Old 02-26-2012, 04:48 PM   #16
guzzimike
guzzimike's Avatar
Oddometer: 1,394
Hey fiwi, check your PMs
Armageddon Was Yesterday, Today We Have a Problem
East is East & West is West 2008
http://www.advrider.com/forums/ad.php?t=400050
A Long Weekend 2009
http://www.advrider.com/forums/showthread.php?t=523893
All the Way to Nowhere & Back Again. 2010
http://www.advrider.com/forums/showthread.php?t=619683
Save 5 bucks on your Smugmug, use my discount code
hQo9Atub1N9jg
guzzimike is offline   Reply With Quote
Old 02-26-2012, 10:49 PM   #17
fiwi OP
Oddometer: 145
Hey loose nuts, I checked the tension on my chain both on the centre stand and on the side stand. It seems that at no point around the chain is it tight in any way, it seems quite even in fact. any ideas?
fiwi is offline   Reply With Quote
Old 02-26-2012, 11:08 PM   #18
fiwi OP
Oddometer: 145
While I'm at it, there is a small black plastic panel, right side, just below the gs sticker which is held in place by 2 metal prongs I think, and 1 torx screw. The thing is, some how I have stripped the screw and the metal piece that it screws into. I don't want to be re tapping anything. Does that size torx screw come in a longer length so that I can just feed it right through and put a nut on the end?
Old 02-28-2012, 01:44 AM   #19
Loose Nuts Rick
Oddometer: 75
Well........ perhaps it's not your chain??
You were saying in your first post that your bike is now due for a service. Your mechanic should steer you in the right direction. Sorry I wasn't more help.
Loose Nuts Rick is offline   Reply With Quote
Times are GMT -7.   It's 09:07 PM.
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
