UHF Radio Questions
Discussion in 'Australia' started by ozadvntr, May 1, 2007.
  1. ozadvntr
    ozadvntr Planning that trip, again
    Sep 15, 2002
    1,208
    Queensland, Australia
    After some information as to the best UHF to purchase.
    What brand is preffered?
    What wattage, 1W, 3W or 5W?
    Are there handlebar mounts available for the radio itself?
    reliability?
    I saw the add in Trailzone from Days Motorcycles in Victoria and thought the deal looked pretty good, any advice would be appreciated.
  2. Major
    Major Major Catastrophe
    Mar 21, 2006
    793
    Newcastle
    We run ours through Autocom units permanently mounted and hardwired to bike. Pretty good range in thopen. Probably around 5km's.
    Hope this helps.
    Can post pics if needed.
    Cheers,
    Grant
  3. Dirt Doctor
    Dirt Doctor Geographicallyembarrassed
    Feb 5, 2005
    1,218
    Bathurst 1000, Australia
    Gman640 and I both run gme tx6200 with the ptt button attached to our camelbag chest strap and carry the radios in our camelbacks.
    Both have the trailzone set up and they work well up to about 70km/h after that you know when somebody is speaking but not much else. good for warnings about oncoming cars, stock on the road etc etc
    Found that if there are 2 many cables (such as the ptt and/or power cable) attached between you and the bike you will break one the first time you have a lay down.
    ktmajor has a good set up.
    range depends on the terrain 10-15k out west 1-2k in really hilly areas.
  4. Hunsta
    Hunsta Have guns will hunt
    Jan 25, 2006
    5,508
    Gympie Queensland Australia
    Mate I wouldnt piss around with anything less than a 5watt. I take a
    Uniden UH-052XR. Can be switched from 1 watt to 5 depending on your distance. Those 1 watt jobs are useless if you are in thick trees. I do believe that Days motorcycles is doing great deals on 5watt units with PPT setups.
    Cheers
    Craig
  5. Dale950
    Dale950 Long timer
    Sep 7, 2004
    1,069
    Melb / Australia
    I finally hooked my helmet/ mic set up I got from Day's Motorcycles ( 12 months ago ) , turns out they have a two pin plug , so it will only fit a UHF radio with a two pin setup , it did fit a Gme but didn't perform to it full potential . Phoned Day's , they said go for the 2 watt Uniden UHO44 , it turns out it's pretty much a discontinued model but managed to get my hands on one . The new model is not released till next month .
    Havn't fully tested it yet as it's for a trip leaving this weekend .
    Cheers
  6. nevgriff64
    nevgriff64 .
    Nov 24, 2005
    21,239
    Melbourne Australia
    I have a Uniden UH075 which is water resistant and also an Autocom system..
    Don`t know how they work cause I`m too bloody lazy to get off my ass and hook them up.. :dunno
    The only down side to the Uniden is that the battery only lasts for 12 hours between recharges.. As far as I know there is no power supply that can be hooked direct to this unit.. It can sit in it`s own recharge cradle but that would be no good for traveling..
  7. Hunsta
    Jan 25, 2006
    5,508
    Yeah the 52XR has the same battery set up, but it does have a DC plug outlet. However Im having trouble finding one for it.:dunno
  8. nevgriff64
    nevgriff64 .
    Nov 24, 2005
    21,239
    Melbourne Australia
    I bought all the UHF stuff off ebay Hunsta.. I can give you the store details if you want..
    #8
  9. Hunsta
    Jan 25, 2006
    5,508
    Fire away sir. What I been search for.
    Cheers
    Craig
    #9
  10. nevgriff64
    nevgriff64 .
    Nov 24, 2005
    21,239
    Melbourne Australia
    This is the store that I dealt with and seem pretty good with posting and delivery.. Hope the link works..
    http://myworld.ebay.com.au/uhf_gps_plusmore
    #10
  11. Autostream
    Autostream Long timer
    Aug 1, 2005
    5,832
    Belgrave, Victoria, Australia
    I'm running the GME TX6200 - chosen because it has a bullet proof chassis, 5w, great battery life.
    Running through my Starcom system which incorporates the PTT button as well as letting me plug in GPS, Phone and Ipod... can get a bit busy in my helmet at times...
    I leave the radio and Starcom unit in the Glovebox on the 950.
    I have the radio connected to an in car kit with a medium gain aerial mounted on the rear of the bike. The incar kit connects the aerial as well as trickle charges the battery via the aerial socket. I have cut up the original housing that is also a Mic bracket so it is about 60x20x30mm
    I use a medium gain aerial as the higher gain you use the less the angle of transmission which can limit range on hilly terrain.
    #11
  12. Hunsta
    Jan 25, 2006
    5,508
    Yeah link worked. Didnt see anything for mine, but fired off an email to them to see if they can source the stuff(with part numbers) I want.
    Thx Nev
    Cheers
    Craig
    #12
  13. Andrew2
    Andrew2 Long timer
    Aug 3, 2005
    9,237
    Wollongong,N.S.W.
    Hve Days M/C got a web site?
    #13
  14. Autostream
    Aug 1, 2005
    5,832
    Not shown in Trailzone offer so I doubt it.
    #14
  15. Andrew2
    Andrew2 Long timer
    Aug 3, 2005
    9,237
    Wollongong,N.S.W.
    Thanks mate.By the way did you get your packet from me Ben?
    #15
  16. nevgriff64
    nevgriff64 .
    Nov 24, 2005
    21,239
    Melbourne Australia
    Your welcome.. :thumb
    Hope they can help out..
    #16
  17. Autostream
    Aug 1, 2005
    5,832
    I did thanks Mate. Seems to be a lot there. Do I owe you anything?
    #17
  18. Andrew2
    Andrew2 Long timer
    Aug 3, 2005
    9,237
    Wollongong,N.S.W.
    No mate,my apologies for the wait.
    Cheers
    Andrew
    #18
  19. AusGoFar
    AusGoFar get back on that horse
    Jul 16, 2006
    1,266
    Burwood, VIC, Australia
    #19
  20. Autostream
    Aug 1, 2005
    5,832
    No worries, just remember to watch which way I go, so I don't lose you.... again!
    #20
