my bike. We know the 1150 needs all the help it can get to improve the original lighting!! It will go to my car if everything else fails.
    #8
  9. teomannaskali
    teomannaskali Long timer
    Mar 8, 2011
    1,185
    Plaka 34
    #9
  10. (I^2)R/746
    (I^2)R/746 Rider
    Oct 12, 2012
    626
    Santa Cruz Mountains, CA
    Wonder if you could use a couple of 1/2" PVC elbows with box adapters and hang them out and pointed down. Like the breather tube on the current assembly but bigger. Should be a good enough rain/splash guard in all but the most severe scenarios (such as immersion where you would be screwed anyway). Very KISS and if it fails stick a plastic knockout plug in there and back to the start. Also all the parts are at the local hardware store for a few bucks.
    #10
  11. Anorak
    Anorak Woolf Barnato Supporter
    Jul 23, 2004
    73,076
    Petaluma
    That's a 50 watt resistor. The draw is 50 watts plus whatever the led draws. The resistor is going to create 50 watts of heat.
    #11
  12. def
    Feb 28, 2004
    14,308
    So, were creating a lot of heat just to get an LED to work in the GS headlamp and hanging some metal braid out of the rear of the headlamp assembly to keep the LED cool...I'll pass and stick with a 4300K, 3100 lumen HID.
    #12
  13. Anorak
    Jul 23, 2004
    73,076
    Petaluma
    Yes. The headlight assembly is designed for a hot bulb but where do you install a hot resistor?
    Your bike doesn't need the resistor because it doesn't detect the lower current consumption of the led and cause a bulb fault.
    Also, is the headlight assembly designed to withstand the weight of everything that extends behind the led?
    #13
  14. cele0001
    cele0001 Instigator
    Jan 9, 2014
    583
    Jacksonville, FL USA
    The resistor is capable of dissipating 50W without burning up. The actual heat loss will depend on the current that goes through it and voltage over it.
    Actually in this case only current is relevant.
    #14
  15. Mr.JAJA
    Nov 29, 2010
    2,006
    That what I hate on the LED lights. You go to the $ spend, time, trouble to save (W) Power and than you have to hide this aditonal 50W Resistor's to foul the Onboard Computer. This resistors getting hot to melt the plastic. I have two for the LED tail light/blinker conversion installed on the Panier's frame.:puke1
    #15
  16. Mr.JAJA
    Nov 29, 2010
    2,006
    You will burn your finger's:ear
    #16
  17. Anorak
    Jul 23, 2004
    73,076
    Petaluma
    To avoid a lamp fault it needs to dissipate the same energy as an H7 bulb. Put your finger on one after the led has been on for a while. You will be burned.
    #17
  18. cele0001
    cele0001 Instigator
    Jan 9, 2014
    583
    I don't doubt that the resistor is getting hot. My point is that it doesn't necessarily mean it is getting full 50W hot.
    #18
  19. WindSailor
    WindSailor Been here awhile
    Jan 29, 2008
    795
    Somewhere out West
    I'd rather mount the 'resistor' under the beak... Away from everything...
    Sent from my Samsung Note 3
    #19
  20. teomannaskali
    Mar 8, 2011
    1,185
    Plaka 34
    Install 4 more :) to create a total of 50W.
    #20
