KDX 250 oil pump info
Discussion in '2 smokers' started by Harvey Krumpet, Feb 3, 2012.
  1. Harvey Krumpet
    Harvey Krumpet Long timer Supporter
    Dec 26, 2011
    3,101
    The Shaky Isles
    Kia Ora all,
    I have a water cooled KDX 250, I would guess 94 - 96 vintage. I have been running it on pre mix because I do not trust the oil pump, the bike is a bit of a hack. The pump works & I would rather run it as intended but I have no idea how to service or calibrate it for my piece of mind. Can any body supply some info or links with diagrams so I can check it?
    Yes, I'm a bodger unfortunately, mechanics is not my strong point & I always need guidance, I do everything wrong the first time.... All help appreciated.
  2. peter650
    peter650 Been here awhile
    Oct 18, 2009
    492
    Sydney
    If i was you, i would keep it on premix. That way you can be 100% sure your motor is getting oil, and how much it's getting.
  3. Harvey Krumpet
    Dec 26, 2011
    3,101
    The Shaky Isles
    My concern is that the pump may be lubricating other parts of the engine, I know bugger all about them & am struggling to get info off the web.
    Cheers for the reply.
  4. PistonPants
    PistonPants Crankcase Scavenger
    Jun 11, 2008
    1,133
    Cantwell, AK
    If oil disappears from the tank then it reaches rings rods and mains. Monitor fuel vs oil consumption. A ratio will emerge. Who are we to second guess Kawasaki's engineers? Honestly I thought all KDX's never had injectors. Ether way works.
    Piston
  5. Shocktower
    Shocktower Long timer
    Jul 27, 2009
    9,537
    Oregon City Orygun
    The Anti-Pump guy :norton
  6. welder
    welder Long timer
    Feb 10, 2008
    1,547
    paradise
    I did not realize kdx's had oil pumps. I thought they were premix right from the factory
  7. theMISSIONARY
    theMISSIONARY hunting and riding!!
    May 11, 2006
    3,364
    DeroportTazmania
    we had the KDX 250SR(Japanese model) here in Australia they were a good bike.....however they are now old and being over there have fun trying to find parts new
  8. Harvey Krumpet
    Dec 26, 2011
    3,101
    The Shaky Isles
    Where those bikes road legal? Mine still has the wiring loom on it & a steel tank, everything else is probably lying in the bush somewhere... The motor is basically a KX so I'm told.
    #8
  9. theMISSIONARY
    May 11, 2006
    3,364
    DeroportTazmania
    yes and steel tank is the "SR" model :wink: there was also a KDX200SR so the pump Might (if your lucky) be the same
    #9
  10. Harvey Krumpet
    Dec 26, 2011
    3,101
    The Shaky Isles
    Thank you. I will carry on with my research.
    #10
