LED Auxiliary Lights
Discussion in 'Vendors' started by sanjoh, Aug 5, 2010.
  1. ewagman
    ewagman Adventurer
    Nov 3, 2011
    50
    DE, Coastal
    I like the recessed look to the 60's, but what about cooling airflow? Is there a limit to how long can you run them at slow speed without overheating? Did you wire in a relay with 16 LEDs drawing current? Any radio interference? Those 64's are big in comparison aren't they! I'd love to see some nite shots on a long straightaway the 60's, the 64's and all on, and with the Ford lights for comparison.
  2. sanjoh
    sanjoh Long timer
    Feb 13, 2007
    9,406
    Here
    Model 60 and 30 compliment each other very well, although most customers have found a pair of 60s to be awesome. Lots of lighting to the sides and plenty of distance.
  3. sanjoh
    sanjoh Long timer
    Feb 13, 2007
    9,406
    Here
    Model 30 light on Sale 25% off
    Normally $60.00 each now $45.00
    Don't forget the "inmate" discount. ~$80 for a Quality set (that's a pair:D) of Lights.
    • Spot Beam
    • 1500 lumens
    • .85amp@12v
    • 3 LEDs
    • aluminum housing
    • Length: 70mm , Diameter 55mm
    • black durable coating
    • o-ring sealed housing
    • one meter wire lead
    • includes flat mount (stainless) mounting bracket
    • glass shatter resistant lens
    • Sold individually
  4. Dusty_Bottoms
    Dusty_Bottoms Part Time Adventurer
    May 8, 2011
    1,234
    Fort Collins, CO
    Sanjoh,
    I'm running 2 44's with the rotary dimmer with high beam circuit. If I want to add a single 30 to get the longer spot beam effect, but still leave both 44s, can that be wired into the existing circuit and dimmer switch?
  5. sanjoh
    sanjoh Long timer
    Feb 13, 2007
    9,406
    Here
    Yes, the rotary dimmer is good for up to 72 watts, a model 30 + 2x Model 44 puts you @ 50watts. You should be fine.
  6. Dusty_Bottoms
    May 8, 2011
    1,234
    Fort Collins, CO
    Excellent.
    Incomiiiiiing!
  7. ewagman
    ewagman Adventurer
    Nov 3, 2011
    50
    DE, Coastal
    Which would have the greater distance reach, a pair of 60's or a 60 with a 30?
  8. sanjoh
    sanjoh Long timer
    Feb 13, 2007
    9,406
    Here
  9. patrick1
    patrick1 Adventurer
    Apr 10, 2012
    48
    Sydney
    Does anyone have pics of lights mounted with the "Crash Bar Light Mount" Im trying to work out where i can mount my set of Model 60's on my sv1000.
    Already broken a set of the heavy duty mounts (different bike) so thought I might give the crash bar mount a go.
    This is the one im taking about
    http://stores.advmonster.com/-strse-43/Crash-Bar-Light-Mount/Detail.bok
  10. sanjoh
    sanjoh Long timer
    Feb 13, 2007
    9,406
    Here
    Here's a beautiful GS with the crashbar light mounts.
  11. patrick1
    patrick1 Adventurer
    Apr 10, 2012
    48
    Sydney
    thanks, so would i need a set of standard or HD mounts to mount the light to the the crashbar mount? Can't quite tell
  12. sanjoh
    sanjoh Long timer
    Feb 13, 2007
    9,406
    Here
    Either mount will work fine. The HD mount is a much thicker version of the standard mount, otherwise the geometry is the same.
  13. sanjoh
    sanjoh Long timer
    Feb 13, 2007
    9,406
    Here
    What year is your SV?
    Perhaps under the mirrors?
  14. TonyfromOR
    TonyfromOR Adventurer
    Jan 13, 2013
    65
    Oregon, Peoples Republik of
    OK, so what do I enter in the coupon code to get the "inmate" discount?
  15. SiBC
    SiBC Adventurer
    Dec 25, 2012
    19
    You enter "inmate". Doesn't know if it is supposed to be capital i or not, but you will figure that out.
    Sent from my iPad using Tapatalk HD
  16. sanjoh
    sanjoh Long timer
    Feb 13, 2007
    9,406
    Here
    What's inside the quotes:wink:
    Put it in during checkout in the promotion code box, typically on the left side of the screen. Discount should show up.
  17. fyrfytr
    fyrfytr B.U.F.F.
    Sep 19, 2007
    3,419
    Jersey, the New one.
    I just ordered the lights you have on special. Thanks too for the ADV discount. They will be going on an '06 Tiger. Will the supplied flat mount work for me, or will I have to break out the MIG and build something myself? Thanks again.
  18. sanjoh
    sanjoh Long timer
    Feb 13, 2007
    9,406
    Here
    • Spot Beam
    • 1500 lumens
    • .85amp@12v
    • 3 LEDs
    • aluminum housing
    • Sold individually
  19. sanjoh
    sanjoh Long timer
    Feb 13, 2007
    9,406
    Here
    Thanks for your business!
    The included mount will mount to a 6mm stud or flat surface 25mmx25mm with a bolt.
  20. fyrfytr
    fyrfytr B.U.F.F.
    Sep 19, 2007
    3,419
    You're welcome, just got the e-mail that they shipped. That's awesome!
    I think I might be able to do something with the mount. There's lots of bolts on the front fender.
