Right side drive two strokes
Discussion in '2 smokers' started by Rokoneer, May 31, 2012.
  1. Rokoneer
    Rokoneer Been here awhile
    Sep 23, 2006
    677
    Upstate, You Nork
    Contemplating a two stroke engine transplant in to former four stroke machine that has a right side countershaft and thus right side chain drive.
    Looking for suitable 2T motorcycle engines, either singles or multiple cylinder, that are right side drive. Trying to keep cost reasonable so anything exotic or current may not be the best option. Been looking at air cooled vintage stuff but older liquid cooled stuff could be a consideration as well.
    Rotax/Bombardier, Husqvarna and Ossa are the few I know off hand. Pleas enlighten me to any that you are aware of.
    Muchos GrassyAss!
  2. ppe172
    ppe172 Been here awhile
    Nov 6, 2007
    170
    1980+ it175, it200.
  3. Rokoneer
    Sep 23, 2006
    677
    Upstate, You Nork
    Interesting! I wasn't aware that any of the Japanese manufacturers had done a right side drive. Thanks for that.
    Ideally I'd like a bit more displacement than a 175 or 200, but beggers can't be choosers.
  4. anonny
    anonny What could go wrong?
    Mar 20, 2007
    7,400
    Beautiful Revelstoke BC
    Ummm couldn't you just flip the wheel around and remake spacers and brake stays? Or respoke the hub to flip it?
  5. stainlesscycle
    stainlesscycle Long timer
    Jun 6, 2008
    2,329
    morgantown, wv
    can-am 175/250 right side drive. it200 would be my choice, there's alot of power to be unlocked in those motors, and parts are cheap (aside from cylinders/heads....) ... the can-am 250 would be great - it's not as wide as other rotary motors - and they're built pretty stout..
    as for flipping to left side, if it's drum brakes, it can be tough - figuring out brake lever to rod crossover or converting to cable rear (easier)....
    i'm trying to jam a mx175 motor into a puch 175 frame - no mounts match up, and figuring pipe will be a chore.
  6. jar944
    jar944 Long timer
    Aug 2, 2010
    1,813
    Warrenton
    ktm 440/500/550
  7. Abdelhub
    Abdelhub Blanco Trasho
    Nov 24, 2007
    728
    Snohomish County
    montesas are right side...
    Mike
  8. Rokoneer
    Sep 23, 2006
    677
    Upstate, You Nork
    Or just flip the swing arm over and you're all good, right!:D
    Simple and inexpensive (ha!) are hoped for with this project.
    You can't strip a perfectly good Can-Am Rat, you just can't!
    Any multi cylinder right side drive 2t's anyone is aware of?
    #8
  9. ADV8
    ADV8 Long timer
    Nov 10, 2007
    2,767
    North of Sydney.
    Add early 1980's CR250 Honda engines to that,right hand chain,left side kick.
    #9
  10. mtothef
    mtothef perpetually furrowed brow
    Dec 23, 2006
    549
    deep in the poison oak somewhere inland of big sur
    honda cr480. last of the air-cooled dinosaurs.
    #10
  11. Neil E.
    Neil E. Been here awhile
    Jun 1, 2004
    873
    Gormley ON
    Let me guess ........ Husaberg frame?
    Consider the exhaust port location (height/angle) so you are sure the exhaust will clear the frame.
    #11
  12. Rokoneer
    Sep 23, 2006
    677
    Upstate, You Nork
    Just imagine a 'real' Swedish built Husaberg frame with a 430 or 500 Husqvarna 2T engine swapped in? Huge power, very light due to losing the liquid cooling components, simple mechanics, reliable electrics.....
    It'd be the bike Husaberg should have built!
    #12
  13. Neil E.
    Jun 1, 2004
    873
    Gormley ON
    I had a Husaberg and wanted to do a 2T conversion. I looked at everything from ultralight motors to rotary engines for go-karts. The tough part was how to marry anything to the Husaberg gearbox to keep the nice wide ratios. A 2T bike engine is a better choice, but 4T frames run close to the front wheel and don't leave much room for a pipe.
    #13
  14. taosgsr
    taosgsr We are all earthlings… be nice to each other.
    Apr 30, 2009
    718
    Tucson AZ
    WR 250 and 300 Right side drive still to this day.
    #14
  15. THE PIG
    THE PIG Vtech
    Dec 4, 2007
    25
    Hamilton. Ontario.
    About Jawa 350.
    #15
  16. Scootern29
    Scootern29 Long timer
    Sep 4, 2012
    1,081
    In the hot, hot, dezert
    Put a CZ motor in it. They are indestructable. This is what I did with a Husky chassis.
    #16
  17. lamotovita
    lamotovita DAMN SNOWBIRD!
    Oct 5, 2007
    4,912
    WA/AZ, USA
    Yankee 500 comes to mind.
    #17
