junk items from harbor freight
Discussion in 'The Garage' started by stainlesscycle, Mar 17, 2010.
  1. Midnightventure
    Midnightventure -
    Dec 23, 2008
    1,620
    Eldon,Mo
    I bought their AC Manifold tester and the second time I used it one of the plastic knobs broke.
    #61
  2. hangontight
    hangontight Been here awhile
    Dec 1, 2008
    287
    IL
    harbor freight orbital sander...blew out the air seals within 10 minutes (in all fairness I might have not regulated the pressure off the compressor low enough)
    #62
  3. JimVonBaden
    JimVonBaden "Cool" Aid!
    Feb 11, 2005
    101,524
    Alexandria, VA
    I found their electric one to be great. I have used it for at least 40 solid hours with zero issues.
    Jim :brow
    #63
  4. Bobthebiker
    Bobthebiker not normal
    Jul 6, 2010
    496
    west central Florida
    I've used a few things from them. notably their air horn when I had my samurai and NEEDED a louder horn. got a lot of troublefree use from that horn.
    my friend has their wire welder, and stick welder, the wire welder SUCKS, but the stick makes pretty nice welds, and they've got several lifts and motorcycle jacks from there, all working just fine.
    compressors though. buy quality brands, just trust me.
    I've read great reviews though on the gas engines they sell, frm 3-13hp. they're honda clones and I'm seeing people have built the 6hp horizontal shaft models into 14hp and run reliably. I'm picking one up soon as I can for my big compressor, which is more or less a mobile sandblasting machine.
    #64
  5. JimVonBaden
    Feb 11, 2005
    101,524
    Alexandria, VA
    Get him to use a better quality wire, like Lincoln wire from Home Depot. It works MUCH better.
    Jim :brow
    PS It is half the cost of HF wire.
    #65
  6. Bobthebiker
    Jul 6, 2010
    496
    Didnt know that, thanks for the tip. it'd help if we knew how to USE the wire welder better too. the stick is easy for us.
    #66
  7. JimVonBaden
    Feb 11, 2005
    101,524
    Alexandria, VA
    I'm far from an expert, but that simple change in wire made a huge difference in my ability to successfully weld!
    Jim :brow
    #67
  8. jamesgs4
    jamesgs4 Been here awhile
    Apr 18, 2009
    480
    denver co
    You should have bought the w(h)ackbar instead of the prybar, then it wouldn't have shattered. duh
    #68
  9. HuckFarley
    HuckFarley Adventurer
    Dec 1, 2009
    66
    SE PA USA
    Imagine the job security you would have working in the HF returns department!
    #69
  10. groundrules
    groundrules Long timer
    Aug 3, 2007
    2,845
    Oh hiya
    harbor freight is like a disease. I just succumbed and got one of these. diggin' it so far:
    #70
  11. hugemoth
    hugemoth Bad Motorscooter
    Sep 6, 2007
    6,252
    RESIST!
    $20 reciprocating saw chewed up it's gears within an hour of use.
    $36 bench top drill press chuck came apart internally after a year. Ordered a replacement part for under $10 including shipping, working fine after 3 more years.
    Box of various size hose clamps are crap.
    Zip ties are crap.
    Cheap rotary tool is worthless.
    Compressor working fine after 3 years.
    Bench grinder A-OK after 3 years.
    Combination wrenches made in India are fine.
    Screwdrivers are OK.
    Zippo lighter copy is fine.
    Handwarmer (lighter fluid type) better than name brand.
    Digital thermometers A-OK
    Cheap simple pop riveter A-OK, more expensive twistable one junk.
    Safety goggles A-ok
    Flux welder, welding apron, gloves, self darkening helmet A-OK
    Saber saw A-OK
    3/8 hammer drill A-OK
    1000 watt 4 stroke generator failed after 2 years, stuck valve.
    Bolt together trailers are A-OK
    99c stainless steel pocket knife is good
    $2 Multimeters are good.
    Rechargable batteries are good.
    #71
  12. BOBaloo22
    BOBaloo22 Tony & Catnis
    Aug 21, 2009
    5,089
    Orangeburgville, Va
    I got the air powered grease gun the other day looks great but I cant seem to get it to "pick up" the grease. The 1 sheet paper instructions say to burp to purge the air out so I guess I will try again. Am I wasting my time? Anyone else have good luck with one of these?
    Thanks,
    Bob
    #72
  13. hilld
    hilld riding isn't an addiction
    Sep 16, 2009
    268
    Portland, OR - raingear or web feet required
    I think I found your answer, it was on the review of the gg on HF's site. Not my solution.
    ---quoted---
    <dl class="block-content" id="product-reviews-list"><dt> Not bad, but may need a slight modification. Review by Thomas </dt><dd> <table class="data-table review-summary-table"> <col> <col> <tbody> <tr> <th class="label">
    </th> <td class="value">
    </td> </tr> </tbody> </table> This item would work great for bulk grease. I needed it for cartridges...
    I bought one and exchanged it, it didn't work with two good quality cartridges. Got the second one home, same problem. Took apart the grease section of the gun (with a HF air ratchet) and noticed that the rubber piston lip is too large for a cartridge. I checked the hand gun I have and it has a smaller diameter plunger. I trimmed the lip around the circumference a bit with a razor scraper (don't take off too much- you want it snug in the cartridge body), reassembled and it fired grease on the second shot. My hand grease gun is going to be very lonely now. I don't suggest more than 3 pumps on this thing into a ball joint, you can burst rubber seals. Keep an eye on the seal as you pump.
    With all the discounts, it was worth it to me and I kept it even though I had to modify it. Other stores want twice as much for pretty much the same tool. If you oil these air tools they will have a very long life.
    (Posted on 5/28/10)
    </dd></dl>
    #73
  14. Sucks2drive
    Sucks2drive Banned
    Sep 22, 2007
    3,479
    Los Angeles, USA
    I buy what I need to use for a particular job from HF......like say a Cordless drill or a wlve tool.......then you have 30 days to return it for ANY REASON. if it breaks within 30 days i get money back or a new one.... if it breaks within 90 days, store credit or exchange.
    Never a quibble..... cant say fairer than that.
    #74
  15. Jimbozini
    Jimbozini Misadventurer
    Aug 29, 2006
    482
    The Church of the Twisty Road - East Tennessee
    Total garbage, HF Haul-Master Motorcycle Swingarm Rear Stand and Front Fork Adapter
    [​IMG] [​IMG]
    On first look, this appeared to be of acceptable quality and capable of doing the job. In reality, it was incapable of performing its intended function and is downright dangerous to use. First off, the wheels were not in alignment with each other making it impossible to lift the bike and remain level. Secondly, the "prongs" on the fork adapter started to bend when the weight of the bike was applied during the lifting operation!
    I was only trying to lift a YZF600, not a fully laden Harley-Ferguson!
    Needless to say, these two fine examples of Chinese craftsmanship went back to HF and I picked up an overpriced Made-In-the-USA Pit Bull front stand to compliment my existing Pit Bull rear stand. There is something to be said about a quality product that performs its designed function!
    #75
  16. GreaseMonkey
    GreaseMonkey Preshrunk & Cottony
    Jun 16, 2006
    6,001
    The only county in Illinois with no train tracks
    I got a dual sided carborundum stone (combination sharpening stone #7345) and it is pretty useless as a sharpener as the particles of the stone are not abrasive at all. Granted it is only $3 but it's a waste of $3.
    #76
  17. JTucker
    JTucker Long timer
    Sep 27, 2008
    2,270
    West By God Virginia
    Generally speaking you can look at the hand tools and tell if they're going to be junk or not. some are decent, some aren't. Most of the air tools the aren't super cheap are ok. The earthquake impacts are good.
    The power hand tools are mostly acceptable just stay away from the drill master stuff.
    As long as you don't expect a $20 grinder to be as good as an $80 one everything is usually alright.
    #77
  18. mrchristian
    mrchristian Been here awhile
    Nov 23, 2008
    847
    LA, CA
    Has anybody used the harbor freight dirt bike stand? $16 after the usual 20% coupon. Crazy cheap. I just don't want to crush it the first time I swing my WR400 on it.
    I have had a lot of those LED lights stowed in my car/camelbak/desk that are free with the coupon. They work fine. Their $3 ratcheting tie downs work fine for dirt bikes,
    #78
  19. JeffD
    JeffD Been here awhile
    Nov 30, 2002
    487
    missoula,mt
    no but it looks like it might make a good portable shitter LOL.
    #79
  20. MiamiMotorcyclist
    MiamiMotorcyclist used to be -MiamiUly
    Jul 11, 2007
    10,390
    Miami, Fl.
    A friend uses the other syle HF dirt bike lift/stand and has been happy with it.
    They would have to out do themselves in a big way to make this stand so bad that it wouldn't work.
    #80
