Brake pads won't fit
Discussion in 'Parallel Universe' started by DualDude, Aug 11, 2013.
  1. DualDude
    DualDude Adventurer
    Oct 29, 2007
    42
    Colorado Springs, CO
    I went to replace the rear break pads. I pushed back the piston and removed the old pads which are almost gone. When went to install the new pads I discovered the right side pad will not fit. I thought they may be defective so I ordered another brand. They are exactly the same. They wont fit ether. There is a huge space on the left side but not enough space on the right side between rooter and the break assembly. Has anyone had this problem and if so what did you do to correct it?
    Any help would be appreciated.
  2. itsatdm
    itsatdm Long timer
    Jun 19, 2004
    5,440
    Nor Ca.
    Google sliding pin calipers. You make room on the right side by pushing the whole caliper from the left side.
  3. murpies
    murpies Been here awhile
    Apr 2, 2011
    199
  4. jackalsour
    jackalsour Xennial
    Dec 14, 2010
    1,106
    Transient
    I just changed mine yesterday and I found it tricky to push the caliper over while lining the pin with both pads... so I just spent the extra 30 seconds to remove the rear wheel. Very easy with the wheel off and also easier to get the pin and clip back on. As a bonus I had a chance to check the rear wheel bearing which is a common F800 weak point.
  5. Goldfish_GR
    Goldfish_GR Adventurer
    Jun 1, 2013
    58
    Athens, Greece
    Why don't you take the caliper off instead of taking the wheel?
  6. jackalsour
    jackalsour Xennial
    Dec 14, 2010
    1,106
    Transient
    I was wondering can you take the rear caliper off? There's a weird rubber boot that wraps through the caliper.. figured I should just leave that be. Besides, I had to check that wheel bearing and adjust my chain :lol3
  7. minton82
    minton82 Adventurer
    May 9, 2013
    36
    Seoul
  8. Bucko
    Bucko In a parallel world
    Mar 20, 2004
    858
    South Coast, CA
    I just replaced my pins and clips when swapping out the pads. The pins were looking pretty corroded up front, and I'd injured one of the springy clips in the rear while re-installing the wheel early on. BMW's little kits aren't cheap, but better to pay up front that have a braking problem. My OEM pads went 35k miles, so won't have to be doing this toooo often.
    #8
