ADV R80ST Registry
Discussion in 'Airheads' started by England-Kev, Oct 1, 2008.
  1. BMWrider79
    BMWrider79 Here
    Aug 6, 2011
    2,734
    Japan
    The ST really isn't a long distance freeway eater, but that kind of riding is a pain in the ass regardless of what you ride. As you have seen they are great for narrow twisty roads - the gearing and f/d ratio are well matched for just such roads. I've put a taller fifth in mine mostly so that I can not be right at redline while on the unavoidable sections of highway between the fun roads. Of course in the US west I prefer to ride my RS.....
  2. Sibbo
    Sibbo Been here awhile
    Sep 23, 2009
    357
    Tweed Valley , Northern NSW
    How many rpm are you doing at 60mph 79 ?
  3. hardwaregrrl
    hardwaregrrl Can't shoot straight Supporter
    Jan 26, 2006
    10,219
    Atlanta
    I'm spinning 5k at 80mph. I ride freeway a lot, unfortunately, in Atlanta which is kind of like playing frogger. STock box and FD, bike does very well in my opinion.
  4. Sibbo
    Sep 23, 2009
    357
    Hmmm... that's pretty much what my girl does, I guess I'm just averse to much over 4000 rpm sustained . I like revs on the hills and twisties but not for hours at a time .... no good reason .:hmmmmm
  5. Sibbo
    Sep 23, 2009
    357
    Really interesting ideas, my ST has a 100GS tank and for long trips on the tar it's great but the weight is too high on the dirt or moving very slowly.
    Thinking, thinking .
  6. BMWrider79
    BMWrider79 Here
    Aug 6, 2011
    2,734
    Japan
    Sorry, I don't know yet. I bolted up the neg. cable for the first time yesterday to see if all the electrics work. The Eastern Beaver headlight relay kit worked well and the starter engaged, but sadly the turn signal relay seems to have bit the dust.
    Like you suggested I don't expect the 5% taller gear to be a great change - just something I could do while I had the box apart and with the lower ratio of the f/d I can't imagine it'll put much more strain on anything. Airhead engines run just fine for hours on end at the upper rev. limits though so don't worry about that.
  7. hetkind
    hetkind Adventurer
    Jun 13, 2006
    96
    North East TN - Shiny Side Up Motorcycle Rescue
    Actually these bikes are designed to run between 4-6k on a continuous basis...normally I run mine between 4-5k. 4K is suggested as a minimum RPM for normal use.
    Howard
  8. Sibbo
    Sep 23, 2009
    357
    Really? I've never seen that quoted before , it certainly puts my prefered use outside guidelines !
  9. hetkind
    hetkind Adventurer
    Jun 13, 2006
    96
    The 4k normal RPM range is based on 3k required for full alternator operation and 4k is suggested as not to "lug" the engine and to give full oiling to things like the valve train and timing chain.
    This figure has been highly debated on the "Airheads" list server and supported by some of the American "gurus" like Oak, Snobum and Cutter, two of those I know personally and one who has been a houseguest of ours.
    Howard
  10. Sibbo
    Sep 23, 2009
    357
    OK, good to know although I usually bumble along at between 3000 and 4000, I'll try to overcome my prejudice against high revs !
  11. bpeckm
    bpeckm Grin!
    Apr 2, 2008
    8,035
    Portugal
    Anton has a good gear ratio chart, you can play with different rear end and gear combinations to find theoretical rpm's at speed...
    Per his chart, the standard ST with a 37/11 (3.36) rear end, at 5000 rpm in fifth you are doing approx 75mph.
    :D
  12. mark1305
    mark1305 Old Enough To Know Better Supporter
    Feb 7, 2005
    6,776
    Merritt Island, FL
    My results agree with what Bob just posted from Anton's info. My tach starts to get erratic when cruising at anything over about 5200 for more than a couple of minutes. But during my slogs up I-95 to get out of Flatistan and onto regular hiways I'm matching most car traffic at 5K rpm. And experience has shown that most traffic on that stretch runs at about 74-75 mph.
  13. bpeckm
    bpeckm Grin!
    Apr 2, 2008
    8,035
    Portugal
    Finally figured a way to put Anton's chart on here (but it is interactive if you go to the site)
    :evil
  14. Airhead Wrangler
    Airhead Wrangler Long timer Supporter
    Mar 4, 2008
    7,275
    Back in Seattle, FINALLY
    The one thing to remember with that is that it assumes a 6.6 foot wheel circumference. I'm not sure what the circumference of the 18" ST rear wheel is. Anyone care to wrap a measuring tape around?
  15. mark1305
    Feb 7, 2005
    6,776
    Merritt Island, FL
    I measured mine with a 50% tread Avon Distanzia and got 6' 10".
  16. Airhead Wrangler
    Mar 4, 2008
    7,275
    ...which is exactly what I happen to have on my back wheel at the moment. 82/79 = 1.0379 so add 3.8% to those speeds for our wheels.
  17. hardwaregrrl
    Jan 26, 2006
    10,219
    Atlanta
    Got the same thing with a fairly new 606.:huh
  18. mark1305
    Feb 7, 2005
    6,776
    Merritt Island, FL
    Something drifted through my brain this morning about wheel circumference - I have a faint recollection that rolling circumference may be different than static measurements due to the slight reduction in radius at the contact patch as the tire deforms ever so slightly from the load on it. May be hogwash, or something I dreamed. If the rain showers will hold off for a little while I will roll the ST out and pick up the actual rolling circumference with my weight on the bike.
  19. hetkind
    hetkind Adventurer
    Jun 13, 2006
    96
    or simply go to the AVON website and get the outside diameter...
    Howard
  20. mark1305
    Feb 7, 2005
    6,776
    Merritt Island, FL
    Unless Avon specifies, I would expect their numbers to be a static measurement.
    News Flash! Did the rolling circumference a little while ago and got...... 6' 7" or 79". :huh So we're back to 79/79, or Anton's tables are on target.
    I suspect most of the discrepancy in my first static measurement could be a combination of stretch in the cotton rope I used around the wheel, any extra length from "wiggles" as the rope may have aligned with some tread blocks, and lastly any actual variation in effective tire radius when the bike is loaded sitting on the pavement.
