my toilet died last night.
Discussion in 'The Garage' started by LuciferMutt, Jul 21, 2011.
  1. LuciferMutt
    LuciferMutt Rides slow bike slow
    Aug 19, 2008
    20,595
    New(er) Mexico
    I just got a new roof on my house a few weeks ago. Last night was the first really substantial rain (downpour) we have had since so it was the acid test for the roof. For the first hour of the rain I was running around the house inspecting all the areas that could spring leaks if there was a problem with the roof.
    Just before bed I'm starting to calm down. No leaks, roof seems to be doing great.
    Go to use the downstairs bathroom and step onto to the bathmat to find it completely soaked with water. FUCK! WATER IS COMING DOWN INSIDE THE WALL!!
    Wait...what's this? Upon closer inspection, I discover that that tank on my toilet sprouted a completely random crack through the porcelain up the entire height of the tank and the tank was pissing water all over the floor. I was quite relieved to find this was the problem and not the roof :lol3 Still need a new toilet now though -- this one is a POS and should have been replaced years ago. Anybody's tank just randomly crack in half? I had just been in that bathroom hours ago and no water. I almost wonder if one particularly loud thunder clap caused the crack to start. :patch
    Unfortunately, last time I had this toilet off the floor, the flange was nearly sacked. I barely got it to hold the toilet down to the floor and this is in a semi basement on a concrete slab.
    So when the new toilet goes down (probably a Toto...wife wants to spend big $$$ and get something good. :dunno ) I already know I'm going to be dealing with a broken flange.
    It's a metal flange on a PVC pipe coming out of the slab. Suggestions for replacement that don't involve jack hammering out the damn slab?
  2. troidus
    troidus Long timer
    Sep 1, 2010
    64,350
    Georgia
  3. P B G
    P B G Long timer
    Mar 7, 2008
    10,004
    Greater Chicago
    get a repair flange, and just lay it on top with some mastic and clamp it together.
  4. dualbert
    dualbert I'm not like the "others"
    Jul 20, 2009
    129
    Chattanooga, TN
    You will need to go to a dedicated plumber's supply type store. Sometimes you can find a flange extension, its like half inch thick and can attach to the current flange, either by fasteners or epoxy. Then acquire a wax ring with an extended flange tube that is long enough to pass through both flanges. Depending on how high the extension is, you may have to cut down the wax ring a little or heat the piss out of it with a hair dryer and crush it in when installing the toilet. Both parts should collectively be under $20, with some quantity of beer.
    Keep in mind, I'm a graphic designer, not a plumber. Hell.... I'm still getting oil in my SMRs radiator if that helps prove that I may not be the best resource. So when you go to the plumber supply, take a picture of your situation, make some measurements and the desk should be able to sort you out.
    -db
  5. Foot dragger
    Foot dragger singletracker
    Dec 27, 2006
    35,002
    The West
    That sounds about right,I used to do remodels for a living,toilets crack REAL easy,they are just a big piece of glass. They need a level area to sit on or they leak or crack,over tightening the tank or the foot can easily crack the newest most expensive toilet. Sometimes I would double up the wax ring or buy a thick one for a better seal.
    Setting a toilet down too hard on a tile floor can crack it rt out of the box. No problem as long as your careful.
    Women Love expensive toilets!!!!!!!!!!! Id rather have the carb parts for my Triumph in hand then a shiny toilet.
  6. LuciferMutt
    Aug 19, 2008
    20,595
    New(er) Mexico
    What is mastic?
  7. larry0071
    larry0071 Been here awhile
    Apr 12, 2010
    275
    Beaver County, PA (Ambridge/Rochester, RT-65)
    A waterproof, putty-like paste used in building as a joint-sealer or filler.
  8. troidus
    troidus Long timer
    Sep 1, 2010
    64,350
    Georgia
    I'd rather not ever have to plunge a toilet. I forgot all about the expense of mine after the first week of not having to plunge the thing every day. After a couple of months, the plunger ended up in the shed and hasn't seen the light of day since. I'm sure the water and time savings have paid for some other shiny things, not to mention not having to approach the flush button with trepidation every time we use the bathroom.
    #8
  9. H96669
    H96669 A proud pragmatist.
    Nov 20, 2009
    6,689
    Hiding off Hwy 6, B.C.
    You are lucky you were home, I have seen what one of them cracked reservoirs can do to a house when left for a few hours, better call the insurance then.:huh
    Can they crack on their own?....well we saw that happen once, lucky we were drinking at the kitchen table and saw the "flood" come out of the bathroom before it got into the carpets. Then we had to play "Drunken Plumbers"....:freaky
    Then went home and.....put some fiberglass tape around my cracked reservoir, had never leaked but....!:eek1
    You may want to look at them in line "Water shut off devices", cheap insurance.http://www.wattscanada.ca/pages/_products_details.asp?catId=1159&parCat=1386&pid=600&ref=2
    #9
  10. MagyarMan
    MagyarMan Long timer
    Dec 8, 2009
    3,302
    Chicken Necker Side
    My basement toilet flange was broken. Went to home depot ,picked up a part that looked like 1/3 of a flange . Slipped it
    under the original flange and bolted it up. It works ok.
    #10
  11. Switchblade315
    Switchblade315 I make people disappear
    Oct 10, 2009
    8,128
    Watching Bridges Burn
    i want a tankless industrial model that will flush a soft ball with out clogging. you know the ones that cause a draft in the room when you flush. :rofl yeah that's what I'm getting when one of mine die.
    #11
  12. mcma111
    mcma111 Long timer
    Jul 17, 2007
    18,735
    San Francisco,Ca.
  13. troidus
    troidus Long timer
    Sep 1, 2010
    64,350
    Georgia
    That Caroma I linked will pass a tennis ball. I tested it before installing it. I think a softball might be a bit too big. As for tankless, you need a largish supply line with good pressure for it to work, and they're not particularly efficient.
    #13
  14. DELTATANGO
    DELTATANGO Motorcyclist and Dog Walk
    Nov 27, 2005
    18,484
    Alabama
    Are you sure it's the toilet leaking.
    Maybe the toilet is just cracked and not leaking but the new roof is leaking around the vent.
    Just a thought..................
    #14
  15. LuciferMutt
    Aug 19, 2008
    20,595
    New(er) Mexico
    Nah. It rained a good couple of hours after I cleaned up the water on the floor and there was no new water in the morning. Plus I could see the water dripping from the crack in the tank.
    #15
  16. boxermoose
    boxermoose Regressive airhead Supporter
    Sep 18, 2003
    3,894
    Baton Rouge Eh!
    #16
  17. Switchblade315
    Oct 10, 2009
    8,128
    the ones I'm speaking of would destroy the softball not flush the thing whole... :rofl we have one at work i swear it creates a draft in the room with it's flushed. I swear that thing would take the hide off a softball and then destroy the innards. :lol3 I'm joking here about the ball but not about the draft.
    #17
  18. DELTATANGO
    Nov 27, 2005
    18,484
    Alabama
    #18
  19. GreaseGorilla
    GreaseGorilla Banned
    May 30, 2011
    415
    Spain
    Get a KLR rider to repair it, at most it will cost ya duct tape, some silicone and maybe 2 cans of PBR.......:evil
    #19
  20. concours
    concours WFO for 50 years
    Dec 2, 2008
    9,696
    USA
    I keep trying to ignore the voices in my head when I peruse the list of topics... but the "toilet blew up" by Zappa keeps coming through! :norton:huh:1drink:lol3
    Flakes! Flakes!
    Flakes! Flakes!
    They don't do no good
    They never be workin'
    Whe they oughta should
    They waste your time
    They're wasting mine
    California's got the most of them
    Boy, they got a host of them
    Swear t'God they got the most
    At every business on the coast
    They got the Flakes
    Flakes! Flakes!
    They can't fix yer brakes
    You ask 'em, "Where's my motor?"
    "Well, it was eaten by snakes..."
    You can stab 'n' shoot 'n' spit
    But they won't be fixin' it
    They're lyin' an' lazy
    They can be drivin' you crazy
    [Take it away, Bob...]
    I asked as nice as I could
    If my job would
    Somehow be finished by Friday
    Well, them whole damn weekend
    came 'n' went, Frankie
    [Wanna buy some mandies, Bob?]
    'N' they didn't do nothin'
    But they charged me double for Sunday
    You know, no matter what you do,
    They gonna cheat 'n' rob you
    Then they'll send you a bill
    That'll get your senses reelin'
    And if you do not pay
    They got computer collectors
    That'll get you so crazy
    'Til your head'll go through th' ceilin'
    Yes it will!
    I'm a moron, 'n' this is my wife
    She's frosting a cake
    With a paper knife
    All what we got here's
    American made
    It's a little bit cheesey,
    But it's nicely displayed
    Well we don't get excited when it
    Crumbles 'n' breaks
    We just get on the phone
    And call up some Flakes
    They rush on over
    'N' wreck it some more
    'N' we are so dumb
    They're linin' up at our door
    Well, the toilet went crazy
    Yersterday afternoon
    The plumber he says
    "Never flush a tampoon!"
    This great information
    Cost me half a week's pay
    And the toilet blew up
    Later on the next day-ay-eee-ay
    Blew up the next day
    WOO-OOO
    We are millions 'n' millions,
    We're coming to get you
    We're protected by unions
    So don't let it upset you
    Can't escape the conclusion
    It's probably God's Will
    That civilization
    Will grind to a standstill
    And we are the people
    Who will make it all happen
    While yer children is sleepin',
    Yer puppy is crappin'
    You might call us Flakes
    Or something else you might coin us
    But we know you're so greedy
    That you'll probably join us
    We're coming to get you, we're coming to get you
    We're coming to get you, we're coming to get you...[​IMG]
    #20
