Airhead Center Stand Issues
Discussion in 'Old's Cool' started by RichHead, Jan 20, 2009.
  1. tathambenjamin
    tathambenjamin Been here awhile
    Oct 31, 2007
    563
    Dekalb, IL
    yep, despite the name "reynolds ride off", I would never consider actually doing so a good idea. The low height may be a problem, I had not noticed that. I just meant o allude mostly to te fact that it looked a lot sturdier from side to side. I am planning on sticking with the stock stand....
    #21
  2. Max Headroom
    Max Headroom lost in the '70s
    Feb 19, 2008
    537
    New Zealand
    Given the option, I wouldn't use a Helicoil to repair a mainstand lug. The load on the thread is a sideways one, and tends to pull the spiral out of the lug after a while (and yes, you can ask me how I know....).
    There are more effective solutions available. If WIREWRKR's fix involves a theaded bush with a flange, I'd go that way.
    I went a step further when I rebuilt my bike a few years ago. I figured that the design was just too weak, and came up with a solution that works for me. The bush that the CS pivots on is now captive between the original lug and a new lug welded onto the frame, making it a true clevis. The new lug is machined to take a countersunk internal hex bolt so that everything is flush with the frame and won't foul the exhaust or footpegs.
    It's a fit'n'forget solution.
    Here's a piccie of the new lug and the countersunk bolt:
    Once assembled, it looks like it should be there, and has about 6-8mm clearance for the exhaust:
    #22
  3. bmwrench
    bmwrench Long timer
    Nov 10, 2006
    10,195
    Wow! Very nice.
    #23
